Question about Kenmore 95002 / 95004 Electric Kitchen Range
Door latch will not retract
The door latch will not retract. I was allowed to open door but now latch will not go back up in slot, therefore the door will not close completely. I have an error message and I have done what manual said to do to unlock. It does go away for a few seconds but comes right back and the latch is still out of place.
Thank you Furman
5 Suggested Answers
SOURCE: Door won't open
Try holding the Off/Cancel button.
Posted on Apr 14, 2007
  • 185 Answers
SOURCE: kenmore 90 series gas dryer door will not stay closed
try adjusting the door
Posted on Mar 24, 2008
lenwest
  • 150 Answers
SOURCE: latch problem...?
Make sure nothing is blocking the latch or the door.
Posted on Feb 22, 2009
  • 39 Answers
SOURCE: Getting FDL error with clicking noise and then beep
The FDL code is a problem with the door latch. The clicking your hearing is the door trying to latch. There should be a tech sheet inside the washer. It's usually located behind the bottom panel under the door, or along the inside of the casing on either the left or right hand side. The tech sheet will have a list of error codes, procedures on how to perform diagnostics, and troubleshooting hints. One thing I would suggest is to open up the relay and try to clean the contacts.
Posted on Jun 23, 2009
milten1
  • 1304 Answers
SOURCE: oven lock wont unlock
try unplugging the range for a few minutes this just might clear your eprom
Posted on Oct 05, 2009
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Right side door won't close
Latch sequence in fixture is in closed position. This means the roundish shaped tab is down and blocking the door latch from entering the door.
If you look at the opposite door you will see that the latch resembles a slot for the post on the door sill to slide into when the door is closed. Your problem door will have that slot closed off by the latch.
Sometimes child safety lock-outs may be 1/2 way engaged and it gets the mechanism out of time. Or the spring which operates the latch breaks and the latch will not retract.
Make sure that the latch is doing what you want before you close the door, or you may be writing about what to do if the door won't open.
Oct 06, 2013 | 2006 Lincoln Zephyr
OVEN DOOR LATCH BLOCKS THE OVEN DOOR FROM CLOSING ALL THE WAY. I CANNOT GET THE DOOR LATCH TO RETRACT.
Hi
There could be couple things. First, try pushing the door closed as you turn the handle. The latch may have dropped into the strike hole completely, binding the latch. Or you may try lifting the door as you try and open it. Friction is the one thing that most often happens causing a latch not to retract.
Another possibility is that the latch may have become detached from the knob set. If this is the case, you will have to remove the lock from the door, and from there you can open the door with a flat blade screwdriver. I recommend replacing the latch as well. If you remove the lock from the inside of the door, using a flat blade screwdriver you can pull the little 'T' that sticks out from the latch on the inside of the hole. This pulls the latch back away from the strike, allowing you to open the door.
There are different configurations of latches, and they activate like way. You could run into a long latch the lock runs through. You can use a large flat blade to activate that. If you have the type with the half moon, use the outside of the lock body, stick it into the half moon, and turn the whole thing to retract the latch.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | KitchenAid KEHC309JSS Electric Double Oven
My Kwikset door handles turn, but the piece on the inside of the door will not retract far enough to allow the door to close. It gets stuck about 3/4 of the way in. Any advice?
The latch houses the retractable part that catches the striker plate. If the retractable part does not retract far enough, then possibly that might need to be defective and need to be replaced.
Aug 25, 2011 | Garden
2007 ford freestar lift gate will not open even though I can hear the lock disengaging. Still feels locked. It is manual open, but cannot lift it, feels locked.
Try pressing the door closed while unlocking and releasing. If the door previously has been slammed shut hard or just due to general wear and tear the latching mechanism can become slightly relocated. This means that when the door closes the door is pressing tighter than normal against the door seal. The compressed door seal will put a lot of strain on the latch mechanism and can hinder its retraction when released. By pressing the door closed and therefore removing the strain due to the door seal you might allow the release mechanism enough freedom of movement to retract when released. If having got the door open then immediately adjust/relocate and lubricate the lock/release mechanism such that you achieve a happy medium of the door closing with a weatherproof seal but not so tightly as to put the latch under a lot of strain.
Aug 19, 2011 | 2007 Ford Freestar Limited Minivan
Driver door won't close 1999 ford contour
Drivers side door will not close because, it might have dropped out of alignment and is sagging down slightly!!! or if it has electric door locks, and someone in the family has failed to mention door locks were activated while that one door was still open!!! now lock mechanism has passed it's normal stopping place and is now stuck, therefore already locked and not allowing door to close all the way!! you might try disconnecting battery then try jiggling the lock, and hope silenoid didn't get burned out, open passenger door and look at lock latch, then check drivers side lock latch!!! if your lucky lock latch should unlock when battery is hooked back up. i have seen this problems happen often on older vehicles!!! especially on cars or trucks that have been in fender benders.........body shops know what to check for, they fix problems like this often!!!!! Good luck!!
Dec 13, 2010 | 1999 Ford Contour
When i close the door on my 95 chevy corsica it doesnt close. it just bounces back. please help im a girl and my parents dont know so use small simple words please.
I think what has happened is that the door latch (the one in the door) has somehow closed and won't let the door shut normally.
Here's how it works. The door latch consists of two major parts. One is the short, round metal tube thing that is attached to the car body about halfway up where the door shuts. Inside the door there is a latch in a slot that lines up with round metal tube thing when you shut the door. I think what has happened is the latch has closed, not allowing the door latch to slide over the metal tube thing and close completely. If you look at the latch in the door slot you'll (hopefully) see what I mean. Now how to fix it.
You'll need a medium to large screwdriver and maybe some help from a friend. First, lift the outside door handle like you are going to open the door. Hold it up. Then, with the screwdriver, push the latch in the door slot UPWARD until it clicks and latches.
It is difficult to put this in words but it usually is an easy fix. No damage done to your car (unless you REALLY slammed the door hard numerous times..).
Please re-post with any questions.
Mar 01, 2010 | 1995 Chevrolet Corsica
Upon recovery from a power outage, the oven door on a Kenmore model #911455881C engaged the automatic door lock, and it will not release. I have cycled the power off and back on; have tried starting the...
I traced the problem to a faulty motor in the automatic door latch. In an effort to get the range operable again quickly, I removed the latch and got the door open. However since I just removed the latch and did not rotate the cam on the motor, the electronics did not "know" that the door latch was open, and therefore it still would not allow the oven to bake or broil. To remedy this I had to completely disassemble the motor and rotate the cam 180 degrees so the the sensors would recognize an open latch.
Dec 23, 2009 | Ovens
2003 lincoln navigator running board stay out on passanger side unless your are moving (they retract) passenger mirror does not adjust backig up message continues saying door ajar
The door switches are built in the latches on each of the doors, they are pron to sticking, leaving the security module to beleive the door is open.
The simple fix is to spray a generous amount of WD40 on, in, and around the door latches, then opening and closing the door a few times. I would start with the passenger door as`this is likely the culprit. do the rest of the latches as a prevenitive measure.
Hope this is of some help.
Ed
Apr 20, 2009 | Lincoln Navigator Cars & Trucks
Kenmore 95002 / 95004 Electric Kitchen Range Logo
120 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
