Question about IBM ThinkPad T42 Notebook
The cpu fan has quit working, looking for instructions to replace the fan
  • IBM Master
  • 5,660 Answers
I can give you instructions, finding a replacement fan might be a little tough.
(Unless you have a good source, in this case Everybody Shares! Lol!)
IBM ThinkPad Service Manual, Free. (But the author indicates donations are welcome. {I'm going to have to do that one day!)
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th ThinkPad line. Go across, and left-click on > T42
This is a PDF file. (Don't shoot the messenger if you are aware of the following)
The computer you are on now has Adobe Reader on it which uses PDF files.
I would suggest however, that you should upgrade, (Free), to Adobe Reader 9.4 if you do not have it.
http://get.adobe.com/reader/
After you click on the t42 file name it will take a few seconds before you see the first page. It will also take additional time to fully download. Suggest you let the file download all the way, before looking through it.
(2 seconds to see the first page, an additional 48 seconds to fully download just now)
[You can save this PDF file to your computer. This way you can copy it to CD disk for safekeeping, and delete it from your computer to save Harddrive space. If you do not know how, and wish to, please post in a Comment ]
In the Bookmarks menu to the left of the PDF file, left-click on the + sign to the left of >
ThinkPad T40/T40P/T41/T41P/T42/T42P Series.
Now click on the + sign to the left of >
Removing and replacing a FRU. (Field Replacement Unit)
Scroll the file tree down, and click right on > 1130 Fan assembly
(The view is at an automatic 355 percent. I would suggest lowering it to a comfortable view for you.
Go to the top header, and click on the Zoom Out icon. ( - )
I reduced it to 125% )
The FRU removal list is shown in an order.
1) Battery
[ You should remove ALL power. This includes the AC adapter (Charger) also ]
2) I suggest you work on a table, Not on a bed, or directly on a carpet floor. These are High areas of Static electricity.
I also suggest you buy, and wear an ESD wrist strap. (Electro Static Discharge)
Connect the alligator clip to a Good ground source.
(I connect to the metal frame of an empty desktop computer case. +20 years, and no Anti-Static Mat needed)
Your body carries Static electricity.
Static will fry out (Short Circuit) the hardware components inside a computer. (It can also wipe off the data on a Harddrive)
An ESD wrist strap connected to a good ground source will prevent that.
An ESD wrist strap cost averages about $3 to $6.
Example of a typical ESD wrist strap,
http://www.amazon.com/Cables-Unlimited-ACC-1400-Static-Grounding/dp/B000EDMPQK
(A $3 ESD wrist strap will work just fine. If you keep it around, be sure to use sandpaper to clean the corrosion off of the metal pad that contacts your wrist)
3) Suggest you use a multi-compartment container for the various screws you will remove.
Mark the compartments for the area the screws came out of.
There are screws that look VERY similar to other screws. They are NOT the same.
Do Not mix them up.
You can use a clean egg carton in a pinch. Mark each egg holder.
4) Make notes, and drawings. Perhaps use a video camera, or digital camera step by step as you disassemble.
Nothing like having a record to fall back to, in case you are disturbed in the middle of working on your computer.
5) After all power is removed, remove the,
A) Harddrive. Page 81.
(In the PDF file page number box. To the right of the blue down arrow in the top header)
B) Keyboard. Page 85
C) Palm Rest. Page 94
D) Keyboard Bezel. Page 97
E) Now the Fan Assembly
(NOTE* I would not use a metallic object when removing the Fan Assembly from the top of the Processor's case. Static carrier, and could be magnetic. Use a stiff wood tool.
Be SURE to Thoroughly clean the top of the Processor's case, and the bottom of the Heatsink. There is a proper method if you are not aware.
Also apply fresh, new Thermal Paste. Cost averages about $4 to $6.
Once the Fan Assembly, (Heatsink) is removed, the areas must be cleaned, and new Thermal paste MUST be applied properly)
For further questions regarding the above, please post in a Comment.
Posted on Nov 15, 2010
  • IBM Master
  • 32,281 Answers
The CPU fan is located under the keyboard. To remove the keyboard there are 4 screws on the bottom of the laptop. The screws holding the keyboard in place have a small keyboard symbol next to each of these screws. When you remove the screws you can then lift off the keyboard, take not to damage the ribbon cable and keyboard connector.
The heat-sink and fan is fixed to the CPU with 4 screws, after removing these screws you can remove the fan and heat-sink. It may take a bit of juggling to clear the case. Take care to unlug the fan power cable/connector.
When you replace the fan, don't forger to put new heat-sink compound on the CPU and fan.
2 Suggested Answers
SOURCE: cpu fan
Honestly, take the laptop to a pc repair shop. Any other laptop, except an IBM and I'd say do it yourself, but these 7000 series notebooks are another breed of animal. The worst part is that there are no repair manuals for them.
Posted on Jul 22, 2008
CPU OVER HEAT
It is likely that a cooling fan is not working. Remove the side panel and start the computer (take care not to touch any parts inside) see if the CPU or other fans are operational. Replace the ones that are not working (don't try to fix them they are sealed and are quite cheap to replace) Good luck
Mar 02, 2016 | Computers & Internet
My Desktop PC assembled is emitting quite a bit of noise. Whenever an application or a download is started, the cpu usage shoots up and the noise / vibration also increases. What can I do?
I would think the SMPS fan, sounds like it's not keeping your computer cool. CPU fans usually never cause much trouble, but maybe you could look into getting quieter fans.
Mar 17, 2015 | Computers & Internet
Cpu fan can't run on dell dimension
You can clean or replace the fan.
Get the manual from www.dell.com/support
You can download it free and look up the fan repair instructions.
Hope this helps.
Mar 05, 2012 | Dell Dimension 2350 PC Desktop
Motherboard always cut off a few second after being power on.
I suspect that your cooling fan has stopped working or the sealing mating between the fan surface and the CPU is not intact. These fans quit working because dirt and grime gets into the fan shaft and friction slows the fan . also if the fan gets accidentaly moved on the CPU, then this breaks the heat transfer tape between the CPU. This over heating causes the CPU to fail. Open the machine and observe if the fan is running correctly.
Apr 14, 2011 | ASUS P4P800-MX (90M8LCI5G0UAY) Motherboard
The fan in my Toshiba Satellite M35-S456 not working
what is not working the fan or laptop?
when it stopped working the first time it is possible the laptop overheated and fried the cpu or motherboard. check the mother board and cpu for any physical marks where overheating has occured .
Aug 02, 2010 | Toshiba Satellite M35-S456 Notebook
I have bought a PIII 1Ghz CPU to replace my armada 110 Celeron 700MHZ CPU, Sometimes it works well for about an hour then just turn itself off, other times only lasted a few minutes. I've noticed that the...
With out knowing your motherboard it's a guess. However you can look at the link below. Then scroll to the bottom of the page. Your SL52R should be the 4th cpu from the bottom of the list. It doesn't look likely and it definitely runs hotter. http://www.cpu-upgrade.com/CPUs/Intel/Pentium_III/RB80526PY700256.html
May 30, 2017 | Compaq Armada 110 Notebook
How to remove and replace cpu for dell dimension desktop 2350
the cpu is a intel remove and replace a cpu is very easy
This link may help it is the rong model but dictates the process
You will need to open the case and be carefull of statick
ab510a2.jpg look for the cpu heatsink
Remove the fan unscrwe on the top
then remove the silver part this is held on with clips
gentley remove the cpu and replace new one THE RIGTH WAY look for the corners on the cpu to mach up on the board
Nov 24, 2009 | Dell Dimension 2350 PC Desktop
My fan runs extremely loud on and off
It is set up to run if CPU gets warm/hot. Quiet normal.
If it didn't you would son know. One Cooked CPU with Chips. Expensive tak Away.
Some fans are noisey. You could go to the expense and have a replacement???
Nov 16, 2009 | HP Pavilion dv2915nr Notebook
NX9119
The Laptop Shuts Down, Due the Processor Reaching It,s Heat Limitations, as set by the Bios/Motherboard Et,c. This Is A Safety function to Avoid Any Further Damage To The CPU Or Other internal Hardware. If the CPU Fan is not functioning, this is likely the cause. To Remedy this Problem, you,d look at removing the faulty fan ( Replace With New ) Or fully functioning Fan. And replacing the thermal Patch Or Paste, Between The CPU ( Processor ) And Heatsink Or Mating surface Between CPU/FAN.
I,d suggest not using the Laptop, until this has been repaired, as you will only cause more damage, which in turn. will become unrepairable. or very costly.
Mike @ Compurepair.
Feb 28, 2008 | HP Business Notebook NX9110 Notebook
IBM ThinkPad T42 Notebook Logo
296 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
