Question about Mitsubishi MSZ-A15NA Split System Air Conditioner
What thickness of cable is required to the power point for a Mitsubishi MSWZGA71KIT is it 2.5mm or 6mm?
    Scholar:
  • 77 Answers
20 amps for every 5kw or 1amp for every 100 watts here is a simple wire size calculator http://www.gorhamschaffler.com/wire_size_calculator.html you can find amp draw and phase on the manufacters data plate on the side of the unit .
Posted on Nov 15, 2010
LOgitech z 5500 "speaker cable thickness?
Ordinary copper wire will accomplish the same end result.
Jan 19, 2015 | Logitech Z-5500 Computer Speakers
I just bought a certified pre-owned 2012 Hyundai Elantra and the rear rotors are only measuring 6 mm. This seems very low so I do not see how it could have passed certification. What is the minimum r
Hello Bethany,
I know a bit about cars but being English I don't understand about rear rotors. I am guessing it is what we call brake discs or disc brakes.
Unlikely I would have thought the actual rotors or discs would be worn to a thickness of 6mm (which would be bad news) and perhaps you are referring to the thickness of the friction material?
It is only a relatively small percentage of braking effort that is exerted by the rear brakes so the rate of wear is much lower than the front brakes so it isn't unusual to discover new friction material isn't much thicker than about 8mm, though many are thicker and some are as thick as those at the front.
It is a general rule that is adopted by most brake and car manufacturer that replacement of friction material or disc pads is not required until there is only 3mm left and I have seen manufacturer's recommendations saying 2mm.
With 6mm of friction material still remaining which is two or three times the recommended minimum there would be no grounds to refuse certification.
Take your car to the service shop and the guy in the greasy overalls will ask himself if 6mm will last you until your next visit and if he is honest he will replace only after asking you what sort of mileage you cover. If he is normal he will grab the extra profit with both hands...
Jan 15, 2015 | 2012 Hyundai Elantra
2008 Mitsubishi release cable for Hood not working. When pulling on release inside car, the hood does not pop open to reach under and release the safety latch
I have a similar problem on my 2006 VW Passat.
I'm able to open the hood two ways:
1) ask someone to hold onto the lever inside the car while you try to lift the hood to the point where you can use the unlatch button and open the hood fully.
2) Pull the lever completely open in the car and try to find a thick screwdriver or some thick paper folded up to wedge next to the lever to hold it open while you get out and try to lift the hood to the point where you can use the unlatch button and open the hood completely.
Other than this finding a service manual or tutorial online about how to pull out whatever trim or interior covers you would need to replace the cable fully. There should be a specific replacement guide for this item since I'm sure it happens to car's at least semi-regularly
Aug 31, 2013 | Mitsubishi Galant Cars & Trucks
HOW TO ADJUST HEADLIGHTS IN A 1997 MITSUBISHI MIRAGE
There are torex screws on under the hood above headlights you can use a 6mm / 12 point socket or wrench also
Jan 04, 2011 | 1997 Mitsubishi Eclipse
Cross bar is too thick. the factory extension bolts are too long. what size (dia and # of threads) are these bolts?
I took the black factory bolts to Home Depot to determine what size was required but they didn't stock the required size. (Factory: 2 x 6mm-1.0 x 50 mm plus 2 x 6mm-1.0 x 60 mm replacements needed to be at least 5mm longer). I then went to Lowe's and they had them, but only zinc plated. I would have preferred stainless steel.
Tip: Depending on how thick your cross bars are, you can save a little by buying only two 65mm long bolts to replace the factory 60 mm bolts, and use those to replace the factory 50mm long bolts.
Jan 01, 2010 | Orange Inno Grab Max Ski & Snowboard...
What is the minimum required thickness allowed after wear on front vented rotor/discs vw golf mk3 vr6 presently the thickness of each surface on each side of the vented disc is 6mm and are quite lipped.
The standard vented rotor is 20mm (0.787 inches) thick and should be ground to no less than 18.5mm (0.728 inches) for your vehicle. The measurement is taken with a micrometer measuring total thickness from inside of rotor to the outside of the rotor.
Good luck.
Regards,
Aug 26, 2009 | 1998 Volkswagen Golf
I need a 12v cable for Sharp Aquos (car to tv)
click at www.shopjimmy.com they have the power cord for your tv.or go to google and type
power cord .
Aug 18, 2009 | Sharp Aquos LC-19D45U 19 in. LCD TV
REPLACEMENT PART FOR FRONT BUTTON CONTROLLER FOR WS 65611
Mine uses 6mm x 6mm x 4mm switches which are available from places like Mouser.com. Good luck.
Mar 10, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Hardwiring in cooker
6mm is the norm for wiring in the majority of electric ovens, you could fit 10mm, but it is is not really needed, unless you want to do it that way.
Please rate my fixya solution.
Thankyou.
Jan 30, 2009 | Belling Ovens
Is 10mm cable ok from 4kw oven to connector unit
A bigger cable size (larger diameter conductors) will not affect power requirements of the stove. (A smaller one definitely will)
Regards
Nov 16, 2008 | Neff U1721 Double circotherm Electric Oven
Mitsubishi MSZ-A15NA Split System Air Conditioner Logo
132 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
