Question about Kenmore Kitchen Ranges
Kenmore gas range model 362.75875691 will not function in bake or broil mode. Did all the tests and have determined there is no power when testing from the neutral to the bake and broil relay hot when bake or broil function is initiated. Power going into Timer erc panel checks out. The original problem is that the oven does not work. Glow bar not glowing. No power to the glow bar and resistance test is spot on. Sensor checks out good as do oven door open and clean mode checks out. Cooktop works fine. It seems odd that both relays have failed so my assumption is the Timer ERC 2 device is bad. Before I spend $200.00 for a replacement do you agree with my diagnostic or do you have a suggestion?
  • perrynowak Nov 15, 2010
    I appreciate your response but let me be a little more specific. I was performing a relay contact operation test per the technical data sheet. When I put the probes of the meter to the BA terminal (bake) to the Neu (neutral) terminal there was no voltage in the OFF position. When I had my girlfriend turn the oven on to BAKE the timer would come on for a few seconds and then go off. During this period there was no recorded voltage which should have been 120. I did the same test for the BROIL relay and the results were identical. When I did the oven control test across terminals L1 to Neu I had 120V in the OFF position of the oven. I failed to see what if anything the voltage did should I have had my girlfriend turn to Bake or Broil mode. I can't test that should I need to until this evening. Turkey time is coming soon and I'm being threatened about not having a Turkey Dinner. Thanks for your help.
  • 2,299 Answers
Yes. I completely agree with you. Both relays would not go bad at the same time.
Posted on Nov 15, 2010
  • Kenmore Master
  • 12,061 Answers
Well, IF you suspect that you have no power on the neutral (In reality there is no power on the neutral as it is the "Return" path for the current) However that doesn't mean that the wire is intact, it very well may be a disconnection, you need to meter each and every wire, and see if they have continuity from point to point, BOTH the Phase and the neutral. usually it is the Phase wire that is routed to each element or device, the Neutral, is used as a return or common wire. For something to work, it needs to have an unbroken Phase wire, and a connection back to the Neutral wire, to complete the circuit. You need to trace and meter out the Phase from where it comes in to each element and controller.
All a switch or a relay contact, does is make or break the Phase wire. this controls the element.
Usually it is the control rather than a relay, relays seldom fault... Controllers frequently do.
Try to obtain a service manual this will help you greatly. Please be careful.
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Oven elements aren't heating, Kenmore Range C970-655821
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 22, 2015 | Kenmore Ovens
No elements working on kenmore range
THINGS TO CHECK:
the broil element
The bake element
Apr 17, 2014 | Frigidaire Ovens
Kenmore md3 both elements stopped working at same time
the broil element
The bake element
Mar 15, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore electric range 790.91011200 When set in broil mode the broil element does not get hot but the bake element does. Should I replace the broil element?
yes. you can do a simple continuity test to be sure (on the broil) element, but you're gonna spend at least 20 dollars on a volt/ohm meter. if you have one already, you're in luck. just remove the element and test the prongs for continuity (usually setting RX1). more than likely the element just needs to be replaced
Jul 07, 2011 | Kenmore Kitchen Ranges
The bottom bake element does not heat up. I replaced it with a new one, still wont heat up. all other functions work. broil, top element heats up on bake.
Did you test the old element before you replaced it? If you did, then you would know that there is some other problem such as a bad wire connection or the bake setting control . Now you need to test each aspect of the wiring and controls that feed this element. macgivor
Dec 27, 2009 | Kenmore 94210 / 94211 / 94212 / 94214 /...
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Hi i have a kemore gas range that the bake ingiter or broil won`t
The igniter in the oven does not spark. It heats up and glows red hot until enough current opens the safety gas valve to the burner. It is not associated with the stovetop burners. Replace the oven igniter itself.
Aug 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Function Problem
Paul, the F9-3 code has to do with the oven door lock motor assy.. Water must have gotten on to it and now the fault. There is a quick test mode on the model ending in aab, if yours ends in this try this. Unplug the oven for 30 seconds, plug it back in and press and hold the cancel and broil buttons together. It should enter test mode. When in the test mode press the clean button to see if the motor activates and resets. Press cancel to exit the test mode...Catriver...post back
Aug 15, 2006 | Jenn-Air JES9800A Electric Kitchen Range
Kitchen Ranges Logo
105 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
