Question about Video Game Consoles & Games
The cursor will not appear on the screen. The buttons work, but not the cursor.
  • tomas863 Nov 15, 2010
    I have tried it as close as 1". There is no cursor. The batteries are good. It will turn the unit on on and off, and the buttons will move the menu left and right. But no cursor.
    The cursor arrow does not appear on the screen. The buttons on the remote work, but there is no cursor.
    The first suggestion was to check distance from the sensor bar. That has not changed since I have used the Wii for the past year, and it is not the problem. I even tried it one inch from the sensor bar. No cursor.
    President:
  • 1,891 Answers
This sounds like a bad sensor bar or the location is wrong . change the sensor location first and if that does not correct problem replace the sensor bar .. hope this helps nd thanks for using fix ya feed back pls ..
Posted on Nov 16, 2010
    President:
  • 1,139 Answers
This is unfortunately sometimes due to a faulty sensor bar. Check the wire from the sensor bar to the back of the Wii for frays or kinks. If it is the sensor bar these can be replaced very cheaply for around £10. Make sure there are no sources of infra-red light shining directly onto the sensor bar, for example bright sunlight. Try adjusting the sensor bar sensitivity within the Wii menu and see if this makes a difference. Finally try a different remote, if no cursor shows with any remote then it is 99% going to be the sensor bar.
Hope this helps and thank you for using FixYa
Posted on Nov 15, 2010
Double check your sensor bar and the distance you are from the sensor bar. You need to be between three and eight feet from the sensor bar for the cursor to appear on the screen
How do I use the video source button? I can see the different video inputs I can select on the screen after hitting the button but I can't move the cursor to select a different video source an
On Most TVs I have messed with, Hit the input or source button muliple times to cycle throught the different inputs. Also make sure there is an active device on the input for the TV to recognize it. Good luck
Jan 03, 2015 | Televison & Video
Screen on samsung computer
try with a other monitor,it can be brooken,or the videocard is brooken.
May 18, 2013 | Computers & Internet
Cursor and text jumps for dell inspiron 1150
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens. Type "Cursor blink" in the "Search programs and file" text box. A list opens. Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens. Click the "Speed" tab. A list of options appears. The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast." Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale. Click "Apply." Click "OK." The cursor stops flickering on the screen.
Feb 04, 2013 | Dell Inspiron Computers & Internet
Logitech m 705 mouse pointer flickering
A list opens.
Click "Apply."
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
HOW DO I CALLIBRATE THE SCREEN ON MY DS thanks
Directly from Nintendo:
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
Mar 15, 2011 | Nintendo DS Console
My son some how locked my 21' luxor tv and i dont know how to unlock it as i cant find the users guide
you want to go into the autolock menu.
cursor right to enter the code.
Using the NUMBERED buttons,
enter 0, 7, 1, 1. "XXXX"
appears on the Access Code screen
as you press the numbered buttons.
"INCORRECT CODE" will
appear on the screen, and you will
need to enter 0, 7, 1, 1 again.
then cursor down to change the code to whatever you want.
found a manual at WWW .manualshark.org/manualshark/files/26/pdf_24753.pdf
may not be yours but may help.
Bill.
Nov 29, 2010 | Philips Televison & Video
How do i get the language back to english?
Hello
Press the Menu Button on the remote to show on-screen menu.
Press Cursor Up or Down button to scroll through the on screen menu until the word Install is hilighted.
Press Cursor Right button to display the Install menu features.
Press Cursor Up Or Down button to scroll the install features until the word Language is hilighted.
Press Cursor Right button repeteadely to select English or Spanish [Espanol]
When finished press the Status/Exit button to remove the menu from the TV screen.
[The language control only makes the TVs on-screen menu items appear in English or Spanish. It does not change the other on-screen text features such as Closed Caption [CC] TV shows.]
Ok.
Nov 11, 2010 | Philips Magnavox 27MS343S 27" TV
I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
If the following doesn't work the tubes could be at the end of life:
Adjusting convergence:
Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
To adjust the convergence of the picture tubes:
  1. Press the 'MENU/SELECT' button on the remote.
  2. Press CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
  5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
  6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
  7. Press the 'EXIT' button to exit the menu.
If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
To Adjust multipoint convergence:
  2. Use CURSOR RIGHT to enter the PICTURE menu.
  3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
  4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
  5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
  6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
  7. Press the 'EXIT' button to enter ADJUST mode.
  8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
  9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
  10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
  11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
  12. Press CURSOR RIGHT to save the multipoint settings.
  13. Press the 'EXIT' button to exit the menu.
Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
Cursor will not appear on screen
make sure your sensor bar is connected to the console! properly aligned in the centre of t.v! also reconect the controler by: open the sd flap on front, press red button, remove batt cover of remote and press the connect button! this will resync the remote! also check battery's!
Jan 04, 2009 | Nintendo Wii Console
Cursor does not appear
exchange it
    Cursor not appearing
    Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
  • Some games do not use the cursor feature of the Wii Remote; Make sure the game you are attempting to play uses the cursor by reading the game's instruction manual. You can also exit out of the game to return to the Channel Menu and use the Wii Remote to see the cursor. If the cursor still does not appear, continue with the steps below.
  • Trying to use multiple Wii Remotes in the Mii Channel or Photo Channel? These Channels only allow the Wii Remote designated as "Player 1" to function.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote.
  • Check the battery power level by turning off the Wii console, then opening the battery cover of the Wii Remote. Press and release the red "SYNC" button to check battery strength. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength. Our experience has shown that as your battery strength decreases to one (1) or less lights flashing, the cursor may not appear. For troubleshooting, if possible, try using fresh batteries so that all four lights illuminate. For guidelines on using batteries, please click here. If after inserting brand new batteries, you are still seeing less than all four LEDs flash, then your Wii Remote will need to be repaired. Please click here for repair information.
  • Is the Wii Remote properly synced?
    Press the POWER button on the Wii Remote to see if the Wii console powers on.
    • If it does, the Wii Remote is synced with the system. Please skip to the next section.
    • If the power doesn't come on, power on the system manually and try syncing the Wii Remote.
      • If the Wii Remote will not sync, there is likely a problem with the Wii Remote. Please click here for repair information.
      • If the Wii Remote will sync and the cursor still does not appear, try another Wii Remote if possible.
        • If at least one Wii Remote is working, there is likely a problem with the first Wii Remote and it will need to be repaired. Please click here for repair information.
        • If you have only one Wii Remote, or none that are working, please continue troubleshooting.
  • Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup).
  • Check the cord on the Sensor Bar for any frayed wires or kinks, and verify that the Sensor Bar is free of obstructions.
  • Check the button functionality, and that the Sensor Bar is operating correctly, by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side through the Wii Channel screens.
    • If you are able to scroll with the "+" and "-" buttons, but the cursor is not appearing, then there is likely a problem with the Sensor Bar. Please click here for additional Sensor Bar information.
    • If there is no response, there is likely a problem with the Wii Remote. Please click here for repair information.
Dec 11, 2007 | Nintendo Wii Console
Video Game Consoles & Games Logo
75 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
