I had a set of computer speakers (Altec Lansing BX3). My wife plugged a heater into the surge protector and later yanked the heater plug out before turning it off. Computer went into some freaky cousin of a BSOD and computer speakers started acting up. Speakers were three parts: two smaller stereo speakers that wired into the back of the base with bare wire connections. The stereo speakers were fine, but the bass started making a loud humming/buzzing noise. The noise was not affected by turning the volume up or down, however it would go up and down in volume if I dialed the bass. Is there anything I can do to fix it? I opened up the back but I don't know enough about electronics to tell if something is broken. I was hoping there would be a fuse I could just replace, but I haven't found one.
Maybe the capacitor in the power supply burned upon unplugging the heater. The power supply is a coil with iron core, next to it, there should be a rectifier and a capacitor. If the capacitor is burnt, the powersupply will still be working, but there will be noise on the line, the 50 Hz that comes out of your wall outlet. Capacitor of the same value can be bought for small change but has to be soldered in.
Posted on Feb 13, 2011
Altec lansing acs33
the subwoofer plugs into the wall on a 110 volt outlet. then use mastervolume control.. RANDY
Apr 28, 2014 | Altec Lansing Multimedia Computer Speakers
Altec Lansing VS4121 speakers stopped working for no reason????
I had a similar set and they drove me mad because they hissed when they were switched off. I bought a pair of Bowers and Wilkins MM1 instead. Fabulous.
If you want yours fixed you would have to take them to an electronics engineer or return them.
Altec Lansing VS4121 Specs
Bowers Wilkins MM 1 Computer speakers Hi Fi Speakers for PC laptops Bowers...
May 14, 2017 | Altec Lansing VS4121 Computer Speakers
Can I connect my Altec Lansing ADA745 4.1 speaker system to an Acer AS5745-7247 laptop?
Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
Make the connections as follows
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Altec Lansing ADA745 4 Speakers
Speakers won't turn on
Make sure you are plugging in your speakers into a surge protector.
Try pluging in speakers to another (known) working outlet
If unit still does not power on, then unit is blown out.
Jul 13, 2010 | Altec Lansing ADA745 4 Speakers
My subwoofer and speakers wont draw power when i plug it in, could it be the fuse or something else?
The Altec Lansing A425 doesn't appear to have a fuse. Check for a circuit breaker on any surge protectors it might be plugged in to and make sure they haven't been tripped. Confirm that the power cord is firmly plugged in. Additionally, you could check the wall transformer with a multimeter to make sure it is providing the correct voltage needed by the speakers. Check the back of the subwoofer for a hidden power switch. If everything is plugged in and turned on, but you still don't have power, you will either need to open the device up and troubleshoot it or replace it.
May 13, 2010 | Dell Powered Subwoofer Set A425 Computer...
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing computer speakers , power requirements
You have to find out what the speakers are rated at then go form there. There is usually a placard or sticker on the back that says what watts and voltage they are rated at. Then you have to find out what plug goes in. Or you just buy an OEM plug
Dec 06, 2008 | Altec Lansing Multimedia Computer Speakers
Altec lansing speakers series 100 plugged in but sounds are distorted
I have to turn the volume to max to hear any sound. Up until now the speakers were great and only needed to be turned on slightly? any suggestions please?
May 07, 2008 | Altec Lansing Multimedia Computer Speakers
Wiring for Altec Lansing avs500
Hi, from a very old Altec ACS48 : Green - right speaker Red - left speaker Black - common, ground White, Yellow & another Black - power switch Orange - Led indicator Below is the pin layout
Jun 24, 2007 | Altec Lansing AVS 500 Computer Speakers
153 people viewed this question
 Grubhead
Grubhead
