Question about Sony VAIO VGN-N325E Notebook
Hi my Sony vaio just got a little wet and Whene I open it says operating system not found I press F8 and F10 it just tells me operating system not found how much does it cost to fux this
    Genius:
  • 1,325 Answers
Hi
shut down computer - remove power adapter, remove battery
use a blow dryer to dry off excess water or liquid from area . if your keboard got wet, you need to remove keyboard and blow dry that area, but dont get the dryer too close to the circuitry to avoid damage by heat. if this does not resolve issue -- let it dry for several days
start computer after 3-4 days... if problem persists, call a Sony service business center.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN325E&upd_id=2658&os_id=28
i hope this helps you
Posted on Nov 15, 2010
Operating system not found.
Now, this is a real embarassing fact of Sony computers. The error can occur even in out of box peice. Reset BIOS to default values, check if the computer is booting to Windows in safe mode and restore if yes. You can acess the safe mode by pressing the F8 key. If the issue persists, perform a system recovery using the recovery partition. You can acess the recovery partition by pressing the F10 key at startup. Selcet the Restore C drive option top recovery computer to its factory settings. If you want to backup and important data from the hard disk, use the rescue data feature option from the VAIO Care recovery partition. I could provide you with a more precise and direct article link if provided with the exact operating system and model # information.
Jun 08, 2011 | Sony VAIO Notebook
How to access recovery partition of Sony Vaio VGN-NW249F laptop?
Hi j5rak,
You can use the VAIO Care Software to access the Recovery Partition within the Operating System.
To open the VAIO Care Software, click Start, All Programs, VAIO Care folder and then click VAIO Care. Then, in the VAIO Care window, in the left pane, click Recovery & Restore . Then you can select the required option in the Recovery & Restore window.
You can also access the Recovery Partition by pressing and holding the F10 Key while restarting the Computer. At the Edit Boot options screen, please press the Enter Key to launch the VAIO Recovery Center.
Good Luck!
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Nov 11, 2010 | Sony VAIO VGNNW240F Notebook
I have sony vaio vgn nr310E pc notebook. I just
i cant find the model listed - is this the model VGN NR310
Theres a number of methods to get into the recovery manager on Sony - could not find any specific info on your model - I would try the following F8 or F10 (Alt + F10 ) should bring up the recovery manager as the PC boots - Do you have Sony Vaio Recovery Centre on the PC ? You can create recovery DVDs from this program
The support site for that model is here http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGNNR310E
Apr 09, 2010 | Sony VAIO VGNNR310E/S Notebook
Want to reset Sony VGN-NR160E/s Vaio NB to factory
Just power on your laptop and keep pressing F10 key. You will get one wizard to restore your laptop to factory settings.
iTechGuru
www.itechguru.in
Mar 29, 2010 | Sony Computers & Internet
My Sony Vaio PCG-K25 wont gp pass the black screen. I hear the fan and the power is on but the screen remains black. I took the battery out and had it powered through the chord. Still now working. Please...
Hello.
Either you have a memory issue or operating system problem.
First, try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Dec 08, 2009 | Sony VAIO PCG-K25 Notebook
No operating system not found comes up. It is a
You must install your OS (Windows XP, Vista, Windows 7, etc....)
Nov 21, 2009 | Sony VAIO VGN-BX760NS2 Notebook
Hi what is the buttom i press while i turn on my laptop to recover vista vgn cr490 i try but didnt work
Try with F10 key at start up.
Restart the System, tapping the F10 key immediately. This should trigger the System to boot directly to the Recovery Partition, and initiate the VAIO Recovery Center, without requiring the Windows Operating System to load.
In the VAIO Recover Center, select the option 'Restore C: Drive' and follow the onscreen instructions to perform a C: Drive Recovery.
Performing a C: Drive Recovery will erase all the data present in the C: Drive and will reinstall the preinstalled Operating System, Applications and the original Drivers.
Good Luck!!!!!!!!
Oct 13, 2009 | Sony VAIO CR Series Notebook PC...
Won't boot up,black screen says operating system not found.
well its tough to say, could be a harsh virus, or damaged registry. Try starting it up and as soon as it starts press f8 repeatedly until the safe mode menu is prompted, then from there pick a the option that best suits you, either safe mode or safe mode with networking. In just regular safe mode you can go in and remove harmful data from your hard drive. Maybe running under last know configuration might help. Let me know what happens.
Sep 05, 2009 | Sony VAIO PCG-K35 Notebook
Windows did not start correctly
well..battery has little to do with windows starting..try it again, pressing F8 when loading up..that goes to Safe mode, where you do some troubleshooting.
May 10, 2008 | HP T2330 15.4" 250GB QP/w remote PC...
Sony VAIO VGN-N325E Notebook Logo
248 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
