Question about LG Microwave Ovens
MY LG MICROWAVE APPLIANCE, MODEL NO:MG396WA IS NOT WORKING. ELECTRIC CONNECTION IS THERE. WHEN I START IT ONLY SHOWS "O" SIGN . NO BUTTON IS WORKING (SECONDS ETC). PLEASE HELP AND ADVISE ME. SANJIB KUMAR CHAKRABORTY M-9830223323 e mail: sanjibddp@gmail.com
MicrowaveSvc
  • 9098 Answers
SOURCE: LG LMVM2055SB over the range microwave keys not working
Is it possible someone may have sprayed cleaner directly onto the keypad area?
This causes moisture to get into the keypad and sometimes onto the control board.
This could mean that they control panel frame with keypad (membrane switch) would need to be replaced.
Can you give more details on the cleaning?
Posted on Nov 18, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Kenmore Galaxy Microwave Hood Combo Model 72180002400
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Posted on Aug 02, 2008
MicrowaveSvc
  • 9098 Answers
Since it sounds louder than before, it is probably a bad high voltage diode or magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
Sears may send you a magnetron to install yourself since it's under warranty. For that or warranty service, contact Sears at http://www.sears.com.
You can save about $75 by taking it to the shop yourself, as opposed to an in-home service call.
Posted on Aug 08, 2008
localwonder
  • 6784 Answers
SOURCE: I have a Magic Chef microwave model mco153sf. The
HI. This is , indeed, an issue within the touch pad circuitry. it is damage, and will require replacement. I have located a replacement touch pad. Use the link below to access the touch pad. You can order the pad on-line, by clicking the link below.
CLICK HERE
Posted on Dec 23, 2009
  • 570 Answers
SOURCE: tuch pad problem in my compaq laptop,model
I have provided below the address of a few service centers in kolkata
88A Sarat Bose road
kolkata West Bengal 700026
contact number (033324863621)
2/6 Lala lajpatrai sarani Sarat Bose road
contact number(03324748320)
Microleans laptop service center
contact number(08013962015)
Also I am mailing you the above details
Please rate me if this solution works for you
Thanks......Have a great time
Posted on Jun 14, 2010
LG model LMV1638SW microwave intermittently runs.
The microwave runs intermittently. You should open it up and look at the connections to see if any have darkened or burn like signs. If you find that, you can either replace the (usually plastic) connection piece, or just remove it and reconnect the wires (that were housed in it), to their connection points. If you want, you can use electric tape to cover those metal wire connectors, but it's not necessary it nothing else is touching.
Nov 07, 2013 | Microwave Ovens
Lg lmv1630bb microwave
Unless you are successful with a hard reset of the elctronics you are SOL and need to get a new control board. Check out the attached for parts Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Microwave Ovens
GH7155XHS Microwave control panel
If you do not want to get the newer model due to configuration changes it does not appear that you have another alternative other than to replace the logic board on unit. And unless you can spot a very obvious issue with the board, there is no way for you to fix it especially if it is a bad ic with beaucoup connections to the board.
Mar 24, 2017 | Whirlpool GH7155XHS Microwave Oven
Part of the keypad on my microwave does not seem to be working. I can key in the cook time, although the zero is not working. The start and cancel buttons will not work. The message "press start or...
The keypad has gone bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 15, 2011 | LG Microwave Ovens
Microwave is getting electricity, but does not light up or come on at all anymore. Is there a "locked" feature that might prevent it from turning "on"? It was working previously, but...
there is fuse inside the microwave.you may have to take the cove off to get to it.caution must be used as there is a high voltage cap.that may need to be discharged for safety!!!!! replace with ONLY the same type of fuse!!!
Oct 26, 2017 | Maytag MMV5165 Stainless Steel 1000 Watts...
We have a over-the-range LG Microwave Model #LMVM2055ST purchased in 2006. It was working fine until today when I tried to heat something, it wouldn't start. The light works inside when you open the...
Most likely the touch panel is bad. You can try ordering a new one from repairclinic.com by searching with your model number. If you find that replacing it doesn't help, return the panel within 30 days and you are only out the shipping costs. With what you describe, it should be the panel itself. Let me know what you find out.
Benjamin
Nov 04, 2010 | LG Over-the-Range Microwave
Microwave stopped working when i pushed the start button
Yes. The white inside the glass that you are describing is a blown fuse. To find out what size fuse it is look around the base or top of the fuse. You will see engraved something like "125V 5A. You can pick these up at Home Depot or Lowes in the electrical isle. You can also type www.google.com and enter the word "fuse" and then the size it is. (125V 5A) If you have found this information at all helpfull, please rate my solution. Thanks D. Lange
Apr 23, 2009 | LG Microwave Ovens
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Mar 12, 2009 | LG LMV2083SW Microwave Oven
LG LMVM2055: Cooked itself?
First you will need to answer a few quick questions between yourselves.
  1. Do you have life insurance?
  2. Is it enough for the wife and kids to survive on
  3. Whats the number for 911
After you answer all these questions, then pick up the microwave, and take it for a long drive.
There are bits inside there that will happily kill you days after it has been turned off. (some even weeks)
For the cost of a replacement in this case, it's not worth it.
Apr 18, 2008 | LG LMV2055ST Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Will Halftowaite
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
