Question about Dryers
My dryer (Simpson Minimax 150) seems to be choked? It gets hot and the drum spins, but it doesn't dry clothes and upon opening the door, heaps of steamy air pours out. The lint filter is clean. Is there somewhere else that requires "de-linting?"
Probably the belt from the fan has broken. The fan is what moves the hot steamy air out of the unit.
try here for parts
http://stores.shop.ebay.com.au/ALLFIX-ELECTRICAL__W0QQLHQ5fSellerWithStoreZ1QQ_dmdZ2QQ_sasiZ1QQ_sidZ70171QQ_sopZ10?_nkw=Simpson+fan+belt&submit=Search&LH_TitleDesc=1
Posted on May 04, 2009
    Champion:
    Scholar:
  • 210 Answers
Check your vents sounds like it is cloged up with lint. Take the vent off the
dryer and see if the air is coming out good , if not check for lint in the machine and around the blower. If air comes out good check the out side vent for good air flow.if you have a leaf blower you might blow it out from the inside to the outside. Hope this helps
Posted on Apr 17, 2013
My dryer gets hot but doest dry my clothes i lifted the top and spun the barrell around and noticed that the seal is torn could that be the cause
Sounds like a belt problem with no clothes in the dryer turn the dryer on for a minute or so open the door if the drum is spinning it not belt if drum is not spinning it's more that likely the belt that turns the drum.also need to check the exhaust hose in back of dryer it could have a blockage check lint screen also.Hope this helps.
Oct 20, 2016 | Dryers
Simpson minimax dryer not getting hot does spin timer works will run for about 2minutes then blows fuse
It is most likely a failed heating element, when it attempts to heat it causes a short, blowing the fuse
Jun 05, 2016 | Dryers
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Dryer does not dry clothes but seems to be hot inside when i open the door
Most of these guys get a bad blower wheel. The heat melts the hub causing it to spin free and airflow is reduced. This makes it take fifty forevers to dry a load of clothes. More Here
Aug 18, 2010 | Crosley Dryers
Mayteg model DE313 clothes dryer that stopped drying clothes.
That is a very accurate assessment of the problem. Check the element for continuity between its two contacts. If there is none, replace it. If there is, look for a fuse on the side with two wires going to it. Test it for continuity. If there is none, replace it.
Jul 21, 2009 | Dryers
Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
Mar 21, 2009 | Dryers
GE Profile Harmony dryer error message
Possible Solution...
When you get message first try turning off. Open door spin drum one or two times. Close door. Power back on/start.
Works for our problem. Post if this helps.
Oct 29, 2007 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
445 people viewed this question
Top Dryers Experts
