Question about KitchenAid KCM511 Coffee Maker
How do I set the auto brew on my kitchenaid kcu222cu coffee maker?
5 Suggested Answers
  • 19 Answers
SOURCE: Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Posted on Jan 19, 2008
Coldcut
  • 1554 Answers
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
VtToolMan
  • 704 Answers
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Posted on Nov 10, 2009
SOURCE: my kitchenaid coffee maker gives
This problem occurs between 6 months and 1 year of these coffee pots. I have contacted customer service each time this occurs and have received a new coffee pot. Unfortunately, I am calling them again and again because the new coffee pots do not even last their warranty time and the ERR2 light again comes on and ruins my morning. I would not recommend this coffee pot. It is expensive and life time is not long at all. Customer service has been great but how many times do you have to return a coffee pot for Kitchenaid to get the hint that it needs to be fixed. Most consumers will get angry, throw it away and never buy the same one again. So, wake up Kitchenaid and smell the COFFEE!!!!!!!!!!!!!!!!!!!!!!!!! Fix this coffeepot. I am not the only one who has had this problem. Customer service @ 1-800-541-6390 Hope this helps. When they send you a new one they send you free shipping back for the old one and you use the box the new one came in.
Posted on Dec 13, 2010
How do I run the clean cycle?
I assume you mean descaling the coffee maker when the Clean indicator flashes after a brewing cycle. You can use a packaged descaling product or white vinegar. For the packaged descaling agent, follow the package directions for the ratio of product and water. If you are using vinegar, fill the carafe with a 50:50 mixture of water and vinegar.
Remove the water filter and remove any coffee and coffee filter from the brew basket. Make sure the unit is plugged in and turned on. Pour the descaling mix from the carafe into the water tank and then place the carafe in the coffee maker. You have 10 seconds to program the cleaning mode or the unit will return to the standby mode. The next step depends on the type of carafe. For a machine with the glass carafe, press Mode 6 times. Otherwise for a unit with the thermal carafe, press Mode 5 times. The Clean indicator will blink. Press Program/Set followed by the + or - button to select Clean On. Press and hold Program/Set until you hear the beep. Press Brew and wait for the cycle to complete (the Clean indicator will go off). Then do two brewing cycles with water but no coffee or coffee filter. Discard the fluid from the coffee maker from all three cycles. Wash the brew basket and then reinstall the water filter.
If you notice an odd taste to the coffee when you next brew some, do at least one more rinse with water (remove the water filter and coffee grounds/filter).
KitchenAid manuals are available from their site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The direct link to the manual for the Kitchenaid KCM223OB is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10321647.pdf . See page 13 for the directions.
I hope this helps.
Jul 04, 2011 | KitchenAid KCM223OB
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future.. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
Kitchenaid Proline program light doesn't stay on & it won't auto start brewing
Pro Line appliances have an extended 2-Year hassle free warranty on them. If you are experiencing any problems with a Pro Line coffee maker, I would suggest calling Kitchenaid Customer Service.Their toll-free telephone number is:
1.800.541.6390.
Aug 03, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
How do I turn the beeping off on my Kitchenaid Coffee Maker when it's brewing?
There is no programming function that allows the beeping to be turned off on a Kitchenaid Coffee Maker.
Apr 01, 2009 | KitchenAid KCM511OB 10-Cup Coffee Maker
Coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart CBC-00FR 12-Cup Coffee Maker
Kitchenaid coffee pot won't brew coffee reads err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does reappear, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Mar 13, 2009 | KitchenAid KCM511 Coffee Maker
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
KitchenAid KCM511 Coffee Maker Logo
648 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
