I have a flat screen tv monitor and it just went black. I've tried other monitors so it's not my pc. How can it be fixed or would it be better to just get a new one.
  • Computers & ... Master
  • 5,159 Answers
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Nov 15, 2010
Tv monitor went blank when using my pc on it
try adjusting your resolution before you plug the tv into the pc. a 26" shouldn't cause this problem, but it may. Give it a try. If this doesn't work, try finding a driver on the Sanyo website for that pc and download or repair the existing driver. You'll need to use another monitor, of course. I hope you have one.
Dec 31, 2013 | Sanyo 26in LCD 720p HDTV - LCD TVs
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
Dell 17inch flat screen monitor will not remain on, the screen go
If your Dell monitor still under into warranty, better to call Dell technical support and have them replace your monitor coz there is no way you can fix on it.
If the monitor is beyond with the warranty already, better to but a new one than taking it repair that will cost you much.
Thank you.
Oct 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
My wifes Acer monitor suddenly went black
When you turn on the monitor, and if you see the power light blink i really doubt that the monitor is at fault. If it failed at all, it would likely fail completely.
Sorry to be bearer of bad news, However, there is no shortcut to reset the monitor.If you open the monitor you would find nothing than a circuit board with long string of capacitors and diodes.
However, before we jump to the conclusion that, monitor is at fault.There might be 2 more reasons.I have seen in the past that sometimes, motherboard fails while you are working on PC and sometimes Window Crash.
Lets work bacwards.
Restart PC. Press f8. If you did'nt get any screen, more likely either motherboard is corrupted or monitor is at fault.
If you do see screen, might be settings, any other colour, Load Windows again as your windows might have crashed.
Motherboard - I have seen many people throwing their monitors thinking that it's their monitor who is at fault. However, in the end its motherboard.
Try to attach your monitor with some other CPU.If that works, motherboard is corrupted.You need to repair or replace that.
Unless. Monitor.
If you honestly ask me its much better to purchase new monitor.If you want to repair that, it might cost you some bucks And once repaired, the issue would always be there ( Though not for some time ).
If you still want to fix that, tell me the model number, so that we can work together to fix that.
Thanks for using Fixya.
Mar 25, 2009 | Acer AL1913b 19 in. Flat Panel LCD Monitor
I have a Dell 19" flat screen TV/Monitor that came with the computer and is my computer screen. While watching, the picture went black. We have determined that it is the TV/Monitor by hooking up another...
Try these :
1.) reinstall your operating sys .
2.) sounds like there is a short somwhere. is it under warranty?
3.) Check the plug-in for the external power pack. Mine did the same thing and it turned out to be an old and week connection at the plug... the contacts were not fully making.
Let me know if teh above are OK .. !
Mar 20, 2009 | Recoton Advent Advent Q1435A TV
Screen resolution issue
Use the "F-8" key at boot to get into safe mode. You should then be able to fix the resolution/refresh rate conflict while in safe mode, and get back to normal.
Jan 30, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Monitor not working
It may well be dead. Try testing the monitor on another working PC. Also try a working monitor on the problem PC. Then you will know whether it's the monitor or the PC graphics card that's faulty.
Jan 09, 2009 | Dell Dimension 2400 PC Desktop
Gateway flat screen monitor goes black when turned on
open monitor and look at the PC Board to locate some kind of DRY SOLDER or burn point , specially where a transformer is located , check re solder any solder point that looks suspicious , and try again , hope this helps
May 03, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
