Question about Vacuums
How do i program my radio shack pro 71 scanner
  • 10,865 Answers
Hello John. Here is the link to your owner manual and other documents radio shack provides for this model. http://support.radioshack.com/support_electronics/52330.htm
Joe
Posted on Nov 15, 2010
Manual concertmate 900
Do you mean a Radio Shack Concertmate-900 keyboard? I've found a Spanish edition of that manual on the Radio Shack support page: http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=42-4017&Name=Musical%20Keyboards&Reuse=N . It's also here: http://support.radioshack.com/support_games/8498.htm . My Spanish isn't very good but I was able to understand most of the document. The direct link is http://support.radioshack.com/support_games/doc33/33079.htm . (Google Translate may be able to give you an English version of the page.)
I hope this helps.
Jul 14, 2015 | Vacuums
I have a euro model s3325 and when i turn on the power switch it says its steam ready but will not heat up
I think it may be from the same issue stated above--the thermal fuse blew. I have the exact same problem. This is what someone posted earlier:
There's a thermal fuse inside. If it gets too hot, the fuse will blow and the thing won't turn on.
It has a 216 C temp limit. You can find thermal fuses at radio shack for less than 5$. If you're adventurous enough, you can find the fuse in line of a white wire under a fiberglass outer and heat shrink inner shielding screwed against the bottom of the tank.
Now to figure out how to get to it!!!
Aug 12, 2011 | Euro-Pro S3325 Handheld Steam Vacuum
I need a couple microtemp fuses 240 degrees C G4A00 for the wolfgang puck swivel waffle maker.
Radio Shack has a 228C and a 262C.
Google '240C thermal fuse' for online purchasing.
If you live near an urban area, try an appliance repair facility or electronics supply.
Feb 28, 2011 | Vacuums
I have a casio keyboard LK-100 and one of the keys only plays when pushed partway down. any suggestions?
dirt under key need compressed air ------------ spray under key tuner cleaner from radio shack restores carbon track
Jan 18, 2011 | Vacuums
Shark Steamer model S3325 will not power on; switch appears to be working but will not indicate on and will not heat tank. I can hear it try to start the heating element (secondary clicks) however, does...
Dec 28, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Replacement power supply is impossible to find... Even techworld the original manufacturer does not have it listed.
If you look at the original power supply, there should be a label with the following details included:
Output voltage
Maximum output current
The polarity of the output connector (which bit is positive and which negative).
If you take this info to an electronics retailer, e.g. Maplins in the UK or Radio Shack in the US, they should be able to sell you a universal power supply that can be configured to match.
Nov 04, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
Plugs in does not turn on
Unplug unit, separate front and rear panels by removing screws. There is a small in-line thermal fuse 192 C (192 degrees celcius). It may or may not look burned, mine wasn't. It can be replaced with little difficulty with right tools (no soldering necessary). Check at Radio Shack first then with wholesale elctronics distributor, where I found one close (228C). Cost about $2.00. Good Luck.. Old Geezer
Nov 03, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My daughter purchased a Steam iron Make
Don a thermo fuse can generally be bought at an electronics parts store or Radio Shack type outlet in the hobby parts area. Like any other fuse they are rated specific to the requirement of the appliance, do NOT use a higher temp one.. If you have warranty, ( likely 1 year???), return the iron, If you replace it, it is generally an in line crimp. I would only attempt it once as the iron may be defective.
Sep 11, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Vacuums Logo
301 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
