Question about Garmin GPS
I'm getting a message that maps can't be located, and are needed to operate the device. The devise is all or the sudden unusable. Any ideas why or how to resolve?
  • 1,514 Answers
The solution to this problem is at http://www.fixya.com/support/r6197735-no_detailed_maps_found_support_routing
There may be more information there than you need. If the message you get doesn't say "No detailed maps that support routing" you can start at paragraph 2.
Posted on Nov 15, 2010
How do I get the devise to work here in Australia
probably does not have maps installed for australia.
Mar 26, 2015 | Garmin nuvi 1350 Car GPS Receiver
Garmin Nuvi 360 says memory full cant reset
Connect the unit up to a PC and try deleting some of the unused text-to- speech (TTS) voices. Keep only the ones that you need. Delete any unused photos or MP3's...and also any unused vehicle icons on the unit. When the unit is booting, it loads in all of the vehicle icons allowing you to change the selected vehicle, so this too uses up valuable memory.
Apr 08, 2013 | Garmin NUVI 360 GPS Receiver
All of a sudden, when I plug in my garmin nuvi 660 and it boots up, I have the following problem.When I try to enter my state(Texas), after entering the letter T the screen flashes and I get an error...
Make sure your City Navigator map is enabled. To check your map, press the wrench/tools button, then the map icon and then press "map info".
You should see your map listed with a box next to it. This boxed should be checked. If it's not, then your map is turned off. Press the box and to place a checkmark in the box. This will turn your map back on.
- Jim
SHARCNET-USA
Aug 23, 2011 | Garmin Nuvi 660 GPS Receiver
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
I have just bought a tomtom sd card of western europe overwritten with tomtom map of new Zealand.when inserted the tomtom520T just gets stuck on a tomtom picture page and nothing works ,any ideas,regards...
Assuming the maps have been registered for your device.........try resetting the device.
If the maps are not registered, it may eventually boot up, but you'll get a message saying that the maps are not authorised for this device.
Mar 04, 2010 | Tomtom GO 910 GPS Receiver
It says "no maps found"
I had the same problem before on a TomTom GO 730. The free internal memory was too small to hold the updated map so installation failed (the download to PC was OK, the message is misleading).
It's a TomTom software bug to not check on the available free memory properly before the update process is started.
My TomTom device required a new software install from scratch. Remove any excess MP3 or unused voices before you retry the update.
Feb 06, 2010 | Tomtom One XL GPS Receiver
I get the message "no detailed maps can be found that support routing. The nuvi cannot be used without them." and I can not get to anything else on the garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
Jul 18, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
When the "no detailed maps found that support routing" screen comes up it covers any of the icons, so I'm unable to do anything.
  2. Select myMaps
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Cannot download maps I purchased
Closed program. Reopened Home screen, new map downloaded and installed as it should. Thank you for asking.
Mar 27, 2009 | Tomtom GO GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
GPS Logo
22 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
