Question about Brinkmann Grilling
My Brinkmann 4 burner grill is not getting hot enough to cook anything. All burners appear to be working, but not giving out enough heat to cook a burger
  • 35 Answers
SOURCE: Low flame/ side burner dosen't light
Try this, close your burners and your propane tank off, let sit for a couple of minutes. Making sure your burners are off turn on the propane tank and let it pressurize the line for a couple of minutes. Turn on the burner that is closest to your igniter and light it. After that burner is lit then you cn turn on the other burners. Good luck and hope tht solves your problem.
Posted on Dec 07, 2007
SOURCE: gas grill loses pressure while side burner does not
I had the exact same problem with my Jenn-Aire and so I replaced the regulator for $20 and it now works fine.
Posted on Feb 28, 2009
cadesertmax
  • 274 Answers
SOURCE: How do I take my Weber Genesis grill apart to
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Posted on Jan 10, 2010
  • 332 Answers
SOURCE: problem with gas flow, flame not hot enough to
Possibly you need to adjust your regulator but don't try that until you try this.
With the new style OPD tanks the male fitting must screw in deep enough to depress the valve fully to get max gas flow - in the female tank fitting there is a small brass ring that can back off and not allow the valve to fully open.
tighten this brass ring and you troubles should go away, or take the tank to a good LP service center and they should have the correct wrench to fix it
Posted on Mar 11, 2010
  • 2464 Answers
SOURCE: gas will not flow to burner to light grill?
could be the reg on the tank , not working no flow of gas ,
Posted on May 17, 2010
VERY LOW HEAT ONCE LIT. TAKES EXTREMELY LONG TIME TO COOK ANYTHING AND THE FOURTH BURNER DOES NOT LIGHT
The new propane bottles have a safety device in them that shuts down the gas if it senses the gas is going out the bottle too quick. Thank you Ralph Nader. To remedy this yall shut all valves off and remove the tank from the grill. Open and close all valves just for fun making sure all of them are off. Then reconnect the tank to the grill and SLOWLY open the triangle shaped valve to just bare ly open, maybe half a turn or less and then retry. More here
Jul 01, 2011 | Brinkmann Charmglow Stainless Steel LP...
I have my Weber Q grill hooked up to a large propane tank rather than the small tube type. It worked fine for a few weeks but now the grill only gets medium hot. Not hot enough to cook anything really. ...
Seems as if your grill is suffering from "Clogged Burner Syndrome". But, don't despair, it's easily solved by removing and thoroughly cleaning the burners or "coil" as you called it. Also, pay particular attention to the venturi valves on the open end of the burner. Spiders like to build nests in them. The venturi valve will look like a slot on the right and left of the burner tube, where it fits over the burner orifice. It's really a good idea to perform this routine maintenance, at the start of each grilling season.
When it comes to gas grills, it's like Benjamin Franklin said, "Cleanliness is next to Godliness."
Hope this helped you solve the problem. Happy Grilling!!
Jun 02, 2011 | Weber Q Grill
It doesnt heat evenly. Burners all fire perfectly, yet heat distribution is very hot in the center, and much cooler on the outer sides. This unit has 4 burners under grill. Any suggestions?
Tex, the other burners my be clogged, as well as the venturi valves. Remove the offending burners, inspect and clean them. That's usually the the problem, with what you described.
Hope this helps you. Happy Grilling!!
May 08, 2011 | Brinkmann ProSeries 810-6330-W Grill
How do I light the grill manually
Get a butane grill lighter. Open the hood of your grill. Remove the cooking grates and one by one turn the burner to low. Light the butane grill lighter prior to turning the burner on and as you turn the burner to low touch the flame of the lighter to the burner. Leave all burners on low, until you replace the cooking grates. Be very very careful, as you don't want gas to buildup before each burner is lit.
Then contact Brinkman for replacement ignitors.
Jan 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
The burners do not get a full flame anyomre, nor
you may have spider web in the burner ... disassemble and blow it out with canned air or a air compressor ...
May 02, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Crossover channel for burners is broken where can i get replacement
i have a jenn air grill, i have bought new burners & heat plates, i still cant get it hot enough to cook a steak, i have replaced the fuel tank& regulator, what gives? any suggestions
Mar 28, 2010 | Brinkmann 810-8410-S Stainless Steel...
Charmglow gas grill is not generating as much heat as it used to
potatoes should take about 30 minutes. if your grill is not hot enough un hook the tank and hook it back up again as you have a safety valve partially closed
Jun 07, 2009 | Brinkmann Charmglow 810-7400-S Propane...
The entire 4 gas burners do not get hot
here is the link to brinkmann.net so you can contact them directly.
http://www.brinkmann.net/Customer%20Service/
Now, the most common problem on all recent gas grills is that the regulator in the gas hose now has a safety feature which prevents it from leaking. Sometimes this feature gets stuck.
Unscrew your propane tank from the regulator, tap the regulator a couple of times and reattach it. This may solve your problem. If not, use the link above.
Apr 10, 2009 | Brinkmann 810-8410-S Stainless Steel...
Grilling Logo
361 people viewed this question
Top Brinkmann Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
