Question about Canon PowerShot SD1100 IS Digital Camera
When I turn my camera on, I get a message that says, "Lens error, restart camera," but everytime I restart it, I get the same message.
  • Jennie Heidinger May 27, 2012
    I have the Canon Powershot 1100SD and it has been "broken" for a year. My Mom told me to research it and I finally did. I came to this website and decided to try one of the solutions which was to press the on button and the zoom at the same time and when I did...it came on and the lens came out!! I am so excited and thankful for this website and the solutions to try. THANKS!!
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 15, 2010
Testimonial: "Thanks, your advice fixed my camera! I'd like to send $5. How do I do that?"
  • Ty Price Nov 15, 2010
    Thanks, but some of us answer questions for free just because we like to help other photographic "nuts" like ourselves.
  • randamcdonal Nov 15, 2010
    Bless your heart, typrice, and thanks a million. There's a great place for you in camera heaven, but hopefully you will be around for a long, long time to help needy people with camera woes like me.
    Thanks again! I will "pay it forward."
    Randa
  • 134 Answers
Tap it on something with the lens facing down do so gently sometimes it will free it up it just gets jammed up sometimes
Testimonial: "It worked! Thanks! My camera is working again."
  • par sims Nov 15, 2010
    if you do it doin it when the camera is on
I recently had the same problem with my camera, and fixed it by sticking a pin in the lens, to free up any sand or dirt particals that might have gotten in it. Usually a thinner pin, is better because it allows you to free sand or dirt that might have for example, gone further into the lens. If that doesn't work try doing the same thing with a very thin knife. This doesn't work as well but is a second option. Hope that helped!
Posted on Dec 31, 2010
edo333
  • 55 Answers
SOURCE: Lens Error, Restart
When you start the camera does the lense zoom out, and or does the lense cover open and close properly?
Posted on May 01, 2008
SOURCE: Lens wont close.
my camera says the same thing. i dropped it and now it won't close or start or open. how do i fix it?
Posted on May 11, 2008
Nikon System error help????
Posted on Sep 24, 2008
ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
  • 11967 Answers
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Posted on May 25, 2010
Camera displaying error message
Have you tried cleaning the lens contacts, both on the back of the lens and in the mount on the camera body?
Jan 14, 2013 | Cameras
Everytime I power on the camera it says "lens
Go to this website for the solutions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 27, 2011 | Canon PowerShot SD1100 IS Digital Camera
I turned on my camera as normal to take a picture and the lens came out as normal but then the camera "turned off" with the lens still in the ready positon and a error message appeared on the...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 26, 2011 | Canon PowerShot SD770 IS / IXUS 85 Digital...
"lens error turning off camera.
If the camera was dropped it can somehow seize the lens related parts since they are mostly made from plastic. It is also possible that particles like sand grains can go between the moving parts of the lens and seize the mechanism. Either case the repair could be expensive and may not worth having it done.
Feb 24, 2011 | Canon PowerShot A495 Digital Camera
Canon Powershot A590 IS GIVING ME A "LENS ERROR, RESTART CAMERA" MESSAGE. I have restarted and the message keeps repeating.
Mine is the same model and it was giving me this same message when I tried to start it up. "LENS ERROR, RESTART CAMERA". It's probably a result of you dropping it. I research it and could'nt find the answer anywhere. I got mad and upset because I use my camera so much and it was not working for the holidays so I hit the lens of the camera on a desk, amazingly I turned it on after I hit t and it started working. I know it sounds a little crazy but give it a try! GOOD LUCK!
Nov 26, 2008 | Canon Cameras
How do you fix 'lens error restart camera' I put it in my bookbag. I guess i threw my bookbag around and now i have this "lens error, restart camera." The lens froze halfway and it's staying that way....
WE WENT TO THA BEACH AND TOOK SOME PIC AND LATER THAT DAY WHEN WE WENT TO TAKE MORE PIC IT SAID LENS ERROR RESTART CAMERA BUT WE DON'T KNOW HOW TO RESTART THE CAM
Aug 18, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1100 IS Digital Camera Logo
373 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
