Question about HP Pavilion Slimline S3123W Desktop PC - REFURBISHED
4 weeks ago my HP pavillon s3123w took more than 3 tries to start and finally it does´nt start, so CPU led is off and screen doesn´t have signal, all others components have power, keyboard, mouse, spkrs, CD-RW REC. etc
  • 1,179 Answers
My guide will help you, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Thanking you
damnor01
Posted on Nov 15, 2010
My Toshiba tecra a7 laptop does not start,when you power on led indicater blinks 10 times and goes off . It was working perfectly allright one week ago and did not use it for one week.power supply is
Back up a little bit and tell us if the screen shows anything at all. If it does not coupled with the lights that are flashing, you have a loose cpu or the cpu is bad.
Feb 05, 2015 | Toshiba Tecra A7 Series Laptop System...
For 3 weeks My Dell 4700C had difficulty starting. It took from 3-6 attempts to start. In the 3rd week the fan began to sound like a plane starting up. It would get louder and louder until I thought it...
hi have you heard any beeps when pc starts they tell you whats going on 1 beep all good and so on what ive found over the years is some times things need to be reseated turn pc off unplug try to start to drain power touch psu with hand on metal to earth then take ram out and reseat it same as batt take out try to start with no pwer to drain board again but in go in to bios change any setting like which hard drive you want to start first tell me how that goes cheers mate ps i never heard of cpu being limited by ram its you motherboard and os system which deside how much ram you pc can handle 32bit can read 4 gigs 64 bit over 12gigs
Oct 17, 2009 | Dell Dimension 4700 PC Desktop
Hp s3123w ,when powered on don't boot the cpu fan runs and the blue on light is lit,, what f key is used for bios
there are different key for different model and brand of cpu but normally almost all pc is using del to enter bios setup. try to press the del key
Oct 05, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
HP Slimline Pavillion s3123w monitor going to sleep.
Sounds like the motherboard might be bad but go thru these steps.
Unseat and reseat the memory one stick at a time in each slot one at at time and turn on the computer after each stick reinsertion.
If that doesn't get the video to come back up then go ahead and unseat and reseat the CPU. Then try turning on the computer.
If that doesn't do it, make sure there is no power going to the hard drive or the dvd drive. Then try turning on the computer.
If you do all of these steps and you still have no video, then the motherboard is bad and would need to be replaced.
Aug 19, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
HP pavillon dv6000 boot troubleshooting !
First take out the battery, and run it on AC power alone , if it runs ok its the battery that has died, it you still can run the laptop with orw/o a bttery then the internal power supply has died.
Jul 12, 2009 | HP Pavilion dv6000z PC Notebook
Hp dv4000 screen turned pink now black
If its not the backlight inverter or cable. It will be the LCD screen itself. It seems the shop you took it to isn't really up on laptop repair, as this is a common issue I see often. Get on Ebay and find a screen for your model and replace it. I asure you this will fix your problem.
May 19, 2009 | HP Pavilion dv4000 Notebook
HP Slimline desktop shuts down on it own without warning
you need to take off the fan to the cpu and blow out all the dust and dirt. removing the cover for better cooling is actually a bad thing to do.... with the cover on the fans will move air thru the computer to cool it... with no cover the air does not circulate for best cooling.
Robert
Please take a moment to rate this solution thanks
Apr 21, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
2007 FORD SPORTS TRAC BATTERY KEEPS DYING
180 milli-amps is way to much draw,ford's limit is 50 milli-amps but typically we usually only see around 20-30. Now when you say fuse 2 is that in the under-hood fuse panel or the interior fuse panel? And if this vehicle is a 2007 it may still be under factory warranty which was 36 months or 36000 miles providing that the add on automatic starter is not causing your draw.Which in that case the people who installed it should be responsible for that.
Mar 05, 2009 | 2007 Ford Explorer Sport Trac
No power!!!
Dear javier4017,
> First ensure that any beep is coming or not
> check numlock LED status glowing or not.
> If numlock LED glowing it means cpu working fine
only problems with monitor
>If numlock LED not glowing its mean problems with cpu
> if problems with CPU Find check RAM may have dusting problems.
Dec 07, 2007 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
97 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
