Question about Sony Walkman WM-D6C Personal Cassette Player
I would like to make this work again.I have cleaned the rollers with alcohol. When playing a tape the sound starts to warble as the speed varies, then the speed slows and it stops. It is plugged in. Is it the motors, the electronics, or just the age of the components? Is there any remedy?
    Problem Solver:
  • 15 Answers
Il rimedio c'?, ma dovrei esaminarlo personalmente. La mia email " doctor.walkman@gmail.com " The remedy is there, but I consider it personally. My email "doctor.walkman @ gmail.com"
Posted on Dec 15, 2010
CT-W103 play back is to fast
You may have some broken tape wrapped around the capstan. The capstan is the small silver post that rotates when the tape is playing. A rubber roller presses the tape against the capstan. This silver post needs to be just that - silver. If it has any brown tape or goop on it, clean off the tape or goop with a small knife. Then follow up with nail polish remover [acetone]. Don't use alcohol because that will harden the rubber roller over time.
Feb 15, 2016 | Pioneer CT-W103 Single Cassette Deck
Why is audio warbled and seems slow?
Belt slippage or excessive friction in drive. Roll up sleeves and check it out.
Feb 12, 2016 | Sony CASSETTE DECK Single Dual Cassette...
After belt replacement and head cleaning it sounds like a warbled and slow running tape deck
Belts are not the only things needed as this question points out. The capstan bearing needs oil, the motor bearings need oil, the Pinch Roller pressure needs to be right and the pinch roller clean. Capstan shaft has to have some grip and can not be glazed when it is suppose to be matte surface to start. What is the model number?
Feb 12, 2016 | Audio Players & Recorders
TAPE MECHANISM WON'T ROLL THE TAPE, IN EITHER RECORD OR PLAYBACK
Problem with the tape transport mechanism; could be the rollers are not contacting the tape itself or it could be the springs in the transport. Sounds like an older model. Could clean the rollers with alcohol and swap and if you can open it a like observe what happens with the rollers when you place in playback. These are rather delicately adjusted machines. I would again 1) try cleaning as best you can and very light oil in moving joints/gears aferward. 2) check adjustment of springs when moving from stop to playback. Once you have that whipped the record mecanism may start working as well.
Apr 02, 2012 | RCA CC4393 VHS Analog Camcorder
Will not reverse play on deck 2-just goes very fast on this
This condition, regardless of which way the tape is moving, is caused by the failure of a rubber pinch-roller to trap the tape between capstan and the passive roller.The speed is then caused by the part of the drive driven by a small belt and a clutch that should only keep a small amount of tension on the tape in ensure clean rewinding of the tape after it has passed the head.
Lubricant in part of the transport's moving parts or a dried-out rubber roller may be causing this.If you want to try to clean the pinch roller, don't use alcohol since this can further harden the robber.Use a clean fiber-free cloth or paper towel wetted with a LITTLE naphtha and turn the roller on the wetted area. If you get some dark smudging, the treatment is working.
Nov 23, 2011 | Sony TC-WE475 Single Cassette Deck
My Panasonic RR-930 transcriber speeds up and slows down as I play back tapes. The problem seems to be with the machine itself and not the foot pedal or the tapes. Where do I start?
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
Feb 02, 2011 | Panasonic RR-930 Desktop Cassette...
The tape plays songs so fast sounds like donald duck. The speed the tape is feeding is to fast.
Hi, the casette deck has a mechanical system (servo-driver) most of the problems that happen when in your case, plays song so fast is that you look at the pinch roller. The pinch roller is a rubberized free spinning wheel typically used to press magnetic tape against a capstan shaft in order to create friction necessary to drive the tape along the magnetic heads with a normal tape speed if the pinch roller brakes, get lost from his place or got dirty then you get this fast sounds play, check the pinch roller if still good in his place or clean his rubber with alcohol, then the problem should be fixed.
Jan 29, 2011 | Sony CD Radio Cassette Boombox, CFD-E90...
Wr565 - both decks jam the tape when i play them. any suggestions?
rss13506,
I'm not sure what you mean by jam but I bet you need to clean the head, roller and pin in each deck. Use rubbing alcohol and a q-tip to clean the:
1) Head (silver thing in the center bottom where the tape slides over; it produces the sound).
2) Roller (black wheel thing that keeps tension on the tape).
3) Pin (above the roller-works with the roller).
If any of these parts are dirty the deck will eat up the tapes. Clean them even if you do not see visible dirt on the q-tip as dust does not show as well as oils in the air typically from cooking will gum up the parts. Give them ample time to dry before trying a tape.
As any tape playing person knows from the 70's and 80's-try a tape you don't care about first, to make sure the deck will not eat up the ones you like!
-Chris
Sep 06, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Tape speed distorts and slows
motor belts are cheap. try replacing the belt that drives the wheel. this become distorted specially when the unit has not been use for quit long time. if you think its not about belt, clean up the rubber that touches the tape when played, also the tape head with 70% alcohol. hope this help.
Mar 24, 2009 | Sony Walkman WM-FX290 Personal Cassette...
I have a Panasonic TV witch is a combination Video and TV set. I am having a problem with the sound on my tape playbacks. I have tried cleaning the head, changing tapes and nothing is working. There is no...
Is this a HiFi stereo vcr? When you cleaned the heads, did you only do the heads on the rotating cylinder or only the fixed tracking/audio heads between the cylinder and the pich roller?
Does a prerecorded tape ( not a self recorded from that machine play ok?
HiFi vcrs default to the audio head(s) on the tracking/audio head if the HiFi heads on the rotating cylinder are dirty or damaged.
If a prerecorded tap palys fine, then the erase head circuit has failed.
If sound is weak and warbles, worse on SLP than SP, a weak VCR power supply.
Nov 06, 2008 | Televison & Video
Sony Walkman WM-D6C Personal Cassette Player Logo
168 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
