Question about Philips GEMINI XG-2001 Fan CooledBridgeable Power Amplifier Car Audio Amplifier
Mi power gemini xg-2001 tiene el problema que cuando conecto cuatro bocinas en paralelo suena como una emisora y se dispara
3 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
josema_sv
  • 485 Answers
SOURCE: hola el problema es que
Hola, el procedimiento sujerido del fabricante en este caso es el siguiente:
  1. Retire y vuelva a colocar las baterias
    del terminal.
  2. Intentelo de nuevo desconectando la
    alimentacion de la base y volviendola a
    conectar y siga el procedimiento de
    registro de un telefono.
Registro de un auricular.
  1. Inserte la bateria para encender el
    auricular. En la pantalla LCD
    aparecera "PULS TECLA OK
    PARA REGISTAR".
  2. Pulse pantalla LCD aparecera "PULSE
    PAGE DURANTE 5 SEGS".
    Antes de que transcurran cinco
    minutos, pulse la tecla de
    localizacion (PAGE) que se encuentra en la
    estacion base para iniciar el proceso
    de registro.
  3. Si el registro se realiza con exito, el
    auricular volvera al modo en espera.
    Si el registro no se realiza
    correctamente, en la pantalla LCD
    aparecera "PULS TECLA OK PARA
    REGISTAR". Repita el proceso de
    nuevo.
Posted on Feb 28, 2011
Compr? un Radio Kenwood KDC-X300,cuando programo la hora,la fecha,dem?s funciones,apago mi carro,lo vuelvo a prender,el radio aparece en standby┬┐?lguien de ustedes me podr?a dar una respuesta?
Mi Espa?ol no es my biene ,perdone. Suena Como que lo tiene connectado all ignition solamented. Se nececita conectar el alambre de Acc. A la batteria directamente Para que Guarde la memeoria . Ay beses que se Idica el alabre en question con color azul. Hope it helps Buena suerte,
May 16, 2016 | Cars & Trucks
Prende el motor
tengo problemas con un bmw 2008 528i se prende en el tablero la figura de la maquina y una como herradurita y no prende que es puede ser la bateria aunque tiene luces
Jan 08, 2014 | Kia Cars & Trucks
Hola no hablo bien ingles solo quiero preguntar mi montana se calento, revize el deposito del antifrez y esta lleno las mangeras estan muy duras como con mucha precion que podria ser
probablemente wl problema que tienes es un mal termostato. Cambialo porque parece haberse quedado pegado en la pocision de cerrado haciendo que se caliente tu carro y que las mangueras se pongan duras debido a la alta presion de coolant super caliente. Un cambio de termostato arreglara tu problema.
No olvides dejar tu commentario y votar por mi ..esto me ayudara y puedo segui ayudando a gente como tu y especialmente de habla hispana. Gracias
Mar 07, 2011 | 2001 Pontiac Montana
Cuando instalo el software del cd que incorpora el paquete que compre funciona todo menos l multimedia y no se como solucionarlo
Suena como que usted está diciendo que ha perdido el CD de instalación de una pieza de software.
Si este es su problema, por favor diga qué software se necesita el CD para
Lo siento si esto no tiene sentido. estoy usando traductor Google:)
Aug 13, 2010 | Computers & Internet
Abri mi terminal Verifon vx510 para darle mantenimiento pero cuando la volvi a cerrar solo parpadea la pantalla, creo que se activo el tamper como lo desbloqueo o restauro, algun switch activa esto
buenas tardes lo que debes de checar son unas gomas que tiene adentro son las que activan el parpadeo o si necesitas ayuda mandame tu correo el mi es dawer_2010@hotmail.com
Jun 09, 2010 | VeriFone VX510
Tengo una camioneta isuzu y se acelera y
Hola Ruben
No estoy seguro, pero tengo un Amigo 90 que le pasa lo mismo.  Según creo el problema está en los controles electrónicos de las válvulas (esos aditamentos que están a la izquierda del carburador, segun lo ves desde el frente, sobre la salpicadera derecha del auto)
No se como se corrige el problema.  Supongo que cambiando los controles de las válvulas.  Una cosa que puedes revisar es que las mangueras que comunican el carburador con esas piezas que te menciono no tengan entradas de aire por grietas por resequedad.
Si alguien más sabe una solución mejor, espero con gusto su respuesta.
Yo quisiera cambiar el carburador por uno 100% mecánico mejor
Oct 03, 2009 | 1993 Isuzu Amigo
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
NECESITO CONFIGURAR MI CAMARA EN LA COMPUTADORA Y NO PUEDO....
pero tienes el cd?, de todas maneras yo estaba de vacaciones y deje el cd en mi casa, pero conecte la camara al computador de un amigo y las vaje de una vez, sin habere instalado el software(CD), luego cuando llegue aqui a mi casa instale el cd y el programa se llama arcsfot photoimpresion 6, despues tuve problemas para ver el video que habia hecho, pero tuve instalar quicktime, bueno si alguien puede dar mas informacion, a mi me gustaria saber mucho mas de la camara, porque me aparecen iconos como un avioncito, una rueda, tambien tome una foto y tiene sonido, si alguien sabe todas las funciones que no estan en el manual mi correo es indytu@hotmail.com clocas ref.camara
gracias
indira
Jan 12, 2009 | General Electric A835 Digital Camera
Problema para escuchar una emisora a traves de internet
Hi
I have tried the link you have provided, this works correctly on my own computer using Microsoft's Media Player 11 running on my own XP system.
the following link is for the microsoft web site it gives you the opportunity to download the latest media player version for your operating system.
http://www.microsoft.com/windows/windowsmedia/download/AllDownloads.aspx?displang=en&qstechnology=
hope this helps.
Hola
He probado el lazo que usted ha proporcionado, esto trabaja correctamente en mi propia computadora que utiliza Jugador de los Medios de Microsoft 11 correr en mi propio sistema de XP.
El lazo siguiente es para el sitio web de Microsoft que lo da usted la oportunidad de descargar al último jugador de medios que el lazo siguiente es para el sitio web de Microsoft que lo da usted la oportunidad de descargar la última versión de jugador de medios para su sistema operativo Vista no es incluida aunque.
Espere que esto ayude.
Nov 11, 2008 | Microsoft Computers & Internet
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
Philips GEMINI XG-2001 Fan CooledBridgeable Power Amplifier Car Audio Amplifier Logo
115 people viewed this question
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Matthew Spark
Matthew Spark
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
