Question about Milwaukee Tool Case Heat Gun
I have a case 90xt skid steer that has locked up all hydralics forward reverse up down etc engine will run but light on panel is a gear with oil dot in center with arrow each side
    Top Expert:
  • Milwaukee Tool Master
  • 51,154 Answers
Check the drive coupling to the main oil pump at the engine as it may be broken
Posted on Nov 10, 2013
4 Suggested Answers
SOURCE: need a service manual for a Case 40xt Skid Steer
put desil in hydraulic resevior
Posted on Jul 29, 2010
SOURCE: need manual for case 1845C skid steer
Case1845c.com
Posted on May 28, 2010
SOURCE: Case 410 Uni Skid Steer Loader Service Repair
Hi, I have a 2005 Case 410 that has 391 hours on it just had the oil and air filters changed 10 hours ago. While using the skid steer it suddenly shut down on me and wont start when I turn the key the hour meter reads ACC. I checked the voltage on the battery checked out at 13 volts coming out, and tried jump, no go. Checked the oil which was at a right level and seemed fine. Cane anybody help me thanks, email me at johnjayb@hotmail.com Thanks
Posted on Nov 28, 2010
I just bought a 1997 bobcat 753 skid steer. It runs great for about 20 mins then motor bogs down then completely shuts down. Its like i turned it off. After about 10 mins it will restart run for another...
I recently tried
the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers wiring, codes, diagrams, torque specs, PCV, everything
got it from www.reliable-store.com
Feb 26, 2018 | Cars & Trucks
I have a 345 OMC mustang skid steer. deutz 2cyl diesel engine it is leaking hyd oil from under bottom of machine not on rims or tires what could be leaking
Not a CAR...
Skid Steers... like yours: we call bob-cats here (USA)...
EASIEST & most common are cracked & loose hoses.
You have a serious hydraulic pump & piston system on all the configurations I've been able to pull.
Any damaged SEAL EVERYWHERE in that circuit
is going to be hydraulic oil...
Crank-case, transmission case... (etc.).
What you are going to have to do is pressure clean the wettest areas... wipe them down... and make your EYES & BRAIN take a look around for the most severe leak...
Fix it... and repeat the process until you
have things nice, tight and dry...
Carnac the Magnificent
Jan 21, 2017 | Cars & Trucks
How do I adjust creating on 1845c case skid steer
Cat® Skid Steer Loader ' Drive Chain Adjustment ... - YouTube
? 1:39
https://www.youtube.com/watch?v=FUtx88JifxY
Sep 27, 2011 - Uploaded by Cat® Products
Cat® Skid Steer Loader ' Drive Chain Adjustment & Chain Oil. Cat® Products ... Crane picking a skid steer out of a building. Unsafe - Duration: ...
How to change a drive chain on a case 90 XT - YouTube
? 2:27
https://www.youtube.com/watch?v=WBWVSpgZkKQ
Dec 27, 2014 - Uploaded by rayray haque
I made this video because I recently had to fix the drive chain on my skid steer. But there were no easily ...
Case 1845C Chain adjustment question - Heavy Equipment Forums
www.heavyequipmentforums.com/showthread.php?...Case-1845C...adju...
Mar 6, 2012 - 15 posts - ‎5 authors
I noticed it was making a popping noise in the front left wheel, so I. ... It appears that this skid steer is pretty much indestructible if taken care of ... Case 1845c Skid Steer Problem - Heavy Equipment Forums
Apr 21, 2013
Case 1845C Uneven speed while travelling
Nov 24, 2012
1845c what things go bad - Heavy Equipment Forums
Jun 9, 2009
1845C Fan belt change question - Heavy Equipment ...
Apr 9, 2009
More results from www.heavyequipmentforums.com
Dec 28, 2015 | Cars & Trucks
I changed hydralic filter now I have no hydralics--HELP-- thanks colljim3@aol.com
you have air in the hydrolics ceck oil level add to it
Oct 16, 2014 | Garden
Have a 95 suzuki sidekick had some work done on the wireing around fuel injectors now my engine light is on and it wont shift out of first gear.please help no money left
this should be a simple solution rock your vehicle forward then reverse on running engine
they call this trans lock usually happens on hills or pressing down the shifting knob
get a few friends to help push forward if cant start vehicle because in gear its like the old 4x4 hubs in order to get out of lock it needs to be rolled a little
my little 4x4 did same thing called a friend he told me same way to fix
Nov 09, 2013 | Cars & Trucks
Car is making a high pitched whining noise and does not shift, checked the fluid and it is ok ... help
HIGH PITCH WHINNING NOISE IS FAULTY TRANSMISSION OIL PUMP.HAVE THE TRANSMISSION FLUID PRESSURE CHECK AT A TRANSMISSION SHOP.IF TRANSMISSION OIL PUMP TOO WEAK OR MALFUNCTION.YOUR TRANSMISSION WONT HAVE ENOUGH OIL PRESSURE FOR FORWARD GEAR , REVERSE GEAR, BAND OR SHIFT VALVES IN VALVE BODY.NOTHING WILL WORK TRANSMISSION.OIL PUMP LIKE HYDRALIC PUMP KEEPS EVERY THING WORKING..
Jul 12, 2011 | 2001 Oldsmobile Intrigue
Sometimes when putting it into park, the steering wheel will not lock properly, the key will not turn off position and the wheel doesn't lock. The key is then left in the on position with the engine off,...
check the swith on the floor may cause the troubel. Ohm it vild jusing it to se its function.ther also can be som swiths whit the gir column newtral rev. etc. check all.
Dec 04, 2009 | 2003 Pontiac Aztek
1993 explorer goes in forward fine will not go in reverse
reverse clutches are burned up, repair or replace tranny.
Nov 06, 2009 | 1993 Ford Explorer Limited
Hyundai excel 1996 automatic will engage reverse and park but no forward gears. Gearbox was overhauled 3 years ago, new seals etc. Oil level in the main transmission is ok and no apparent leaks. Problem...
It appears you have a Forward Clutch FAILURE. Replace the trans after you get it diagnosed and verified by a professional technician. By the way, do you have a Check Engine light? If so, what is the diagnostic code? The dealership can scan the system and find any codes which may have been stored in the TCM (Transmission Control Module). If there were any 'Incorrect Gear Ratio" codes, it's most probably the trans itself.
May 16, 2009 | 1994 Hyundai Excel
Milwaukee Tool Case Heat Gun Logo
1,852 people viewed this question
Top Milwaukee Tool Air Tools & Compressors Experts
John Trevino
Geert Deschamps
Are you a Milwaukee Tool Air Tool and Compressor Expert? Answer questions, earn points and help others
