Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony bravia screen turns green when you change channel
  • 8 Answers
SOURCE: no picture or menu
If your dealer has not already told you, I suggest you unplug the unit from the wall and let it sit for 30-45min. Plug it back in and hope...
Posted on May 04, 2007
  • 231 Answers
SOURCE: Pink and Green on Non HD Stations
what is model of unit?
Posted on Nov 30, 2007
circuitworld
  • 335 Answers
SOURCE: A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Posted on Nov 09, 2009
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
SOURCE: my sony bravia screen turned
When the color of the screen is complete green, you should not worry. That is the normal color that should be on the screen when no program is coming in because the cable box is off. So simply press OK on the remote of your digital box and your will see picture on your TV. If none appeared, then there is problem on your cable box. Call then your service provider.
Posted on Dec 05, 2010
MY tv that goes straight to the screensaver mode like it would on pc. sony bravia kdl32nl140 is the tv.
J, it sounds like it may not be getting any input from cable or satellite, try switching cable and inputs around, try VCR or DVD player. You may need a firmware or software update.
Some forums say to unplug and wait 10 min. then it resets.
Check links below.
Sony eSupport KDL 32NL140 Support
Stuck with initial setup screens on my Sony Bravia 4k Android TV
Feb 21, 2016 | Televison & Video
My Sony Bravia picture turns green.
check cable, if its using an HDMI, replace it: if component RGB cable, reseat or replace.
Oct 03, 2015 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
I got a sony bravia kdl46nx800 led tv and for some reason, there is a green line on the right edge of the screen on certain HD channels and not on regular channels when i watch the shows. it is a common...
Hi, I can't say I've ever seen that happen with that TV before so I'd say it definitely isn't common. I'm pretty sure it's the signal from the HD channels, I'd suggest talking to your cable service provider.
May 14, 2011 | Sony BRAVIA NX800 KDL46NX800 46 in. HDTV
My Sony Bravia tv screen turns green on occassion when changing channels. You can still hear the sound on the channel but can't see the picture only a green screen. My tv is hooked to a digital cable box...
If you haven't done so already, check that the cable between your tv and digital cable box(probably HDMI) is secure at both ends. If it is, try a different cable and/or different port on your tv if you have more than one. If the issue is still there after you've tried these options it's most likely an issue with either the digital box or tv. I would contact manufacturer at this stage for advise and possible replacement of tv or box if they are under warranty.
Hope this helps.
Dec 30, 2017 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
if the line is in the same place all the time im afraid to say that is a pixel problem on your display contact sony they may offer you a replacement display or altleast a way of changing the set.
Mar 10, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Feb 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony 37" Flat Panel Bravia--cant change from channel 2?
On the original Sony remote control, try typing in a channel manually. Try pressing the numbers "0-4" or "0-5," and waiting for a moment. If the channel changes, then the TV needs to be autoprogrammed. Using the SOny remote control, go into the MENU (or HOME on some Sony remotes), and look for the initial setup screen. It will walk you through the process. The process is also in the original users manual, available on the www.SONY.com website.
Hope this helps you....
Jan 05, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
I have a Sony Bravia KDL-32v2500, 16 months old, a thin vertical green line has appeared just off centre. It is on all channels and all input sources. Any suggestions?
If it still under warranty, no cost will be there, but if its out of warranty, you have to pay to Sony (might be they give you some discount) because its problem in LCD Panel.
Aug 05, 2008 | Televison & Video
Channel information stays on screen for av channels
there should be a info button or display button on remote to turn on and off, unless it is coming from the box that is connected to tv
Jun 02, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
244 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
