Question about Samsung HP-T4254 42 in. Plasma Television
I have this Samsung but theres a wash and dryer behind the tv in another room. theres a annoying buzzing sound and theres lines going across the tv when the washer machine is on. what can I do to reduce noise or static?
  • 417 Answers
you can try using a good quality surge strip on the tv. if that doesent do it you could try a different outlet on the other side of the room, or try using an outlet from a different room(long extension cord) if that doesent do it you may have to move the tv to another wall.
jm
Posted on Nov 15, 2010
How do I stop the buzzing noise when in heating cycle?
BAD IDEA THERE IS A REASON IT IS BUZZING? FIND THAT OUT FIRST
Apr 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Hi, I Purchased an LG 50PK350 plasma tv and I am experiencing an extremely loud, annoying buzzing sound even with the amp switched off & the sound muted. The buzzing is not constant ... the brighter...
I have this tv aswell, and yes I will confirm that it does buzz quite alot, but all plasma tvs do, it is to do with how it renders images, the buzzing can be made worse by it being close to a wall and it reflecting back. I found that my tv stand some how amplified the buzzing when i got mine. I dont think its something you can escape.
Mine i notice also when scrolling around menus seems to have lines that follow your selection....not to pleased about that
Oct 18, 2010 | Televison & Video
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung LCD suffering from faint white lines scrolling, and buzz
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 22, 2017 | Samsung LN-S3251D 32 in. LCD HDTV
Buzzing sound then dead
Most likely power supply is dead,but there is a small chance that the power cord has been burnt out.If your TV is wall mounted or left very little room behind the tv to allow it to"breath",that could happen.
So,stop by Fry's to get a power cord and replace yours and see if that works or not.If not,it is time for a repairman to do his/her work.You are right,it is not cheap.
Next brand:New Pioneer KURO plasma tv,case closed!Reliable,and top of the line.
solutiondoct
Jun 15, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Plazma TV buzzing noise
I have the same problem I can hear buzzing over the volume of the tv into the 30 range. I've had a tech out 3 times and he's coming out for a fourth. He's changed to power supplies and is bringing the 3rd next visit. From what I've read it has either to do with power supplies or grounding strips.
Jan 18, 2008 | Televison & Video
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-T4254 42 in. Plasma Television Logo
99 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
