Add ram - Computers & Internet
  • 191 Answers
Info required regarding your computer
make and model number.
Posted on Jun 19, 2008
Memory upgrade 2gb 4gb
The CF29 comes in two basic flavors:
#1: With 256MB RAM and DDR Ram with One open slot.
So add a 1GB DDR RAM (PC-2700) DDR 333 and
the maximum RAM is now 1.2GB
#2: With 512MB RAM and DDR2 Ram with One open slot.
So add a 1GB DDR2 RAM (PC2-5300) and the
maximum RAM is now 1.5GB.
This is my experience and very frustrating to find out the
hard way that the CF29 does not support a 2GB DDR2
RAM Module.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Jun 05, 2013 | Panasonic Toughbook CF-29 Notebook
Does ASUS P5GC-MX/1333 Motherboard supports DDR2 800mhz ram.?i'am havin 1gb ddr2 667mhz ram and i want to add 2gb 800mhz ram to it
Hello Tarun - No it doesn't. It would run OK but you would not gain any performance as the ram will only run at the same 667 MHz.
The limitation of RAM speed is dictated by the specs of the Intel 945 Chipset the motherboard is based on. But certainly add more ram, especially if your running Windows Vista or Windows 7 which both need at least two GB of RAM to perform well.
Happy upgrading and thanks for using Fix Ya.
Mikeywaf
Mar 21, 2011 | ASUS P5GC-MX/1333 Motherboard
I think i need to add ram to my toshiba satellite laptop and i do not know how to figure out what to buy.
if u think to add ram on your laptop then frist cahck your laptop is there amty slote on ram place
u can chack back site of your laptop
cahck what ram your laptop is supporting after that same type of ram u can add.
Apr 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
Add more ram
hi-
To add ram - look on the back of the lap top. You will see some screws that are holding down a little door. There may be two of these. Remove the screws on the ram cover and remove ram cover
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ram slots are stacked. you have to remove the top one first.
1- press the buttons on the sides of the ram chip, and then it will pop up and towards you.
2- 2- pull this ram upwards and out
3- from there, you can take out the other chip, if there is one, or you can start installing.
4- installing the new ram chips is just as easy
5- line up the slots in the chip, then push it in as far as you can without breaking it.
6- then push it down so that you hear it click on both sides, and doesn't budge.
7- Repeat using the top chip.
This should do it –
I hope it helps- please rate me – thanks
G
Mar 18, 2010 | Acer Aspire 9500 Notebook
I have intel 845 glly desktop board with 256 mb SDR. When I added 128 mb SDR in the second slot it is not recognising it. How to add 128 mb SDR with 256 mb SDR. When I fix 128 mb ram in first slot and...
1st try to exchange the cards in the slot.
2nd try another card
3rd ur RAM slot may not be ok
4th ur RAMs may not be compatible
5th ur new RAM card may not be ok
use same type of RAMs, and same size...
if u have 256, add 256
if u ahve 128 add 128
if u have SDR then dont add DDR
getting compatibility is little difficult...
some times no combinations can work...
note...technology keeps changing...so a old RAM card that was bought years ago may not be compatible with a new RAM card....
even i got all my old RAM cards(256+128) removed and got 2 - 512mb of the same type fixed...even i had issues with my RAMs for 6 months...
Dec 27, 2009 | Intel D845GLLY Motherboard
I want to add 1Gig Ram to istalled 512 Mb of Ram,Can I do this? NEC VERSA M160. Memory type DDR 533 Mhz PC2-400 200 pinSODIMM
Yes, of course you can do this with your own. The first things you should do are they:
You need to buy 1gb RAM which same socket to your old 512mb RAM. Be sure that the said RAM are compatible to your motherboard.
Dec 02, 2009 | Computers & Internet
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
I canot add another ram with the exist one
Try to use only the new one. if it works, then try combination of slots using two rams. And..1024MB, not KB ;) thanks
Apr 04, 2009 | Biostar Computers & Internet
Ram coflict with graphic card
look at mhz on ram make sure it is the right mhz pc 2100,pc3200,pc2800 and so on some Bran's are not compatible with motherboard
Jan 11, 2009 | MSI KT4V (MS-6712) Motherboard
Need to add ram
its depend that upon your RAM slots. If RAM slot is two then its means you can add only 2 RAM.
Jan 02, 2009 | HP Compaq Presario V6000T Notebook
Computers & Internet Logo
David Payne
David Payne
