Question about Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230
Which way do you turn the impeller to remove ir from the shaft. The part # is 310-4190. Thanks!
  • 760 Answers
Counter clockwise looking at the impeller end. If you can't hold the motor shaft, you might try an impact wrench or using a socket and ratchet sharply strike the wrench.
Posted on Nov 15, 2010
How do I lock the shaft so that I can remove the impeller?
remove the cap at the rear of the motor. you'll see the shaft under the thermal overload. Take a 7/16 or 1/12 wrench depending on shaft size, turn the impeller until you see the slot for the wrench. you may have to remove the starting compassitor to make some more room. Hold your wrench with one hand and remove the impeller. ***some impellers have a lock screw in the middle of them, if you have one it is left handed threads, this must be removed before the impeller can be removed.
Aug 27, 2013 | U.S. Motors Emerson EB848
I have a Pentair 2.0 pump that I am trying to remove from the impellar. The shaft turns allowing me to turn the pump part itself but I can not pull it loose from the rest of the housing. How exactly do I...
The impeller is threaded onto the motor shaft. On 2hp motors and above, there is usually a screw with reverse threads to help secure impeller to shaft. To remove impeller, first remove screw(reverse threads) Next, remove back cover off motor. The shaft either has a slot for a screwdriver or flats for a wrench. Hold shaft and unscrew impeller.
Aug 21, 2011 | Pentair One - Speed 1hp 115v Dynamo Pump...
Hi, I have a QC 1072 A.O. Smith pool pump motor. How to get the impeller off? Which direction does the impeller spin off? Where to but impeller and seal? Thank you very much Greg
The impeller is just screwed on the shaft. COUNTERCLOCKWISE to remove. Some have a screw in the center attaching it to shaft. This is removed by by turning CLOCKWISE.(reverse threads) Remove back cover and secure shaft with a wrench. There are flats on the shaft to hold it. You might need a large pipe wrench to loosen impeller. Wrap with rag so you don't damage impeller.
May 18, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
How to remove impeller seal
Remove v-clamp from wet end.
Remove diffuser from wet-end using a flat blade screwdriver.
Remove impeller screw by turning clock-wise(this is a reverse threaded screw (some impellers dont have an impeller screw))
Remove back end of motor using a 1/4" hex driver.
Secure rear end of motor shaft by slipping a 7/16" open face wrench into rear electrical compartment
While securing the shaft, turn the impeller counter clockwise until its off.
Remove seal halfs and replace with identical seal.
Reverse to finish the install
Mar 23, 2011 | Sta Rite Tune Up Kit Dyn Glas Dyna Max...
I have a US!1102 AO Smith 1HP Pool Pump Motor. I was told to hold one end of the motor shaft and turn the Impeller clockwise to remove the impeller, I was told NOT to remove the nut at the center of the...
I have never taken this pump apart.
If I were in your position and I could move the impellar 1/8 turn, the next thing that I would do is carefully loosen the nut on the end of the shaft being careful that nothing else disassembles. Once this nut is loose say 2 turns, try the impellar again watching what is moving. It seems that the nut may have to be removed.
Also, I'm not sure which way the nut of the impellar rotates to remove, but you seem to have that under control since you have it moving already.
Gary
Feb 20, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
How to seperate pump from motor
Disconnect all power. Remove the six bolts holding the seal plate to the wet end. Remove the two small allen screws to remove the diffuser. Remove the dust cap from the end of the motor and secure the shaft from moving. If installed, remove the Phillips head screw in the center of the impeller by turning clockwise (left hand threads). You can now remove the impeller by turning counter clockwise, note that you may need an impeller wrench to remove it and a specific tool to hold the shaft while you remove the impeller. Once the impeller is off you can remove the four bolts that hold the motor to the seal plate. This process just needs to be reversed to re-install but you will need a new shaft seal (PS-1000).
Jun 30, 2010 | Pentair 1 hp WhisperFlo InGround Pool Pump...
REMOVE IMPELLER FROM SHAFT A O SMITH PUMP MOTOR HIFLO
The impeller is threaded onto the motor shaft, take the back cover off and use a wrench to hold the motor shaft, then turn the impeller counter clockwise to remove.
Mar 15, 2010 | Plumbing
We are having issues getting the impeller apart on the jacuzzi magnum force pool pump and need some instructions on how to proceed.
I believe the jacuzzi pump impeller has a locking screw directly in the middle of the impeller. You'll have to turn it clockwise to remove it. Then you'll need to remove the cover from the back of the motor using a 1/4" nut driver. Depending on the motor, you should be able to use a 7/16" open end wrench to hold the motor shaft from turning as you turn the impeller counter-clockwise to remove it. Some motors are different, some have a keyed shaft or require a special tool to hold the shaft while the impeller is removed. Hope this helps.
Nov 22, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Waterway 5 Hp 230 Volt 2 Speed Side Discharge Spa / Hot Tub Pump 2" Plumbing # S50230 Logo
172 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Mike
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
