Question about Radio Communications
I hooked everything up the way it said but i get nothing on every channel....also when i drive i here a lot of feed-back
    Guru:
  • 773 Answers
Im not sure feed back is the correct description. You can only have feedback when you transmit. I think you are talking about interference from the car.
First lets address the issue of hearing nothing....
  • Make sure the coax is tightly screwed onto the back of the radio.
  • Depending on the type of antenna, for fiberglass antenna, make sure its grounded properly, for mag mount, make sure there is nothing wrong with the mebrane on the bottom of the magnet, and that you haven't put anything in between the magnet and the car.
  • Make sure the mic is plugged in. You will have no receive if there is an issue with the mic.
  • Make sure you have tuned your antenna. This is important. If you don't you will ruin your radio.
As for the interference. Some times devices in a car can cause interference to the radio. Here are some ways to battle that.
  • Make sure ANL is turned on. This is the Automatic Noise Limiter.
  • If you have the power wire connect into the fuse box, try running it straight off the battery.
  • If that does not stop the interference, then got to a truck stop, and get a power wire noise filter.
Also, I am including information on tuning your antenna below.
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Posted on Nov 18, 2010
My dvr 16sb started producing a dreadful signal now after buying new cables etc and re installing the channels I have no signal at all. I have reverted back to my old cables and back again but still...
Go back and do ONE channel. disconnect everything else and just try hooking up ONE channel. when you find what you may have done wrong, then fix them all. A Bad Camera Power supply will cause your original issue,
Oct 26, 2013 | Televison & Video
How to set up a spalding uv Tex 5 tent
First set the 3 eleven piece poles with 2 crossed across the tent and one across the front portion. Feed them thru the channels and buckles. Then put the pin hooks into the bottom of the poles. You will need to arc the poles to get the pins into the end of the pole. Next put the poles that are smaller into the channels and buckles for the two vestibules. Again put the pin hooks into the same pole ends as the back crossed one.
Stake the tent to the ground by driving the stakes thru the pin rings starting at the 6 corners of the tent. Pull front of vestibule taut and secure in place by driving stakes thru webbing loops at base.
Install the rainfly by draping it over the top of the tent. Hook each of the 8 S hooks onto the provided loops. Secure the rainfly to the poles by wrapping the velcro straps around the poles underneath the rainfly.
These instructions should be in the pocket on the wall in the main section of the tent in the pocket with red writing.
Jul 03, 2011 | Rock & Ice Climbing
I have everything hooked up just as the schematics say and have sound from my front speakers but nothing from the back 6x9's or the subs?
well let me start by saying your trying to power way to much on this little amp you should be using a 5 channel if you wanna do all that try just hooking up the front speakers and 6x9s
Mar 28, 2010 | Rockford Fosgate Punch 201S Car Audio...
Received used Olevia 226-s11 hdtv, hook-up up (no
I need to go to Menu, Picture, Mode, Home.....
The default setting for the TV was Showroom which wouldn't let the cable signal through. Thanks for trying to help.
Jan 12, 2010 | Televison & Video
I have a starting problem
Check you put the vacuum tube back on and its not leaking. this operates the fuel feed.
Sep 05, 2009 | 2008 Suzuki GSX-R 600
Ribbon installition
Is it ide or sata drives you are using?
Guessing ide as sat have no jumper but best to check :)
Sett all the 3 drives jumpers to "cable select" and then just make sure you hard drive is in the master ide channel and on the end of the cable.
Jan 04, 2008 | Computers & Internet
Ilo 42" plasma tv
Go the the settings on the cable box. look for output resolution, then change it to 1080i and 720p. now turn the box off and back on your tv will now display the input of wither 1080i or 720p depending on the hd channel your watching.
Dec 26, 2007 | Televison & Video
Tv troubleshooting
your keyboard is most likley bad..or tv  buttons/switch...
Oct 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Radio Communications Logo
42 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
