Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer Banging During Spin Cycle
Whirlpool Duet Sport Washer 19 months old. Model WFW8300SW00
Started banging during spin cycle.   At first I thought that it was just an unbalanced load.
But on close inspection I discovered if I rotated the drum so that one at a time, each of the three segments at the back of the drum pointed down. One was loose.
For each attachment point, pull forward at the front of the drum  One position is loose and pulls forward making the banging sound when it drops back. The other two points do not pull forward and  appear firmly attached.
The result is that for every rotation of the drum one attachment point at the back of the drum swings out a bit then bangs back as gravity pulls it in when it is at bottom.
My guess is that the Cross piece assemble part 27 appears not to be attached to the drum with part 26 on
one of the three attachment points.  Not sure about this.
All I have found is a parts schematic I have no service manual.
Perhaps somebody can give me a better answer
since this repair looks like a complete disassembly
if my assumptions are correct.
It sounds like a couple of the other postings in this
list may also be a similar problem.
Any suggestions are most welcome.
Thank you.
  • Anonymous Dec 27, 2008
    I have a similar problem. My drum bangs against the door and I actually see sparks from the friction. It is really scary. It actually brole my handle and locking mechanism. I had a repair guy out and said my drum seemed balanced and ok. After he left the same thing happened and It almost broke the lock agian. I thought that this machine was suppose to hold large loads. I am not happy since I just had my washer and dryer built in to a cabinet. Any clues as to what is causing this?
  • 413 Answers
If the the drum feels loose in any way, there are three possible reasons:
1. The pulley nut has come loose. (easily repairable from the rear)
2. The bearing is bad (part of the rear tub).
3. The spinner has come loose from the basket (what you describe)
In cases 2 and 3, the entire drum/tub assembly will have to be removed, disassembled and repaired/replaced.
Check your owners manual for possible limited warranty. Contact Whirlpool for potential warranty repair concessions for case 3 if not covered under limited warranty.
Regards
reg501..The FixYa Team
Posted on Jun 19, 2008
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,066 people viewed this question
Dan Webster
Dan Webster
Sal De
