Question about Cameras
Most pictures I take are blurry, video is really good. I have tried different settings even setting back to default. and still having issues
Make sure the flash is on. That was a problem for me too.
Posted on Nov 15, 2010
Sinotec
check the antenna u may be getting poor reception,if the video is ok on dvd then the antenna is , if not the tv is faulty on its video output need a tech to check it
Jul 10, 2013 | Televison & Video
Hi. i have sony w120. its not new, i bought it cca 3 years ago. I didnt use is for a quite a while (but my family did), so few days ago, i realized when i take pictures, pictures are somehow blurry,...
Please go to Setup menu and select Initialize option to reset camera to default settings that might solve blurry picture problem, if that does not help then its technician job to adjust focus of camera.
Thanks.
Aug 02, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
My DSC-T10 Sony Digital Camera fell down and now the new pictures taken are coming Blurry (hazy). My old pictures in the memory stick shows perfect. Please advise what could have happened.
Based on the information you've provided, it seems that the Lens Mechanism of the Camera is damaged when it fell down. The Lens of the Camera is not focusing properly while capturing the images. As the issue is with the lens mechanism, the previously captured images are displaying normally. I suggest that you try resetting the Camera and check if the issue can be resolved.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Apr 01, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
I tried to download the tape to the TV but the picture is blurry. I got the DCR-HC23E as a gift from Europe and I live in Canada. I also tried to download the picture to the laptop but it looks I don't...
Sounds like a problem with the European signal trying to be viewed on an NTSC signal set. If the picture plays back fine on the camcorder and not on the tv set then its most likely the conversation loss between the 2 different video standard signals
Sep 04, 2010 | Sony DCR-HC23E DV Digital Camcorder
Blurry pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
May 03, 2009 | Olympus SP-560 UZ Digital Camera
Blurry images on camera
Also try to reset the camera back to factory settings as there may be a setting that is causing this issue to occur. To reset the camera - go to Menu - left arrow to reset - highlight Yes and press ok. This will reset the camera back to factory default settings. See if the blurriness still occurs. If it is still blurry you may want to send to Olympus for evaluation and repair service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Apr 22, 2009 | Olympus FE-340 Digital Camera
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Nikon D80-picture blurry in auto mode
jbenjack,
The D80 has a lot more settings to deal with and depending on the lens the depth of field may explain the blurry background (that is desired effect on a portrait) The view finder on the D80 is for composing the shot and has read outs for the settings. The LCD on the back is for playback and the menus, it doesn't work like a live view of what's being taken (on some newer and more expensive DSLRs it does preview on the big LCD) on smaller point & Shoot cameras that don't have a viewfinder they use the LCD as the viewfinder, does that make sense? If she has the manual you may want to faniliarize yourself with some of the features, start out on one at a time for the different modes so they make more sense, you can really appriciate the camera after that and respect what pro photographers do. The D80 is not a cheap camera and I personally know a couple of professionals that use it among their cameras. (lots of different lenses that cost many time more than the camera body) Have fun with it, and if you get into it you will find you can take some fantastic photos with it. Can you tell that I like that camera?
randy320sgi
Mar 04, 2009 | Nikon D80 Digital Camera with 18-135mm...
Blurry pictures
First try to put the camera dial on the P mode setting and then press ok - right arrow to Mode Menu - down arrow to setup tab - then right arrow to All Reset and then right arrow to make sure it is set to On. Then power the camera off and then back on. The camera should then be in factory defaulted settings. Try taking an image in P mode and seeing how it turns out. If it is still blurry you may want to call Olympus technical support to further troubleshoot your issue. Their telephone number is 888-553-4448 option 5 and then option 1.
Oct 05, 2008 | Olympus Camedia C-740 Ultra Zoom Digital...
Pictures too white and blurry
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
It's need repair camera machine shutter.
more detail casio ex-s600 overexpourse
Nov 09, 2007 | Casio Exilim EX-S600 Digital Camera
Cameras Logo
26 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
