Question about Samsung RS2630SH Side by Side Refrigerator
Fridge not cooling very good, freezer side frosting up, and ice tray not dumping properly then spills water all over.
    Brigadier General:
  • 4,044 Answers
Your best bet is to defrost the whole unit so the ice melts from the paths that go from the freezer to the refrigerator side. While you are doing this check the seal on the Door Dispenser. When you have frosting problems in these type of units it is usually the seal on the flap that opens to dispense ice through the door. It allows heat in and moisture and that in turn freezes up the inside of the unit and builds up over time and causes your other problems. Also check the door seals to make sure the sealing area is clean and dry and making a good seal between the door and the sealing areas. The Lower part of the door and the sides near the hinges are the most common problem areas. Placing Armor hammer boxes in the fridge and freezer will help a little with the moisture although that is not what they are marketed for.
Posted on Nov 15, 2010
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
How does Auto defrost work and how long does it take
Hello there
A Look at the Defrosting System:
Modern refrigeration systems, whether industrial or household, feature a defrost system. A refrigeration system works by developing temperature below the water's freezing point. Long hours of continuous operation may lead to development of a layer of frost or ice around the freezer or the evaporator coil. This hinders the cooling capacity of the evaporator, making it difficult for the cooling effect to pass into the freezer. Without refrigerator defrosting, the layer of frost or ice leads to loss of cooling and lessening of performance coefficient of the refrigerator and higher electricity costs. There are various defrosting methods that your fridge can employ. Take a look at some of these defrosting methods.
Thermostat Defrosting:
Thermostat is a basic component in all modern refrigerators. The device allows you to set the freezer temperature that you want, depending on your requirement. Most often, a refrigerator with thermostat comes with a small plastic tray which can be found below the freezer compartment. This tray is where the excess water from your freezer goes to. The thermostat works by stopping the supply of power that is received by your compressor whenever the temperature that you have set has been reached.
The refrigeration unit stops producing the cooling effect whenever the thermostat stops, which happen several times a day. And during this stage, the frost or ice collected on the freezer starts to melt, with the resulting water collected in the tray. A small tube connects the tray to a small outlet usually located at the bottom back side of your refrigerator. A pan is installed there where the tube brings the water resulting from melted ice after defrosting.
Mar 01, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Samsung RS253BAVQ freezer Keeps defrosting, and wont dump ice
One posibility is that it is not defrosting a all and that the ice is building up on the evaporator coil behind the rear cover inside the freezer. This condition will block the flow of cold air. Remove the back panel to see what your have. Either no ice , light frost, partial icing or heavy icing blocking the fins. Complete light frosting is normal.
Sep 09, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Not putting water into ice maker to make ice
Try pouring 1/2 cup of water into the icemaker and if it dumps ice , then the water valve or fill tube is the problem . If it does not dump , then the icemaker is the problem , or , freezer is not cold enough . Check your coils under the refrig to make sure they are clean and the fan that cools the compressor is working ( and the freezer fan also ) .
Jul 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Side by side fridge not cooling properly
If you have NO water in ice maker... check to see if inlet water valve to ice maker is still good.
Frig not cooling...
Look in freezer see if any frost build up, on back wall ..make sure fan in freezer is blowing.. also fan in back by compressor
Jun 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
May 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Samsung RS2630SH Side by Side Refrigerator Logo
56 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
