Question about ACD Systems ACDSee 3.1 Full Version for PC
Hi there I have had ACD 3.1 on my PC for the last few years. Just yesterday an error box appeared when I was trying open ACD form my desk top which said that the programme was not able to open itself. I cqan access ACD if I need to send an email and need to access a photo or download something from ACD to the internet but as I said I cannot open ACD from my desk top. Can you please advise how I can fix this problem. Regards David
My hp desktop with intel pentium 4 works for a a few seconds when plugged into power,but after it keeps running and displays "power save mode""
Hi, try this: assuming you're running XP. right click an empty space on the desk top, left click properties, click screen saver.
click power. click all the drop down boxes and select "never"
click apply then O.K.
the other way is: control panel, open power options
Apr 19, 2014 | Acer Aspire E700 PC Desktop
I have an old dell inspiron desk top, how do i eject acd
there's a little hole on the cd drawer, just push a pin in it and the drawer will open.
Jul 22, 2012 | Dell Computers & Internet
Then recycle bin shortcut is there at the desk top screen but wont work when u click on it
Try to check the settings of your recycle bin by pressing right click of your mouse(single click only) then choose properties then click it,form the dialog box appear choose (use one settings for all drivers) make it 10 percent,then check (Display delete confirmation dialog) then press OK.
Jul 22, 2011 | Computers & Internet
It was fine but since yesterday the desk top does not appear can hear narrator though when i switch it on
It is possible that the LCD screen got a problem. You may try to do these steps and let's see if one of the steps will work.
1. Try to reconnect the laptop to a different power outlet If it works with a different power outlet, proceed to the next step.
2. Please check the light indicator on the ac adapter if it turns on. If not, then ac adapter needs to be replaced. If yes go with step 3 3. Try to connect an external monitor to the laptop if possible. If external monitor works, then LCD screen needs to be replaced.
If step 3 works then you may need to contact the manufacturer of the computer for possible LCD replacement.
Hope this help
Keith
Jun 13, 2011 | Dell Inspiron 1464 Notebook
Double click left mouse button on desk top icon opens property box. Must right click and select open to open program. When attempting to type in dialog boxes like google search, no letters appear. Alpha...
Sounds like your registry might be a little "Off". Please download this program
http://download.cnet.com/CCleaner/3000-2086_4-11042369.html
Run it and restart your computer.
Also, go to your Control Panel, select Mouse, and choose to have the mouse operate on the left.
Blssed be
regards
selk
Oct 12, 2010 | Gateway Computers & Internet
It was working fine yesterday. but today i got Error 20. i checked the firewall as listed in the website but i still have it.
Open the My Computer icon.
If not on your desk top can be found in start menu.
After you open it right click the C drive.
In the drop down menu choose properties. On the top of the window choose the Tools tab.
You will see a option to Check Now. Click the Check Now button make sure both little boxes have a check in them and click the start button. It will say it won't start till PC is rebooted. Reboot the PC and let it run through it's scanning and fixing thing.
This may or may not fix the problem. It's only one of the things to try.
Please rate, and write testimonial if you feel the need to, if this was helpful.
Good Luck
cookieMonster
Oct 07, 2010 | Computers & Internet
Toggling between greeting 1 and greeting 2
Hi, what do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
**SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
(CICS AND ICS 2.0+)
**ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
**BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
**SET NORSTAR SET PROFILE
**LINE NORSTAR LINE PROFILE
**USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
**TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
*0 BUTTON INQUIRY
*1 FEATURE KEY EXTERNAL AUTODIAL
*2 FEATURE KEY INTERNAL AUTODIAL
*3 FEATURE KEY PROGRAMMING
*4 PERSONNEL SPEED DIAL
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*7 DISPLAY CONTRAST ADJUST
*80 RING VOLUME ADJUST
*81 MOVE LINE KEYS
*82 DIAL MODES
*831 AA ON/OFF (CICS)
*832 CCR ON/OFF (CICS)
*833 AA/CCR RECORDING MAINTENANCE (CICS)
*84 AUTO LOG OPTIONS
*85 CALL LOG PASSWORD
*89 PROGRAMMED RELEASE
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
#1 SEND MESSAGE CANCEL
2 RING AGAIN
#2 RING AGAIN CANCEL
3 CONFERENCE / TRANSFER
#3 CONFERENCE SPLIT
4 CALL FORWARD
#4 CALL FORWARD CANCEL
5 LAST NUMBER REDIAL
60 PAGE GENERAL
61X PAGE INTERNAL ZONE (1-6)
62 PAGE EXTERNAL
63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
#65 MESSAGE REPLY CANCEL
66 VOICE CALL
67 SAVED NUMBER
68 RESTRICTION /COS OVERRIDE
69 PRIORITY CALL
70 CALL TRANSFER (BLIND)
71 LINK (HOOK FLASH)
72 TIMED RELEASE
74 CALL PARK
75 GROUP CALL PICKUP
76 DIRECTED CALL PICKUP
77 CALL DURATION TIMER
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
804 WAIT FOR DIAL TONE
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
811 CALL INFORMATION
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
817 IRAD TRANSFER (CICS ONLY)
819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
#819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
#84 CANCEL LINE REDIRECTION
85 DO NOT DISTURB
#85 CANCEL DO NOT DISTURB
86 BACK GROUND MUSIC
#86 CANCEL BACKGROUND MUSIC
87 "SERVICE MODES (DR-3,4,5)"
#87 CANCEL SERVICE MODES
870 SHOW SERVICE MODES (CICS)
871 EXTENDED RINGING (ICS)
#871 CANCEL EXTENDED RINGING
872 ALTERNATIVE RESTRICTIONS
#872 CANCEL ALTERNATIVE RESTRICTIONS
873 ALTERNATIVE ROUTING
#873 CANCEL ALTERNATIVE ROUTING
88 VOICE CALL DENY
#88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
"VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
THE FOLLOWING ARE SOME COMMON USAGES:
9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
9*1 CHECK FEATURE CODES FOR VOICE MAIL
9*2 SMDR Admin
9*3 LOGGER TIME STAMP
9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
9*4 NORSTAR DOOR PHONE PROGRAMMING
9*5 FLASH LOW RANGE CHECK FEATURE CODES
9*7 ACD ADMIN MAINTENANCE SESSION
9*9 VOICE MAIL INTERFACE (VMI) CODES
900 SMDR,enter an account number to be logged with the call
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
903 ACD CANCEL WRAP
904 ACD HELP
904 FLASH ACD LOW RANGE LOGIN/OUT
905 ACD CATEGORIZE
905 FLASH LOW RANGE DN IDENTIFIER
906 ACD RECORD CALL
906 FLASH LOW RANGE VM TRANSFER
907 FLASH LOW RANGE VM INTERRUPT
908 STAR TEXT (OBSOLETE)
908 FLASH ACD LOW RANGE BUSY MODE
909 ACD ANN. MAINTENANCE
909 FLASH ACD LOW RANGE QUEUE STATUS
910 FLASH LOW RANGE LEAVE MESSAGE
911 FLASH LOW RANGE OPEN MAILBOX
912 FLASH LOW RANGE OPERATOR CONTROL
913 ACD CALLS QUEUED
913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
920 ACD ADMIN SESSION
921 ACD ROUTING SESSION DAY/NIGHT
922 ACD ADMIN STATISTICS SESSION
923 ACD GROUP STATISTICS SESSION
960 DIAL BY NAME (CINTECH NSVM OPTION)
961 DIAL BY NAME ADMIN (PSWD=1234)
980 VM SEND MSG TO ANOTHER MAILBOX
981 VM LOG INT MAILBOX
982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
983 VM ADMIN PROGRAMMING (PSWD=1020000)
983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
984 VM TIME AND DATE(STARTALK Pswd=1020000)
984 AUTO FOREWARD TO VMAIL(NSVM4.0)
984 FLASH ACD LOGIN/OUT
985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
986 VOICE MAIL TRANSFER
987 VOICE MAIL INTERRUPT
988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
988 FLASH ACD BUSY MODE
989 RECORD CALL (NSVM 4.0)
989 FLASH ACD QUEUE STATUS
Mar 11, 2010 | NorStar M7310 Corded Phone
Where do hook up wireless. I have dell desk top.
Hi and welcome to FixYa,
Almost always, wireless mouse makes use of the USB port to connect its base/receiver. Depending on the exact model of the Dell desktop, there would normally be USB ports at the rear of the computer. Some others have 2 USB ports at the front or side.
Good luck and thank you for asking FixYa.
Oct 22, 2009 | HP Wireless Optical Mouse
My computer wont start up
First try pressing F2 at start up to see if you can get to setup. Also pressing F12 may get you a boot menu. If cd is already set as first boot you may get a chance to boot from a Windows cd. The idea here is to get to a minimal Windows configuration like setup or safe mode (F8) to see if this is a hardware or operating system fault. Two common issues with eMachines are power supply problems where repetitive reboots can actually fry the motherboard or if the PC has a few years use the CMOS battery. Steve Medley
Oct 30, 2008 | E-Machines eMachines Desktop PC
ACD Systems ACDSee 3.1 Full Version for PC Logo
56 people viewed this question
Top ACD Systems Computers & Internet Experts
David Payne
David Payne
Are you an ACD Systems Computer and Internet Expert? Answer questions, earn points and help others
