Since changing the ink cartridge for the first time it now won't print. Sometimes it will print absolutely nothing although it seems to go through the motions but page comes out blank, sometimes it will print first page perfectly and either some of the next page or totally blank. Now the "blue"ink is showing as low while all other colour are just about full? Have tried all "troubleshooting"solutions and everything tests OK.
  • 1,218 Answers
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Posted on Nov 15, 2010
Will only print yellow, black and photo black-- red cartridge shows ink in window and I just refilled blue-- cartridge was only out of printer a few hours. I've cleaned the print head a number of...
There are a few things here that will do this. One is the cartridge is a smart cartridge and unless you reset the chip it either won't print or shows low. If you filled it before then this shouldn't be it. If you have refilled the cart more than a few times they sometimes just stop. This is either the ink has jelled inside or the little feeder sponge is dried out. If you changed ink brands sometimes the ink reacts with the old stuff and jells.The other is the jet or any feeder tubes are plugged with dried ink. Usually happens if you haven't printed for a while. You can try running the cleaning cycle and it will take quite a few of these sometimes before it starts working.
There are a few more tricks for cleaning such as using white vinegar to dissolve dried ink but that's a bit of the messy side sometimes. Usually we have just had to buy a replacement cartridge after spending the time on this. We eventually just got rig of our ink jets and got some of the cheaper color laser printers. Wish we had done that sooner.
Sep 01, 2011 | HP Photosmart D7560 InkJet Printer
The black print won't print, but colour does, although very lightly. I have refilled the ink cartridges at Island Inkjet, so there is ink,..but black won't print at all.
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
May 27, 2011 | Canon PIXMA MP610 InkJet Printer
Hi The colour is wrong - the yellow does not seem to print although it is not empty. How can I fix this? Thank you susanne
Sometimes the ink cartridges go bad before they run out of ink. I've had this problem and the vendor I get my ink from let me trade it for a new one. Try changing the ink cartridge and see if that fixes it like it did on mine.
Sep 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Printing 1 1/2" down right side of paper
You have a defective toner cartridge, drum should be clean when you looked at it, the blade is failing. Is the cartridge remanufactured (or compatible)? Although they usually work well (depending on the supplier) there are sometimes defects
Nov 25, 2008 | Canon PC-980 Color Copier
The yellow ink doesn't print although the ink shows full
Hi there! are you using original canon ink cartridges? if so, your cartridge might have defects, try to replace your cartridge with a new one. If you're using compatible ink cartridges try to replace it with an original canon ink cartridge. Have a good day!
Apr 09, 2008 | Canon i860 InkJet Photo Printer
No ink coming from cartridges.
Seems like a lot of people are all of a sudden having these problems. I have had this printer for 4 years I think and no problems at all. Phone support says to clean the heads 3 times and then they give up. By the way, there is no tape to remove from authentic ink cartridges for this printer. The cartridge holder pops a hole in the film. You cant pull that cover off, it is popped when inserted.
Jan 28, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printing only blank pages
you have to go to the printer settings start printer properies ink or color than change to color because you can set your printer to print color or just black does not matter if that one has color if the setting is for black it will print just black
Dec 02, 2007 | HP DeskJet 3940 InkJet Photo Printer
199 people viewed this question
k24674
jasbo
jasbo
