Question about Car Audio & Video
Installing amp Remote wire is getting constant flow of electricity when I turn the car off. Do I connect the remote wire to the amp to another place other than the place my cd player is connected too.
  • dfreespk Jun 19, 2008
    the amp stays on when you turn off the car, when you unplugg the remote wire it cuts off
    President:
  • 624 Answers
If I understand you right, your amplifier is never turing off
The remote wire from your head unit should be the wire that goes to the remote turn on of the amp.
If that wire is getting constant voltage to the amp you have a problem in the head unit.
This is something that will require your head unit to be checked by a technician.
Before you take it to a service center, make sure that this is your real problem.
I may be able to help you with that.
First , how do you know the remote wire is getting constant voltage to the amp, how did you check it?
Is the amp on all the time, even with the car turned off?
Does the amp turn off if you disconnect the remote wire from it?
Let me know if I can be of more help.
Posted on Jun 19, 2008
  • Dave DeGain
    Dave DeGain Jun 19, 2008
    It is settled then, you have a problem in the head unit.
    Are going to try and fix this yourself?
    If so, I need the model number of the head unit. if I have a service manual for it, I should be able to guide you thru it.
    I have thousands of service manuals
    You will need a power supply, multimeter, and soldering iron with solder and some solder wick.
    Thanks for the "FixYa" it is appreciated :)
So I can't get my jbl gto- 521 ex to shut off even with out the auto on wire connected. I tested the wire and when the car is off there is no current but when the car is there is current, so here is my set...
remove the remote wire.
you probably have the power wire touching or connected to the remote wire. you dont need with auto on.
once again, unplug the remote wire.
Oct 16, 2013 | Car Audio & Video
Amp on all the time. how do you wire in the remote lead? We have it wired in, but the amp stays on even when the care is turned off? Help!
The remote is connected to the remote on the car radio. The same remote is being used by eg the electric antenna. If there's not a remote on the car radio wires, place a switch.
Aug 17, 2011 | Lightning Audio S2.500 2CH 500W Amplifier...
My amp i just instaled is a terminater mtx 250 watt amp and the lights are flashing instead of a constant red i checked my power and ground what else would it be
Check your remote wire on both the deck and amp... If the remote wire is loose it will turn the amp on and off constantly... Also check to make sure that the fuses on the amp it self are properly seated.
Oct 30, 2010 | MTX Car Audio & Video
I have this hooked up and works fine with the key on, but when i start the car, sub light, amp and sub dont come on.
You have connected it to the wrong power wire - one that is only active in service mode - first key position.
You should draw a wire directly from the battery (don't forget to add a 40 amps fuse on the wire) to the amps. If you don't want them constantly operational (you will have to manually shut them down) install a relay on the wire with the command coming from a wire from the instrument key position - second position of the key. Use a voltmeter to identify the wires.
Oct 15, 2010 | Rockford Fosgate Power 351M Car Audio...
Wiring
The remote turn on should be connected to the blue wire of the stereo. this wire is used to turn on the amp on ly when the stereo is on. If you connect this wire to a +12 constant, the amp will stay on all the time.
Jun 13, 2010 | Kicker KX150.2 Car Audio Amplifier
Turning the amp off
your amp should have 2 places for 12v+, one larger one for main power, and one small one for a remote turn on. the small one is usually between the ground and power terminals. make sure you don't have constant power feeding it. this is for a input voltage from your radio to turn the amp on and off at the same time as the radio. On the back of the radio there should be a blue wire hanging out, that is usually the one to connect to the amp remote input.
Mar 09, 2010 | Car Audio & Video
Remote wire
You have the REMOTE wire hooked to a constant +12V source. The remote wire is supposed to correspond to the ACCY wire to the vehicle, usually through an aftermarket Audio DECK. If it is reaming on when turning the key OFF the wire you currently have it spliced to is a CONSTANT +12V , which is connected directly to the battery. If you do not have a aftermarket Deck, hook the remote wire to the ACCY wire conecting to the factory radio.
Jun 19, 2008 | Car Audio & Video
2000 watt jl audio amp & car battery...
Make sure that you don't have any strands that would connect the remote lead to the constant +12 volts. Also make sure that your remote lead fromt the radio switches off when you shut the car off. If you don't have an aftermarket radio with a remote turn-on lead, tap into the ignition wire to the radio. Let me know what kind of car you have and I can point you in the right direction to get the right wire. Good luck.
-Andrew Hawkins
Apr 08, 2008 | Jl Audio 1000/1 Car Audio Amplifier
MY AMPLIFIER?
Try removing the remote turn-on wire from the terminal on your amp. If that shuts it off then you can use either the remote turn-on output from your head unit, or any fuse at your fusebox that only comes on with the car on.
If that doesn't shut it off the amp has an internal short and should be replaced or you could put an easily accessible fuse in its power wire and pull that when you wanted to shut it off.
Mar 06, 2008 | Power Acoustik LT-980/2 Car Audio...
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
