Purchased used acer 7720Z donot have adminstrator password it has two partition 1. winvista 2. win nt help I can't reformat drive or is there some way to get the pswd ? prefer to reformat and start over but DONOT have startup or recovery discs I'm assuming that vista is in one of the partitions help
    Guru:
  • 125 Answers
It contains a fixed amount of reactants and when they are discharged, both plates undergo changes in chemistry to become the lead sulphate and the result is that theA1185 battery is flat.
Posted on Nov 15, 2010
Can i use a 3tb hard drive on acer z5610 running windows 7
The simplest way would be to reformat as NTFS. Use the advance options to delete and re-create partions.
GPT requires EFI and there is some debate whether Win 7 can be installed. I have not tested yet and quite frankly I would not waste the time and effort. Your hard drive and partition size is well within requirements. Good Luck
Sep 22, 2012 | Computers & Internet
ACER ASPIRE 3750G 13.3", reformat.
when you turn the unit on hit Alt+F10. This will access the acer recovery partition from which you can restore. This is provided you didn't replace the Hard drive or wiped the drive yourself
Aug 02, 2011 | Acer Computers & Internet
I lost my sandisk secure access password and want to recover my data or password...need help..please
i have'nt had the need to use this software so i dont actually know how it works http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Aug 02, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
The hard drive can't reformat
try to format using linux system... like ubuntu...using gparted software...or kde partition manager i've try in many times...and always solve using those software...even bad sector...
or maybe you can reformat using win server 2000 edition...
Mar 01, 2011 | Acer Aspire 3680 Laptop
HDD cannot be detected after reformatting
Ok, unfortunately, even though, you had two partitions they were both on the same Physical drive, now you cannot "Format & Partition" without breaking the install, as the Win 7 is the "Boss" and when you formatted you have wiped out all you boot track information, You maybe have a shot, if you get a Win 7 install disk, and boot off of it, then ask it to repair your "Boot Sector" this may allow you to Boot into Win 7,if you are lucky. Then you can use as normal. But if you cannot do that, you will have to boot from a Win 7 or Vista or whatever OS you wish to install,and follow the instructions, and do a complete reinstall of the OS. If you wish more than one partition, in the setup, it allows you to choose the size of your drive, so simply do all that, at that time.
May 08, 2010 | Acer Aspire 4720 Notebook
I have just purchased a Seagate Freeagent 1tb drive and
Yes to all. First, You can share them by setting it as a network, or shared drive. Right click the drive, and choose sharing and security. Set the share name, and then connect it to the other computers by pointing them to this address: \\COMPUTER-IP\SHARE-NAME
Second, the manual should be in the drive when you first got it, but if it got deleted, the only way to get it again, would be to borrow another drive, as it comes with a custom key to extend the software trial to 100 years, and therefore is not hosted online.
Last, You can partition it for free with EASEUS partition manager home. You can get it here: http://www.partition-tool.com/personal.htm
I hope I helped.
Jan 02, 2010 | Seagate FreeAgent Pro 1TB External USB...
Password reset
Reformatting the hard drive is the best way to solve this problem. Reformatting will also get rid of all the junk files and make the system faster.
Aug 14, 2009 | Dell Inspiron 1501 Notebook
Reformatting
you need to obtain a windows cd and use the setup to completely reformat the drive
Aug 18, 2008 | Acer Aspire 4720 Notebook
Does not load Win98se
Robb4. Use fdisk to make active partition and reformat.
Jan 25, 2008 | IBM ThinkPad T20 2647 Notebook
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
