Question about EA - Electronic Arts Video Game Consoles & Games
Video on some games is herky jerky or lsort of like slow motion. sound is normal
  • 12,061 Answers
Ok, well i have seen this many many times, and as far as i can tell quite a few things can cause it.. from the CPU getting "Bogged Down" with an algorithm, to, difficulty in reading the Media, to, not enough memory, bad memory management and so on.. Sometimes it can be fixed by cleaning the DVD, if used. But often it is simply a "Glitch" however if it happens repeatedly at the same spot in a game, or whatever, then it maybe damaged media. Again if DVD a Lens Cleaner may be used this indeed may help, don't over do the cleaning though as it will damage it more than help. If streamed from a HDD, then there maybe damaged sectors tracks blocks etc, if this is suspected, then uninstall and reinstall the software, after doing a disk cleanup and scan, this too will often sort problems like this out too.
The sound is often encoded away from the video data, and so good sound, doesn't always mean anything, as the sound may indeed be OK, but the picture terrible.
If run on a PC, More RAM, Higher GPU and CPU speeds, more swap space, will usually sort most problems out.
Posted on Nov 15, 2010
My sound has a herky jerky tempo. How can I troubleshoot?
herky jerky tempo?
that is an interesting description. If it sounds like its kind of pulsing, then you may have a bad wire or if you use a 3.5mm headphone plug for any of the connections, it may not be inserted properly or all the way. that can cause phase cancellation effects like you are describing.
Sep 02, 2015 | Bose Solo TV sound system - Black
When I play audio or video files they play fine and then suddenly start dragging for 15 sec. -1 min. then return to normal , I have also noticed when I play pinball the ball motion is jerky and fl
The most likely problem is that you are either, buffering from an internet feed (slow internet) or you are overloading the processor. The Pinball would indicate that your processor is too slow. Buy a new graphics card or more RAM. Also run CCleaner to get rid of any rubbish that is slowing down the computer.
Apr 18, 2013 | Dell Dimension 3000 PC Desktop
Canon ixus 75
Unfortunately, no. By recording in fast mode, the camera captured fewer frames than usual. When played back at the normal speed, the action appears faster than normal. Because the camera recorded fewer frames, there is no way to make up for the images that were not captured. You could slow down the playback, but the result would be a jerky, jumpy video.
Now, if you had accidentally captured the video in slow motion, you could then throw away some of the intervening frames and recreate a normal-speed video.
Feb 15, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Logitech web cam video adjustment
This is just USB and is perfectly normal. It is hard to find a webcam that does not do this.
May 05, 2010 | Logitech Webcam
My jazzy 1113 won,t come out of slow modeI have reset it it jerks herky jerky tries to set into reg mode then slips with a **** back to slow hellp it took me an hour to get home and it was onlyh 10...
Hi.Sounds like faulty motors to me. Check brushes and brake units. How much work has the machine done.
These motors develope a build up of carbon and copper dust from the brushes and commutator. This dust can cause a partial short from the armature to the outer casing of the motors. What happens then is the signal from one motor leaks through to the other motor causing the controller to think its developed a fault. A good serviceman can tell you if this is the case. Good luck. Neil.
Feb 20, 2010 | Pride Mobility Products Jazzy 1113 ATS
I have a stx38 riding lawnmower. The drive is herky jerky in forw
I have seen this problem on other tractors. It is caused by a loose or sticking drive belt between the engine drive pulley and the transmission. There is an idler pulley between them that is spring loaded to keep the belt tight. If the pulley bearings froze so the pulley doesn't spin, or if rust or a broken spring prevents the pulley from swinging over enough to keep the belt tight it would cause the problem.
May 05, 2009 | John Deere Garden
Slow motion live and recorded video
sound and audio devices not working
Jan 20, 2009 | Dell Inspiron 1501 Notebook
Leadtek PX8500GT low profile video card
what settings uuseing the game on restion 1024x768 ? shadows off 8500 sounds like nvidia not ati drivers ? lol
Jan 09, 2008 | XFX GeForce FX 5200, Graphic Card
Video Game Consoles & Games Logo
Top EA - Electronic Arts Video Game Consoles & Games Experts
James Wishart
 Shayaan Tanwir
Shayaan Tanwir
Person On the...
Level 1 Expert
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
