Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Is there any water problems in burtonsville i thougt the pipe broke.
    Genius:
  • 1,027 Answers
If it is like my Kenmore, the water tube connection at the lower edge of the freezer door hinge line, may have come loosened by opening and closing the door. That tube provides the water source for the in-door chilled water outlet. Just tighten the connections.
Posted on Jun 19, 2008
Why do my house pipes vibrate?
The problem is called water hammer it happens because water lines have become lose inside the walls. Generally because pipe straps have loosened or even broke, or not enough of them were used at time of installation letting pipes rattle against them selves or walls and so on.
Jan 02, 2014 | Plumbing
How to remove broken off hot water tank drain nipple
You can purchase an ease out tool from Home Depot or Lowe's, It fits inside the broken pipe and when you rotate it counter clockwise it tightens inside the pipe and removes the nipple. (Be sure to check the inside pipe diameter first)
Mar 21, 2013 | Water Heaters
No heat I have changed thermostat,blow air thougt
I had this exact problem. Suspect a clogged heater core and you will probably have to replace it. Make sure you have the valve that opens the heater that works. You can remove it and see if it works. The valve is a vacuum valve that is connected within 10 inches of the 2 firewall heater hoses.
If the valve opens and stay opens and passes water well then disconnect the output of the heater and verify the that water flows well and you may be ok with the heater core being ok.
I know you do not like to hear but with all these tests, you should replace the heater core in the cab. It is a pain to remove but doable.
e
Sep 20, 2011 | 1992 Dodge Caravan
I replaced an Moen spout for my shower unit. Water flows thru the Spout and when level is pulled water flows thru the shower head. But there is water leak somewhere (reverse flow?). The ceiling below it...
if you have copper piping,you probably twisted the pipe when,you tightened the spout ,and broke pipe. If you are'nt able to get into the wall on the shower side, cut a hole on the other side of shower wall to repair it.
Aug 04, 2011 | Garden
I broke the pvc pipes that transport the water to the jets. I need replacement pipes. Where do I get those?
the PVC pipes used to plumb bathtubs can be either rigid PVC pipe or flex PVC pipe. You may use either kind and is usually available at your local Home Center.
Jan 10, 2011 | American Standard Colony Hydro Massage...
Bike starts to miss fire at about 80 miles an hour, have changed everything electrical still no luck removed carb found a joint for water pipe broke could this cause the miss fire?
Looking at this problem laterally rather than logically, what if the pipe leaks when the bike is working and just happens that the air intake ingests the water at high speed. That would make it misfire.
Does it misfire due to revs or speed?
Jan 03, 2011 | 2001 Yamaha YZF-R6
Windscreen washers weren't working. connection to the jets had come undone.(probably due to frozen water in the pipe) tried to reconnect and one plastic pipe broke close to the connection.(about 2,1/2...
if i understand what you are saying correctly, the line leading to the nozzles in the hood broke, not the nozzles themselves. if the line broke in the middle somewhere, you can go to the auto parts store and buy a piece of rubber vacuum line, just slightly larger than the plastic line and use the rubber line as a splice. has to be a very tight fit or the rubber will leak or blow off when under pressure. if you have a set of measuring calipers, you can measure the plastic line, or just cut off a very small section and take it with you.
Feb 21, 2010 | 2001 BMW 5 Series
Volvo V40 T4 -01 front springs
You maybe should of changed all the springs, also the one you done, the shocker could of extended out to far and is not now working correctly causing the problem.
Jan 10, 2009 | 2001 Volvo V40
Water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Jul 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
52 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
