Question about Fisher RS909
Trying to get connect Samsung HDTV to JVC RX 660V receiver. All components (cable box, Xbox) are connected to TV using HDMI cable. JVC receiver has no HDMI outlets (yeah.. its old), so I used the component cable (red & white cable) to connect "Audio Out" on TV to (red and white jack) in the receiver. Still the sound comes from the TV and not the receiver. why not?
2 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: Connecting Samsung TV to a Fisher RS909 Receiver
yes use rca outs form samungto video in on sterio
Posted on Jan 26, 2008
I have just brought a rx-v367 av reciever and have connected it to my tv/ speakers. speakers work fine when testing set up. however there is no sound coming out when connected to tv. also it keeps coming...
Hi, Yamaha audio-video receivers are equipped with a variety of connecting jacks for hooking up different types of electronic equipment. Component AV cables are typically used for hooking up the receiver to a cable TV box. Component cables can also be used to connect the Yamaha receiver to an HDTV, although a High Definition Media Interface (HDMI) cable offers a simpler connection if the receiver is equipped with HDMI (all HDTV sets are equipped with the distinctive, six-sided HDMI jack). The connections should take less than five minutes.
Instructions
Things You'll Need:
* 2 sets component AV cables
* HDMI cable
Check the back of the Yamaha receiver to determine if HDMI is available. The six-sided jack contains 19 holes set in three rows. If the receiver is equipped with an HDMI Out port, use an HDMI cable to connect to the TV by inserting the plug straight into the jack with the wider end turned upward.
Insert the red, green and blue plugs on a set of component AV cables into the Video Out jacks on the cable TV box, matching the plug colors to the jacks.
Connect the plugs on the other end to a set of Video In jacks on the back of the Yamaha receiver. Make a note of which jacks are used for the connection. Each set of jacks is labeled on the receiver.
Insert the audio plugs on the component cables into the Audio Out jacks on the cable box, using the white plug for the left channel and the red plug for the right.
Attach the plugs on the other end to the Audio In jacks on the Yamaha receiver.
Use a second set of component AV cables to connect from the AV Out jacks on the Yamaha to the AV In jacks on the HDTV only if an HDMI cable was not used.
Feb 18, 2011 | Yamaha RXV367 Receiver
Is the Yamaha RX-V596 capable of using HDMI in
Nope. Use S-Video or composite video In and digital audio in from the Cable Box, S- or composite-video out to the TV/Monitor.
OR (what I do) skip the receiver as a video middleman and take the HDMI video right to the TV; and run the Cable Box digital audio to the Receiver.
Feb 18, 2010 | Yamaha RX-V596 Receiver
How do i connect my xbox 360 to my yamaha rx-v665 receiver
If you are gonna connect the x-box to the yamaha directly you would have to connect the red and white cables to one of the inputs on the reciever and the yellow to the video on your tv.
Feb 16, 2010 | Yamaha RXV665BL Receiver
Connect my xbox on reicever
If your xbox has HDMI connector then you HDMI cable to connect it to the receiver and another HDMI cable to connect receiver to the TV. Receiver should support both video and audio over HDMI.
If your xbox doesn't have HDMI, connect the video directly to your TV using whatever connector/cable is available (in terms of quality from best to worst: HDMI, component, s-video/scart, composite).
Then connect audio to the receiver via optical spdif cable.
Jan 29, 2010 | Yamaha RX-V463 Receiver
With Cable connected to the rx-465 input, I'm not getting HDMI output to a Samsung plasma TV. With DVD HDMI input I get HDMI output to the TV. Any suggestions on what I'm missing. Thanks, Greg
is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings
Nov 03, 2009 | Yamaha RX-V463 Receiver
Digital Audio cutting out
I have the same problem with my RX-V565 receiver. Did you get this fixed?
Albert
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
XBOX 360 to JVC RX 5060b
does your reciver have video ins and outs monitor out u have to send master video out from jvc to tv 1st u know im open for chat
Jan 06, 2008 | Audio Players & Recorders
48 people viewed this question
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
