Question about Amana ARB220RCW Bottom Freezer Refrigerator
Water from core is getting into my freezer
I have a Amana bottom freezer ARB220ZCW and I'm getting what I believe is condensation running into my freezer. I can see the trail of ice coming from the core/radiator at the back of the freezer. A frozen puddle forms at the bottom and then it makes it's way out the door and on to my floor. I need to get this fixed soon. Does anyone know what could be the cause of this? I see some talk of clogged hoses/drains so I'm going to look for that. I'm guessing it isn't that though.....
Harry0
  • 2 more comments
  • aichare Jun 19, 2008
    Thanks PaulMo but as I thought it was not the drain tube. I was back there a while ago and cleaned things up. It wasn't bad then and still looks good. It is dry back there though and that is what I need to work on.
    I'm going to go in from the inside of the freezer next. That is where I see ice sometimes form on the coil. I think I'll have more luck there.
    I'll
    I'll post my findings after I go back in.
  • aichare Jun 30, 2008
    Okay, Here's where I'm at: I found an ice dam at the point where the condensation makes it's way to that tube that is accessable behind the back black panal. I cleared it and thought I had ended my troubles but now the upper fridge isn't getting cold. What happened? The freezer is cold. I just had a thought that maybe a wire got in the way of the fan I saw in there. I will check that out and get back.....
    Update:
    I forgot to plug the 6 prong plug harness back to the mating plug at the top. I pulled it in an attempt to gain slack when I couldn't work around the cover which was giving me trouble working around not knowing (then) how to disconnect the ice maker plug from the cover. I believe that this plug harness goes to the defrost timer switch. Located above the light fixture in the upper refridgerator.
    Anyways the cold air is now moving and all looks good.
    All in all a good solution back when would have been to move the food you have to save to a cooler or another fridge then unplug the problem fridge wait about an hour with doors open then run some warm water at the base of the rear cover and see if the drain tray in the back is recieving the water through the tube. Don't start up fridge till that try is emptied though. too much to evaporate. use a sponge. easy job. also a good idea to clean the coil under the fridge while you're fridge is down. that can be done with vacuum or a dryer brush. nylon bristle. That's about it.
    Genius:
  • 1,027 Answers
Right, the drip tray on the upper coil section has a blockage (possibly mold) that prevents the defrost condensate from reaching the evaporator pan that should be at the bottom of the fridge. Those lines are usually accessed from the back of the fridge.
Posted on Jun 19, 2008
Amana bottom freezer/frige not cooling. Clicking sound then buzzing sounds and clicks off. Compressor hot. Hear it running but no cooling.
Solution to this recyle-Amana is to scrap it and get a "GOOD" brand!!
The condenser/compressor is made by Tucumsah, excuse the spelling, but you know what I'm saying.
Jan 15, 2013 | Amana ABB1927DE Bottom Freezer...
The freezer door handle on our ARB220ZCW is cracked. Where can I get a replacement?
I have used this site for a couple of replacement parts for both refrigerator and dish washer and have been extremely satisfied with their service. Hope it helps
http://www.partselect.com/
Nov 29, 2010 | Amana ARB220RCW Bottom Freezer...
Amana model arb220zcw is not cooling. Freezer and
Your problem could be one of two issues.
- The relay part number 12555902. This is a package that plugs directly onto the compressor, it is an easy repair.
- If the relay does solve the problem the issue is the compressor itself. This repair is major and usually will cost around $500.00 and will need to be done by a professional
Apr 18, 2010 | Amana ARB220RCW Bottom Freezer...
Everything in the freezer has defrosted, temp setting at 6 (refrigerator compartment at 5). Amana bottom freezer model ARB210AB Water will not freeze, ice cream melted and frozen veggies and meat have...
Is there frost on the freezer panel? are the two motor and compressor running (freezer motor and condenser motor)? find this out 1st. this is nothing you did but if you are not mechanically incline at this point only a frig tech can properly check and tell you exactly what is it. theres are the things it might be...
compressor not working
condenser not running
freezer fan not running
thermostat not sensing temp.
stuck in defrost
heaters on too long
bi-metal shorted
timer not working
now if you paid alot for this frig at least get someone to look at it for a service call ($40-60) if it too high to repair then its time to get a new one
Mar 27, 2010 | Amana Easy Reach Bottom Freezer 20.5 cu....
My amana frige leaks at the bottom, it is a bottom freezer frige, I moved it lately because I am laying laminate floor, any solutions?
In your shuffling of the refrigerator you may have knocked the condensate drain away from the pain near the compressor that evaporates the water back into the air inside your home. Or you may have the refrigerator leaning in a way that the water pools up near the condensate drain pipe beginning in the rear of the freezer and has frozen over and causing the water to drain over the condensate collector pan behind the rear wall of the freezer. I have more, Sea Breeze
Oct 16, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana 20 - 20 years old. Freezer thawing - refreezing. Fan running very hot in the compressor arae at the bottom. Drip pan full of water - never saw that before.
IT SOUNDS LIKE YOU HAVE DEFINITE ISSUE WITH YOUR COMPRESSOR, IT MAY BE CONSTANTLY RUNNING OR RUNNING TOO OFTEN, THIS WOULD CAUSE THE LARGE AMOUNT OF HEAT COMING FORM THE BOTTOM. IF YOUR COMPRESSOR IS RUNNING TOO MUCH YOU WILL ALSO GET AN EXCESS AMOUNT OF WATER EVAPORATING DUE TO CONDENSATION ON THE EVAPORATOR COILS THEREFORE FILLING UP YOUR DRAIN PAN THAT MUCH QUICKER. YOUR FRIDGES COMPRESSOR MAY BE ON THE WAY OUT BUT YOUR FRIDGE SOUNDS LIKE IT'S WORKING THE WAY IT SHOULD BE.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Amana Freezers
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Fridge/freezer not very cold and cylinder is very hot? amana arb220zcw
souns as if youre having an issue with your compressor("cylinder?") black football sized motor behind unit???5 yr manufactures warr if so, cross your fingers, out of warr that repair could cost 4-6 hundred dollars
Nov 20, 2008 | Amana ARB220RCW Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana ARB220RCW Bottom Freezer Refrigerator Logo
149 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
