Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Cabrio washer does not have a soak cycle. I miss this and wonder if there is anything I can do to simulate a soak? I've been using rinse and drain, just to get a sort of mini prewash, but when something needs to soak it just isn't enough.
  • 14 Answers
SOURCE: soak/prewash led flashing after about 10 seconds...
It is a pressure sensor fault, call in an expert to fix, these machines are far too complex for anyone else to repair Good luck
Posted on Sep 14, 2007
SOURCE: when the washer go s on rinse the prewash flashes Problem
Mine has been doing the same ... each time it goes to the next part of the cycle the red light flashes but the machine doesn't do anything ... so up till I have been able to get the machine moving to the next stage by pressing the "Start" button ... unfortunately the machine will pause on each stage - meaning I have to press "Start" at each stage!
Posted on Jul 28, 2008
  • 1028 Answers
SOURCE: Whirlpool Washer mod.LSR5232LQ1
ck lid switch
Posted on Sep 27, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool Cabrio Washer Error message code F1
Whirlpool did a recall on this problem here is there number try this first. Whirlpool 1-800-253-1301
On a number of ranges this can mean a number of things, the most common being a failed ERC(EOC, Clock assembly)or a faulty touchpad. Firstly if you are using a recent Maytag range it may pay to test the oven sensor as described above as this may cause an F1 error if faulty (may apply to some other ranges as well) this is not a common cause but is worth discounting. To check the ERC and touchpad
  1. Disconnect the power
  2. Gain access to the back of the ERC
  3. Disconnect the ribbon cable that connects the ERC to the touchpad
  4. Check nothing will short when power is reconnected
  5. reconnect the power and switch on
  6. Watch for F1 and listen for the beep
  7. If you get the F1 and the beep this means the fault is with the ERC and it will need replacing
  8. If after 30 mins you do not see the F1 error and hear the beep, replace the touchpad
Posted on Feb 14, 2009
skrbin
  • 121 Answers
SOURCE: water will not drain from my Cabrio
check pump filter.
Posted on Feb 17, 2009
Why doesn't Cabrio washer wash the clothes?
This model has gone through different control board revisions, could be control board related, service mode would have to be accessed to have machine run thru self-diagnostics. if it does not agitate on self-diag mode, unit needs board
Apr 03, 2013 | Whirlpool WTW6400SW Cabrio Washer
Cabrio washer will not start
I have one doing the same thing it washes but will not rinse.So until I can do better I just use the wash cycle twice first with detergent and once without.
May 30, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
The machine starts going thru the wash Cycle and then it goes past the rinse cycle and then it shows OL after the spin cycle.. It even does this when you have no cloths in it. I went to rinse and spin...
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Press STOP/CANCEL to clear the display and completely cancel the cycle
flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Stops during wash cycle
my cabrio agi washer will stop constantly during the wash and rinse cycle and it will say F51 and dL
Sep 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Rinse cycle
If the machine has a soak cycle, you can use that. If it does not, you can have it fill on a cold rinse, and then stop it for a soak. Restart it on a hot wash with a cold rinse. Tumble dry low.
May 14, 2009 | Ariston Technologies AWD 129 NA Washer/...
F_i on the cabrio washing machine at the rinse cycle
F is a code then another number or letter should pop up too that is needed. It will say F then a number like 50 or 51.
Dec 10, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
505 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
