Question about Dishwashers
Well how do you remove the plug to the garbage disposal?
  • 10,515 Answers
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 15, 2010
How to remove drain plug from garbage disposal
Good Afternoon Dogman85,
I understand you want to know how to remove the drain plug from your garbage disposal, regarding your Frigidaire dishwasher, model# PLD2850. I suggest contacting the manufacturer of the garbage disposal. They will be able to better assist in removing the drain plug from your garbage disposal. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire 24 in. PLD2850 Built-in...
We just replaced our garbage disposal and now the dishwasher won't drain. I order a drain pump and it still won't drain.
Make sure that the air clear on top of the sink is clean and clear all the way through. Sometimes in replacement silt and other garbage clog this up and keep it allowing water to drain properly.
Dec 23, 2010 | Whirlpool Dishwashers
Water standing in bottom of dish washer. Just replaced the garbage disposal.
You forgot to remove the round "Knock Out" Plug in your new garbage disposal. Check your new garbage disposal manual.
Feb 23, 2010 | Jenn-Air Dishwashers
Dishwasher will not drain totally after it has finished the cycle. I recently had a new garbage disposal installe and every since then the dishwasher will not drain. Is it something to maybe do with the...
disposal has a plug in it where the drain line from d/w hooks up remove drain line from disposer and stick a screwdriver in hole to remove plug remove plug from inside disposer with a pair of needle nose pliers that should take of it
Oct 26, 2009 | Dishwashers
Removing dishwasher drain plug on a new garbage disposal.
The plug is thin plastic. Use a flat blade screw driver and a hammer to knock it out. I know this sounds primitive but this is how it is done. I have been a plumber for thirty years.
May 16, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My quiet partner 4 will no longer drain, I recently replaced my garbage disposal & the problem began after that.
There is a plug you have to remove on the garbage disposal where you hook up the washer drain hose.
Check the instructions with the disposal.
You'll have to deinstall the garbage disposal, remove this plug and reinstall.
May 05, 2009 | Dishwashers
How to knock out garbage disposal plug
Turn off the power source to the garbage disposal. Take the drain hose from the dishwasher off the connector going to the disposal (if connected). Insert a flat blade screwdriver in the drain hose fitting and tap a few times with a hammer. The plastic plug will pop off inside the garbage disposal. Reach inside from the top of the disposal to retrieve the plastic plug. Sometimes you have to use a little force to tap the plug out. Hope this helps you.
Apr 07, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher won't drain
remve the drain line connected to the garbage disposal take a flat blade screwdriver insert it into the garbage disposal and hit the end of the screwdriver , the plug will pop out
to verify after hitting it stick the screwdriver back in if it has not removed the plug do it again
Apr 04, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dish washer
The drain in to the garbage diposal is clogged.  Remove the drain hose from the dishwasher and clean the hose.  Also check the inlet to the garbage disposer and clena it.
Oct 28, 2007 | Dishwashers
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
