Question about DISH Network 135899 Remote Control
When I change the channel in my room it changes the channel in the front room also. How can I fix this problem? Thanks
    Novelist:
    Champion:
  • DISH Network Expert
  • 286 Answers
Hey there! My name is Becki Barned, and I am with Dish Network customer service. This problem may have already been resolve,d but if not, or if you want for future use, follow these steps! Make sure that your receiver is in dual mode (will have green/orange/blue light on). Thsi should fix the problem. If not go ahead and follow these steps to reprogram your remote, which may be interfering with the other room's remote. http://www.dishnetwork.com/SupportSection/remote-control If that doesn't work, blog back, or you can find us on Twitter!!!!
Posted on Dec 25, 2010
I'm trying to get my 32 inch envision tv to change channels and it won't change at all!! I need to get it to channel 73 to work with my box free dish dvr that's in the other room!! Any suggestions??...
We would be happy to help with that. Some TV's do not havethe ability to go as high as channel 73; this may be the case for yourEnvisionTV. We would recommend changing the channel that your DISH Networkreceiver outputs the picture for your TV2. Start by pressing the"Menu" button, from the main menu press 6 for "SystemSetup", then 1 for "Installation", and then 5 for"Modulator Setup". Under TV2 we are going to change the mode to"Air", the channel displayed beside it should change to 60, selectdone on the right side of the screen to save the changes. Now change thechannel of your TV2 to 60 and you should get the DISH Network programming.
We hope this helps. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 14, 2011 | Envision L32W761 32 in. LCD TV
I need to get to channel 73 to connect to Satellite Dish network, but it keeps telling me there is no channel in list ???? what do i do..Thanks
We would be happy to help with that. Some TV's are not ableto go as high as channel 73. This sounds like you're having an issue with yourTV2, this would be the TV located in a different room than your DISH Networkreceiver. Go to the main TV by the receiver, press the menu button located onthe top left of your DISH remote. Once in the main menu, press the numbers6-1-5, this will take you to the "Modulator Setup" screen. Once there we want to highlight the "Air"option located below "TV2 Out" then press the select button. TheChannel should change from 73 to 60. Change the channel of the TV you arehaving an issue with to channel 60; you should get the DISH Network programmingat that point. We hope these steps help you get that fixed. Thank you for beinga valued DISH Network customer!
Phillip Chang
Oct 16, 2010 | Haier HTF20 20" TV
Other room remote changes channels on BOTH TVs
turn off the uhf from you reciver in main menu set up funcion remoto control
Apr 07, 2010 | Toys
The two TV are synced. Do I unconnect them? I have one TV in the living room, one TV in the bedroom. Whenever the TV in the bedroom is on, it is on whatever channel is on in the living room. Both remotes...
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
Aug 15, 2009 | DISH Network IR Remote Control
Remote changes channel up but not down
Could be a bad remote controller(well button inside the remote:) ) . Try front function, if works the bad remote control. :)
Apr 14, 2009 | Hitachi 43FDX01B TV
Channels flipping non stop
Ether the front panel channel button is sticking or the remote channel button. take the remote out of the room.. if it still is changing channels make sure the channel buttons on the front of the set are not sticking. Spay a little WD 40 on them then wipe them off
Dec 03, 2008 | RCA F32649 32" TV
Dish Network DVR
You have what is called a diplexer in the back of the the receiver in the front room.It looks like a splitter.If it is put back on in the wrong way you will have a fuzzy screen.look at the diplexer,you will see in/out which would be the input on a regular splitter,then you will have one side that would be one of the 2 outputs that will say SAT,the other side is UHF/VHF.The chances are that when you plugged them back in you had them swapped.Try changing the 2 cables around.If that doesnt work try changing the assigned channel to 68.You can also try doing a auto channel search on the tv in the room without the receiver.this will find the channel that the front room receiver is broadcasting the signal on.Chances are though that your diplexer wires are configured incorrectly.remember,the in/out should plug into the back of the receiver (satellite in)and the UHF/VHF should be going to the other room with the problem and the SAT side of the diplexer should be wired to the satellite dish.GOOD LUCK! rate me with the outcome please.
May 09, 2007 | RCA DISH Network(r) 311 Satellite System
Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Dec 18, 2006 | Sony KV-27V42 27" TV
DISH Network 135899 Remote Control Logo
111 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
