Question about Danby DAR483BLS Compact Refrigerator
The beverages are not cold adjustment is turned 3/4 of the way to the right. could the refrigerant need to be replaced?
Kegerator gets cold but will not not stay cold. its like unit shuts off after it reaches cold
You may need to replace the thermostat. Sound like it works until the low temp setting is reached and then can't maintain that temperature. Given that it will turn the machine on when the refrigerated compartment is warm this implies that the thermostat works until it breaks the connection when the low temperature target is reached.
Jan 07, 2014 | EdgeStar KC2000 Beverage Cooler Commercial
Refrigerator runs and will not shut off, keeps getting colder and colder no matter what setting I put it on?
I have the same problem. My 7 yrs old Beverage Air model MT27 got very cold even with temperature control set to almost off position. It froze all the water and pops in it. Somebody have the solution?
Oct 12, 2011 | Beverage-Air MT27 Beverage Cooler...
Won't get cold one of the copper tubes has a hole on the tip and air is coming out is that right
Hello Ramrecycling,
I understand that you are having a problem with your commercial beverage cooler. If I understand right that one of the refrigerant lines have a hole and the refrigerant is escaping from the unit. This will cause the unit not to get cold as the refrigerant is what produces the cold temperature when the fan blows are over the coils.
I am sorry to inform you that this is not a DIY project as it requires many special tools, vacuum pump (recovery unit), refrigerant gauges, scale, and more items that the common DIY does not own or wish to purchase at a costly price.
I would check with local HVAC contractors and tell them that you have already located the leak in the system and what the cost of patching and recharging would be. Then I would look at how economical it would be to fix or just replace the unit.
Thank you for choosing FIxYa.com
Justin
Mar 29, 2011 | Beverage-Air DW64 Beverage Cooler...
My danby beverage centre does not cool anymore 3 years old. compressor is hot. fan sounds and appears to work well all coils are clean.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ,.,
Oct 06, 2010 | Danby DBC514BLS Silhouette Beverage Centre
Bev Air BB78-1 not cold. Losing freon thru condenser?? Condenser completely rusted.
Replace the condensor if this is not a option which you can buy one then you will just need to replace the system all together
Apr 29, 2009 | Carrier Beverage Air BB78-1 Beverage...
Marvel beverage refridgerator is not staying cold anymore
Make sure you have 3-5" of space all around, otherwise it keeps sucking its own hot air and reaches 'equilibrium' and won't get any colder. Ever
Jan 15, 2009 | Refrigerators
Beverage air cycling off/on
These units are not designed to run in temps much lower than 50 degrees. They have no winter controls and the freon pressures will take a nose dive when running in a cold ambient condition. The unit will not run well in a cold environment, compressor damage may result. :(
Dec 16, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Beer Not Cold!!!
There is a temperature control knob on the back side of the ref. it is on the bottom by the compressor
Have you adjusted this?
clayfoot
Aug 09, 2008 | Frigidaire PLKU1267DS Stainless Steel...
Refrigerator Keeps running
Replacing the thermostat should correct the problem. Be sure to install the thermstat exactly as the one you are removing, assuming it hasn't been changed prior. Hope this helps
Jun 10, 2008 | Beverage-Air Beverage Air KR48-IAS 44.9...
Danby DAR483BLS Compact Refrigerator Logo
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
