Question about Midland LXT310 2-Way Radio
Can i get replacement rechargeable battery packs
    President:
  • 2,761 Answers
The best deal that I found on your batteries is on eBay, and you can follow this link to the sale:
http://cgi.ebay.com/2-Midland-AVP-7-Rechargable-NI-MH-Battery-Packs-BATT5R-/160368242370?pt=2_Way_Radios_FRS&hash=item2556b12ec2
If you're not an eBayer, you can also purchase the batteries here (for a bit more):
http://www.123radios.com/BuyItNow.asp?PID=1222
Bill B.
Posted on Nov 15, 2010
My INSIGNIA NS-PDVD10 portable DVD player will not power up. Can you help me identify the problem? Will the rechargeable battery go bad in this device?
Of course the battery will go bad , nothing made by man ever lasts forever . it may need to be sent it for replacement of battery .
Oct 16, 2015 | Insignia NS-PDVD10 Portable DVD Player
How to repair ridgid r82007 battery?
check the charger first for correct operation
power tool batteries are prone to memory block so if you do not completely drain a battery ,it will recharge only to the last voltage point recharged
to ways to fix
take it to a battery shop that may be able to force charge the pack
have the batteries in the pack replaced with better quality batteries
buy a new battery pack from an authorized dealer
Sep 06, 2015 | Ridgid Drills
My GRE PSR295 scanner wont switch on
first off check your batteries. if you are using a rechargeable battery pack disconnect it and try it off the power supply alone bad battery packs can and generally do keep radios from powering on. If this allows it to come on, try charging it for 24 hours, and then deep cycling it several times ( run the scanner with sound such as on a noaa weather channel) until it goes dead and then recharge, to recondition the battery pack. if this doesn't work the pack will need to be replaced or rebuilt (batteries plus can do this) if the radio just uses discrete rechargeable batteries simply replace them. meanwhile I'll look for a manual for you....
Here you go
http://www.manualslib.com/manual/703072/Gre-Psr-295.html#manual
Feb 16, 2015 | Radio Communications
Battery will not hold charge
This is an indication of memory in a battery or failing battery in the pack. Batteries should be run until they are flat then recharged and never recharged when they are part charged as they develop a memory of that charge point that the charger cannot overcome and will not charge past. If the battery in a pack has failed then there are battery re-acker shops that can replace batteries in a pack cheaper than a new battery unit and most probably with better batteries.
Jul 27, 2013 | kawasaki Drills
I need a replacement rechargeable battery
I would try Google if you have not----most of these battery packs have a generic number right on the label on the battery, did that recently for a friend looking for sealed packs for a large electric scooter, inside found the generic one indicated.
Aug 28, 2012 | Durabrand DUR7 Portable DVD Player
Revive drill driver battery packs
Rechargeable batteries do have a lifespan, they won't recharge forever. If you have fully discharged the batteries then fully recharged them and they still don't have full power or they only last a couple minutes then they are done. If they won't charge or the charger shows them as defective, the only fix is to replace them.
Jan 29, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Need to replace battery back-up pack. Have any
Oh wow. You have an old timer there. I think they used a rechargeable 3.6Volt pack so you should be able to use any old rechargeable nickel cadmium or nickel metal hydride 3,6V battery such as out of a cordless phone. try a local electronics shop.
Mar 27, 2010 | Casio Parts Cash Register PC Desktop
I have the same problem the charger won't charge and states it's broken. on 2 of my 6 batterys when will the next go?
the battery pack has a number of small batterys in it any one of them can go down on you and then the hole pack go's dead and refuses to charge, if you can get the battery pack apart you could fix one pack by taking a good battery from one pack and replacing the dud one in another pack,the real secret is dont knock the batterys right out, recharge them before they go completle flat,,,and dont ever leave them flat or they will go into whats called a "supper discharged state" if they do there never going to recharge
Nov 16, 2009 | Makita 18V LXT Circular Saw
Dvd battery
Hello sara_lou,
I have 2 suggestions for you:
1) Look into purchasing an external rechargeable battery pack for PDVD units (available at Best Buy). It is an external pack that will connect to the players AC port.
2) Prepare for surgery! You will need 6 rechargeable AA batteries, a soldering iron, super glue, and patience.
You'll need to open the battery case and look at the batteries within. Note the direction and polarity of all the batteries and how they are wired/soldered together. You will need to replace all these batteries with the new ones you have purchased. Wire together the new batteries in the exact same order and polarity as the old dead ones. Remove the old ones and replace with the new ones. Solder in where necessary and be sure not to bridge any contacts. Put the case back together with a little super glue on the seam. Replace into the PDVD player when the battery case is dry (or else you may permanently mount the battery case into the player) and set to recharge using the AC pack. if everythign was wired correctly, you should have a charged battery pack in about 1 hour (since most rechargeable batteries come with 3/4 charge in them).
While I don't recomend this second solution, it is plausable for the hobbiest electrician or DIY-er.
Best of luck to you!
Jul 20, 2008 | Insignia IS-PDVD10 Portable DVD Player
Midland LXT310 2-Way Radio Logo
313 people viewed this question
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
