Question about Supersonic SC-22D DVD Player
I messed up with the video settings, and now I cannot get a signal. I guess that I am still accessing the menu, but cannot see where to change the settings because there is no picture. Maybe a reset to factory settings can help, but don't know how to do it. Thanks I have a Supersonic sc-22d
  • alfredo_gome Nov 15, 2010
    Sorry Joe, but that solution is far from what I am looking for. I messed with the video settings on the dvd, and need to reset it to factory settings. Can you help with that???
  • 10,865 Answers
Hello Alfredo. turn on the tv and the DVD player. Use the tv remote and push the input key. When you do that you will see a list of choices. One of them is DVD. Click on it. That said, if that doesn't give you a picture from the dvd, go down through the list one item at a time and you will find it. Joe
Posted on Nov 15, 2010
  • Supersonic Master
  • 19,396 Answers
Hi Alfredo.
I am afraid that the only reset available is a software update. Unfortunately Supersonic did not provide any software for this model. Service documentation is also not available.
In some of the Supersonic receiver units you could press the two channel buttons and disconnect the power cord from back side and connect it again while still holding the button. This will not work on a DVD unit (there are also no channel buttons).The reset of this unit is done using a factory upgrade disk, which is not available.
The best way to find out if there is an alternative solution to the problem is contacting Supersonic with this online form, or calling them at the number listed on page. Click Here.
1080p from ps3 through rx v563 not working
It is likely then that your receiver does not support the progressive scan signal.
However, it is not a requirement to run your video signal through your receiver and doing so most of the time creates problems in instances where the video signal processing that it is performing is the same as what your TV would be doing. This causes problems like the one you are having. It is the equivalent of attempting to stir a pot of soup with identical spoons but they aren't synchronized so they conflict and make a mess. It is only in those instances where a receiver has video signal processing capabilities that your TV does not, that these common connections found on them are useful, i.e.; video upscaling. But most modern flat panel TV's already do that be default automatically and disabling it often requires service menu access.
The best possible video will be achieved with your equipment by connecting your PS3 directly to your TV. If you need additional inputs for the TV, the use of a switch box is best.
Jan 19, 2012 | Yamaha RX-V563 Receiver
EasyCap - ''no input signal or signal is unclear'' Please Help!!!
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Hope this helps.
Goodluck
OAC
Mar 06, 2010 | Ulead Videostudio 8 for PC
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
Polaroid DVD recorder need to re-set up can't see menu
If you're using a SCART lead, bin it and get a new one, this seems to work best in most cases
Hope this helps
Alen Boardman
Feb 13, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Color is washed out ,almost black & white
Good Day;
Washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Good Luck, big IRISH. PS: don't change any other setting!!
Sep 07, 2008 | Mitsubishi WS-55315 55" Rear Projection...
When there?s any bright white light, the unit just loses the signal .
Good Day, littlejhon4u;
Try this and/or try using different input: White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0157" use the audio button to select "video chroma" adjustments, use the video button to select item "68 - AG1", use the adjust button to change the setting to 0, then press the enter button to store the change. Good Luck, big IRISH. PS; Adjust this ONLY.
Aug 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
COLOR &CONTRAST NOT GOOD
Good Day, LEE-M;
Try this :
White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change. Good Luck, big IRISH.
May 20, 2008 | Mitsubishi WS-65315 65" Rear Projection...
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Sometimes it takes a minute to get Reception
Dec 11, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Supersonic SC-22D DVD Player Logo
272 people viewed this question
Top Supersonic Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jason Morris
Computer Repairing
Computer Repairing
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
