Question about Asko D1776 Stainless Steel Built-in Dishwasher
F2 overfill. how to reset? - Asko D1776 Stainless Steel Built-in Dishwasher
  • Asko Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description "f2 overfill. how to reset?" It is likely nothing very serious.
The "F2" with Asko dishwashers means the control is indicating an overfill has been detected...but I gather you know that based on your post.
Whether the unit has actually overfilled or not remains to be seen, but to reset it is fairly simple...if nothing else is at fault.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. If water is present, with the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base.
By way of removing the water from the overfill basin should "reset" the unit. If the unit works fine after resetting the power/breaker it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump.
Try this and let me know what you find and I`ll assist you in moving forward if necessary.
Thanks for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on Nov 15, 2010
I have an asko T760 Butterfly dryer. It is stuck on P2 but will not run. I shut off the unit, turned back on. The LCD flashes between P1-P4 and what they are, such as extra dry, dry, normal dry, & iron...
Hi.
The machine is telling you that there is overfill, f2 and 4 are faults with overfill system. Lights blinking, pump running and controls dead also indicate an over fill fault :
"1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray"
Here all diagrams.
Regards.
Ginko.
Apr 26, 2011 | Asko T761 Electric Dryer
What does F2 mean
Hello, Welcome to FixYa. To answer your question..."What does F2 mean ?", the good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part. F2 means the control has indicated a overfill. This is meaning the overfill switch is indicating an overfill has been detected. Whether the unit has actually overfilled or not remains to be seen. It may in fact have been caused by a long drain or backed up drain. I'm presently on my iphone so I can't post the pertinent info to resolve the error directly, however if you copy and paste this link to your browser all the info will be there and it will apply to your model Asko as well. http://www.fixya.com/support/t7832382-f2_mean Either that or visit my profile page and you'll see other post relating to the Asko F2 error, its meaning and remedy. Hope this helps, let me know and good luck. Regards, Macmarkus :)
Jan 17, 2011 | Asko 24 in. D3250 Built-in Dishwasher
What does F2 mean?
Welcome to FixYa.
The first thing to do is remove the toe panel/kick plate and inspect the base for water. If water is present, with the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if a problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump so you'll need to pay close attention the next few times you run it)
...If not, there are a couple of other possibilities that I'd focus on.
**Again insure power to the unit is off**
The first is the float and subsequently, float switch. If you've removed the service panel at the bottom, or toe plate, you need to locate the float and it's switch. It will be located directly behind where your main electrical junction is...
i.e.
Once you've located the float behind the main connection plate, you should see something like this image below,
i.e.
With the aid of a long screwdriver or if you can reach it, move the float up and down and listen closely for the switch to "click", indicating it is indeed functioning.
Restore power again, and see if this resolves the issue, if not try this next...
The pressure switch too can cause the drain/outlet pump to run constantly ( and usually all the lights to flash or "F2"...depending on the era and model of the Asko...ones with displays show F2 and lights flash ).
As I was saying the pressure switch is the component which controls the normal fill level and the overfill detection...pre float activation. The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit to service or call for service to the unit.
It too is located under the machine and is mounted to the sump well assembly as shown, the large arrow indicates the switch while the small is the hose.
i.e.
The issue is possibly just the hose going to the switch is clogged with debris such as dirt, detergent buildup etc and will be remedied by blowing it out.
The best way to do this is to remove this hose at the switch in the location indicated above, be very careful as to not break the hose off with the part of the switch inside, they can be delicate.
I typically work it loose with a tiny screw driver gently working it away from the switch. Once removed, pour a small amount of hot water, white vinegar or "CLR" through the sump from within the tub...or you can try blowing it through with "lung power".
The other end of the hose is located at the back of the sump well and is quite vulnerable to blockages over time due to detergents, dirt, and such.
This is the location...do not break this or you will need to replace the entire sump well...no fun.
Large arrow is pointing back to pressure switch, small indicates connection to sump well, sorry for the poor quality...it's hard to get in there with a camera phone, ha ha !
i.e.
That's almost the extent of the possible causes of this error. Of course it could be the pump as I alluded to, a pressure switch has failed, the float switch has failed, but not likely.
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary.
Good luck.
Regards,
Macmarkus :)
Jan 15, 2011 | Asko D1776 Built-in Dishwasher
Model#1885 giving a F2 error code
Welcome to FixYa.
Based on your description "model#1885 giving a F2 error code", the good news...It is likely nothing very serious, but the "reset" requires some investigation on your part.
The "F2" is an error indicating an overfill scenarios for Asko dishwashers of this era. This is meaning the control is indicating an overfill has been detected. Whether the unit has actually overfilled or not remains to be seen.
In the event it has, the outlet/drain pump motor is automatically turned on via either the pressure switch or a float in the base if sensing an overfill and removing water from inside the dishwasher will do nothing to resolve this error, but you can...
**again insure power to the unit is off**
i.e.
i.e.
The pressure switch too can cause the drain/outlet pump to run constantly ( and usually all the lights to flash or "F2"...depending on the era and model of the Asko...ones with displays show F2 ).
As I was saying the pressure switch is the component which controls the normal fill level and the overfill detection...pre float activation. The float is primarily the last ditch safety to notify the user in the event of a overflow, back-flow, or leak underneath the unit to service or call for service to the unit.
i.e.
i.e.
That's almost the extent of the possible causes of this error. Of course it could be the pressure switch has failed, the float switch has failed or ultimately the control has failed, but not likely.
Good luck.
Regards,
Macmarkus :)
Dec 03, 2010 | Asko 1385 Dishwasher
F2 lights indicated. pup wont stop when machine turned on. no water in cabinet. course fine filter removed. yellow plg removed to check for obstructions. none found.
Welcome to FixYa.
Based on your description " f2 lights indicated. pup wont stop when machine turned on. no water in cabinet. course fine filter removed. yellow plg removed to check for obstructions. none found." the good news...It is likely nothing very serious, but the "reset" requires some investigation on your part.
The "drain stuck cycle" or "F2" ( I presume you mean drain pump running constantly ) are directly related with overfill scenarios for Asko dishwashers of this era.
i.e.
i.e.
The pressure switch too can cause the drain/outlet pump to run constantly ( and usually all the lights to flash or "F2"...depending on the era and model of the Asko ).
i.e.
i.e.
Good luck.
Regards,
Macmarkus :)
Nov 24, 2010 | Asko D1796FI Built-in Dishwasher
Display reads f2
Welcome to FixYa.
Based on your description It is likely nothing very serious.
Regards,
Macmarkus :)
Nov 16, 2010 | Asko 1385 Dishwasher
What does code F2 mean?
Hi, Welcome to FixYa. The "F2" for Asko dishwasher indicates an issue with the unit overfilling. This can be caused by several things, faulty inlet valve, drain pump, a plugged fill switch/overfill hose or a leak which causes the overfill switch to actuate or even a plugged drain hose. ( if you wait a couple of days it may in fact start working as the water in the base evaporates ) I would start by removing the bottom toe panel to see if the base is full of water and then check the drain hose where it connects to your home plumbing. Of course make sure you turn off the power at the breaker panel. If you don't feel like these are things you can check I'd recommend calling an authorized Asko service provider. Let me know what you find. Macmarkus :)
Aug 15, 2010 | Asko D1776 Stainless Steel Built-in...
What does FL mean when it comes on washer ?
Flood condition "FL"
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
***If there was not an Overfill condition and, the SUDs were not present when this alarm was initiated, thsi will confirm a faulty Overfill switch and, it should be replaced.
Press STOP/CANCEL to clear the display.
Jul 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing fl error code
Jun 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
F2 overfill status, but no water
It sound that the problem is cause the water level switch (stuck in the "full" water position). The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear first any obstruction in the tube, In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
Apr 11, 2007 | Asko D1716 Built-in Dishwasher
Asko D1776 Stainless Steel Built-in Dishwasher Logo
1,634 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
