Question about HP Pavilion dv6000z Notebook
My hp6000 Turns on for only a second. Every now and then it will remain on for ten seconds and then shuts off. I get no picture whatsoever but i can hear the fan click sometimes.
  • 757 Answers
I had the same problem, then I replaced the DC jack and it worked for a few days. It turns out that these HP models have a very high failure rate of the motherboard something to the like of 85%, and it sounds very much like what has happened to yours.
However, the root cause of that problem is the motherboard capacitors. There is a chance that being able to replace just those components *may* solve the problem and it won't cost much to find out.
The capacitors in question are the black square shaped ones that are protecting vital components on the motherboard...when they fail then there's no protection. They are soldered onto the board directly beneath where the end of the copper tubing extends to in the cooling fan heat-sink just beyond the CPU. There will be about three of them mounted next each other, one or all them may have the appearance of starting to melt. De-soldering these could possibly solve the motherboard problem and it wouldn't cost much to find out. But if you sent it away to have it professionally repaired, they will likely just want to replace the entire motherboard and it would cost about as much to do that as it would to just buy a new computer.
Posted on Nov 15, 2010
Leapfrog ipad ultra black screen white dot
During a normal shut down, the screen image on a LeapPad will reduce to a white dot, which will disappear in five to ten seconds.
In rare circumstances, the white dot will not disappear and the LeapPad will not fully power down. If the LeapPad does not complete the shutdown process and the white dot remains on the screen for more than ten seconds, complete the shut down by pressing and holding the power button on the LeapPad for ten seconds. This will fully power the LeapPad down, and it will start up normally next time you power it on. For more information contact essay writing service reviews
Essaypaperreviews com Best Writing Services Reviews online
Dec 27, 2013 | LeapFrog Toys
Turn the tv on picture come on all red and fuzzy and then couple seconds later tv turns off and then turns back on with no picture just red screen then turns off and wont turn back on for ten min
It indicates a short at the Red picture tube--set has three picture tubes and each has a socket which processes signal to each tube--each has a single IC chip---in your case either the chip on the red board or the red tube.
If a bright red screen the set will detect something is pulling way too much current and shut the set down for protection---called a shutdown circuit.......
Apr 13, 2012 | Televison & Video
My problem started out pretty confusing. One day I turned my lap top on and the screen, after about five to ten seconds of being on, went black. I could see things loading up sort of but the screen was too...
Darkened screen as you describe indicates a failing inverter. You can test this easily by plugging the laptop into an external monitor, if this works ok, then the inverter needs replaced, If it does not work, the problem is with the graphics chip / motherboard
Jan 18, 2011 | Dell Inspiron 8000 Notebook
Auto shutoff d300 nikon to save batery on case of forgoten shut down
If you navigate through the menu system, you will find several items of interest on the Custom Settings menu.
Item c2 controls how long the exposure meter remains active when no operations are performed. It ranges from four seconds to thirty minutes, and also has a "No limit" option.
Item c4 controls how long the monitor remains active when no operations are performed. It ranges from ten seconds to ten minutes.
Jan 13, 2010 | Nikon Cameras
Turns on when I push the butten then shuts off
Try soft reset :
hold lap/reset and mode buttons for ten seconds, then release and wait 10sec, then hold start button for 10 seconds, device should start
Jan 11, 2010 | Garmin Edge 305 GPS Receiver
Picture turns on for ten seconds then shuts off and the temp and power blinks red. thanks!
you need to make sure all of your filters are clean. if they are you need to remove the plastic covers and make sure all of the fans are working. they burn up and the power supply may need to be reapired. we repair them auburntechnology.com
Dec 30, 2009 | BenQ PB6100 Multimedia Projector
Tv turns itself off after bout ten seconds
Your over voltage circuits(hi-voltage and low voltage) are defective.When the voltage exceeds the specs it shuts off the tv.Unless your a service tech,you can't fix this.There are components on the main circuit tha t have to be changed.Sorry, no easy fix.
Jan 03, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
I loose picture on my big screen
bad voltage regulator - BA09FP requires a bit of tech experience to replace, but its relatively easy. It took me about 1 hour to replace mine. If you need clarification on this, email me at Doin12volt at yahoo
Jul 03, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Model kdp65ws550
High voltage protection. Either transistor Q8014 04 Q 8013 is shorted along with R8051 on the D board or IC 8005 is defective on the D board. Let me know if you need more assistance
Apr 22, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
