Question about Electric Eyeware Redcat Racing Volcano EPX PRO Truck 110 Scale Brushless Electric
My Volcano EPX Pro was purchased rtr. With a fully charged battery, if I punch the throttle wide open, instead of a smooth, quick take off, I get a herky, jerky start. After a couple of seconds its blazing. Cant race like this. Any help would be great. Thanks.
So I have the same problem with mine, and it's fairly new. It looks like its a combination of two things. One the ESC isn't working properly and needs to be replaced (hopefully the company I bought my truck from will replace, I still haven't heard back from them), and two the gearing seems to be abnormal, the team at my local hobby store recommended a small gear on the motor (the stock is 17 and the buy at the store seemed to think that it was huge) so if you get a small one (15 pinion I think is the terminology) it puts less stress on the motor. The top speed will be reduced apparently but the gearing problem is resolved. Other things they suggested where replacing the metal main diff gear with a plastic one, or lighter material one as well; hope that helps; if the company doesn't replace my esc I am strongly considering buying a new motor/esc combo from the hobby store and hopefully sort out both problems with one purchase.
Posted on Dec 31, 2013
2016 Arctic Cat ATV 450, gets fuel and spark, won't start. tried new spark plug, fully charged battery, no codes, only has 230 miles on it
Hey Mad Bear, check the compression, you should get 120psi + minimum,,, hold the throttle wide open and spin the motor for 5-8 seconds... reply on here with results,, thanks
Mar 27, 2017 | ATVs
Can i use a tenergy nimh 7.2 v 3800 on my battery operated rc car, the infinitive ep rtr off road truck?
Never exceed the recomended voltage but the 3800Mha is a measurment of how long the battery is likely to last. The higher the number, the longer it will last
Jun 23, 2014 | NitroRCX.com 1/10 exceed rc brushless pro...
Red light blinking
either that or it may be getting interference from another radio source like a cordless phone or old celphone..or bluetooth..any radio waves closeby will affect this..
Feb 02, 2014 | Redcat Racing Volcano Epx
EY3530NQMKW
I would suspect poor quality batteries in the battery pack or memory in the pack from recharging a partially charged pack instead of letting it work to flat condition. New batteries take hours to fully charge so if you just plugged in the charger for a short time before use then the battery pack may nit have been fully charged to start with.
Jul 23, 2013 | Panasonic EY3530NQMKW 15.6V Cordless Metal...
Rc truck
There should be a switch on your controller that says forward or reverse, you can switch it to run the way its supposed to
Mar 31, 2013 | Team International Associated Sc10 Short...
Batterys are fully charged when i open it up it just clicks when upull back the throtal
Check all the connections. Purchase a replacement throttle assembly.
Oct 29, 2012 | Razor E100 Electric Scooter
Ford Fiesta 1989. Starting problems
Hello! i would suspect the Carb fuel bowl vent level clearance..
Mechanical Fuel Bowl Vent Lever Clearance Adjustment
Secure the choke plate in the wide open position...
Turn ignition key to the ON position to activate the Throttle Position Sensor (TPS)... Open the throttle so that the TPS plunger extends fully.
Verify that the throttle is in the idle set position (contacting the TPS plunger)... Measure the clearance of the fuel bowl vent arm to the bowl vent actuating lever. ..Fuel bowl vent clearance (dimension A) should be 0.03 in. (0.76mm)...See diagram below...Guru...saailer
May 06, 2012 | Ford Cars & Trucks
2005 Sportsman 700 EFI - Throttle stuck wide open. All cables move freely, opened throttle position sensor - butterfly valve opens smoothly with thumb throttle but valve does not close all the way even...
you will have to have a nulti meter and unplug the sensor and che the ohms on the sensor when you move the control, it should move up and down on the ohm numbers smoothly if jumps as you apply throttle then you have a bad sensor
Sep 26, 2017 | Polaris ATV
After a short highspeed acceleration and then suddently drive slow or just stop for traffic lights, sometimes the engine just doesnt rev anymore. Then I have to open the throttle very wide just to continue...
but is the fuel going to carbs or injectors--also chec fawcett at tank--if theres a fuel pump it may be failin--those hispeed spurts consume much petrol no wheelies
Sep 27, 2010 | 2007 Yamaha YZF-R1
I get it started it runs as long as you have it wide open but you let of the gas it dies
This might require adjustment of the hi speed carb screw, the lo speed, and the idling screw as well.
The engine needs to be good and warm, you need to be certain you have a fresh fuel mixture in the tank, and you should check the air filter because it too affects the way the saw will run at low speed and idle.
I would start with the hi speed adjustment screw since wi does start. Fire it up and run it a bit to make sure you have it warmed up.
You may need someone else to help you hold the saw while you make these adjustments. With the throttle wide open, turn the hi speed screw slowly, in increments of 1/4 turn, to the left. It may be just a bit off. The objective here is to turn one way until it sputters or runs a little rough. Then turn it the other way until the engine smooths out. Continue to turn in the same direction until it again runs rough. Then turn back about halfway between those two points.
It should run well at wide open throttle. Place your screwdriver in the low speed adjustment screw and turn to the left, in small 1/4 increments like you did before. The objective here is to adjust to the point where the saw will throttle up quickly and smoothly, and more and more from an idling position, or as close as you can get.
If you find you don't get that, and the ramp up is choppy and unsmooth, adjust in the other direction. Eventually you should get to a point where you have quick response to your throttle. You should get to a point where it runs without being wide open.
If it fires up easily and throttles up smoothly but won't idle, the you need to adjust the idling screw. Adjust it until the chain begins to move on the bar when you let the throttle go. Once you get to the point where it idles with the chain moving, back off the adjustment until the chain just stops moving.
Make sure the air cleaner is clean. You may have to clean the carb with spray carb cleaner while it is running at full throttle. If you do, spray a tiny bit at a time, as it will almost kill the engine.
Finally, after all this work, invest in a new spark plug, even if the one in it isn't that old.
Sirwriter
Jun 15, 2009 | Garden
Electric Eyeware Redcat Racing Volcano EPX PRO Truck 110 Scale Brushless Electric Logo
152 people viewed this question
Top Electric Eyeware Toys Experts
Andrew Taylor
Andrew Taylor
Are you an Electric Eyeware Toy Expert? Answer questions, earn points and help others
