Question about Nintendo DS Lite Console
Almost there i think
No it doesn't rattle but ive tried to clean it once i could try again if neccasary.
  • EAB1
    EAB1 Jun 19, 2008
    thz
  • EAB1
    EAB1 Jun 19, 2008
    No but ill keep tryin.
    Champion:
  • 268 Answers
Keep trying, i tried it with mine and now it works like a charm but my little sis has lost it so thats a bummer, also try using paper towels on the card not damp (obviously) or even try holding the card down when you turn your ds on
Posted on Jun 19, 2008
Rattling and engine light when i accelerate
sorry would need a drive to know whats wrong but you havent stated if this is a diesel or a petrol version .
Dec 22, 2012 | 1994 Ford Explorer Limited
Hi i have an avensis verso d4d 2litre diesel 2003 its lacking bad on power
Mr Allan first thing you must do is to renew the fuel filter,check if there is any other filters and then if you still have any old fuel in tank drain it,fill it up with a clean diesel and my personal advice as an automotive engineer try what I do personally,ask from a petrol station if they sell- " TWO STROKE OIL " yes is the oil use in mixing with petrol for mopped motorcycles. Use 250ml in tank full of diesel ,-full tank to empty -before light comes on and re-use again 250ml for another full tank and continued for four times. It is also good to do this even for two times filling every two months,. Two Stroke Oil has the power to clean and lubricate the feeding system of a diesel engine also treats the fuel injectors even when you might hear them working rough. It is like a cough medicine. Try it and let me know.
Sep 08, 2012 | Toyota Verso Cars & Trucks
My xbox 360 doesnt want to read the game. when i put in gears of war, it tells me to open tray. i open it then close it and again it tells me to open tray. ive done the clean cd and still the same thing....
Unfortunately this is a common issue with the xbox. If you have tried all the steps that are provided on the xbox support website, it may be time to call xbox support and get your xbox repaired. If it is out of warranty, I'd honestly just get a new one cause the repairs run about $120 out of warranty.
Aug 17, 2011 | Microsoft Xbox 360 Console
Water pressure low in dishwasher sprayer
Hello; the VERY first thing I'd check, which is the most common cause for this problem, is plugged sprays. The spray nozzles are usually easily removed for cleaning. Often, you can see debris that is stuck in the spray holes partially protruding. Be careful when pushing it back through the holes, often there are bits of broken glass in it. NEVER PULL the debris OUT, which would enlarge the hole, and misalign the spraying action. Push the debris back IN, then remove it through the connection port by shaking it. Spread a paper towel over the area where you do this to catch the debris, again being careful of the glass.
A good way to find out if you have removed all this stuff, which includes old food particles, plastic, etc., is to sharply rap the spray against a padded object, then shake and listen for rattling. When this procedure doesn't produce a rattling noise after several "raps" the spray is probably clean. Cleaning these nozzles once in a while, even before you notice a problem, is a good idea, as it improves the efficiency of the dishwasher.
Alec
Jun 04, 2011 | Dishwashers
I have an older Miller Furnace in a mobile home that I own. The unit was made around 1977-78. Think the model number is MGC-80-1. It does two things that seem odd. 1st is it will kick on like it should,...
sounds like the fan control is playing up try cleaning the back of it could have dust in it cleaning my help fan could be a loose spindal which the fan spins on see if this helps
Nov 06, 2010 | Heating & Cooling
The heat shield keeps rattling. Should i have it removed?
its there to prevent a fire happening from the heat of the catholitec converter , say if you park over dry leafs or something it can **** them up and ignite. ive removed mine since i drove over side of cliff, hahaah but its fine i think once u dont go parking over dry leafs.
Dec 04, 2009 | 2004 Toyota Camry
Engine rattles
if it has a distributor, try advancing it a bit. probaly off a bit
Aug 30, 2009 | 1994 Chevrolet S-10 Blazer
Epson 4800 set ink crtg error
Check the following information for reset the printer cartridge.......
http://www.fixya.com/support/t2689003-set_ink_cartridge_invalid_ink_cartridge
hope this helps you.
Oct 30, 2008 | Office Equipment & Supplies
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
Camera Not Working Wirelessly
I think maybe the problem is that the cam has already been recognised and given an ip address when you connect via RJ45 cable, but when you try wirelessly, there is a replication of the ip address which is not allowed. Check your router to see what ip address was given to the cam and remove if neccasary so as to re new the cam ipaddress. I would turn off the encryption first to try and get it working, then turn on again.
Feb 08, 2007 | Trendware TV-IP400W Network Camera
Nintendo DS Lite Console Logo
16 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
