Question about Tomtom GO 910 GPS Receiver
No battery power
My 910 just started going dead once the power supply from the lighter plug was disconnected. I have powered the unit up on the docking station with the same results. Did the battery suddenly die or is there a fix for this?
  • Anonymous Jun 23, 2008
    Funny....exact same thing started happening to me since yesterday, the 22'nd.
  • Anonymous Jul 01, 2008
    Same here, after I picked the preference to turn off after disconnecting from power. Then I unselected it and now it won't turn on at all except on base.
You can set the Battery options from the Preferences Get to the screen which asks if you want o turn off, an dthen accept. The next will ask if unit should be turned off every time power is interrupted. Select NO
Posted on Sep 26, 2008
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
Jan 16, 2013 | Dell Inspiron 1545 Notebook
My bose sounddock portable system suddenly stopped working so I thought it needed charging, when I plugged it back in to the mains it wont charge and no light comes on the system at all it's totally...
Guys - she has the protable!! Hi Fiona, the best bet is to visit and check the SounDock Portable diagnostic video. (Repair video is there too) Remove the battery and plug the power in., If you get a beep-beep sound then the unit has power and is booting up so you need a docking connector replacement kit. . If there is no beep beep then it is the power supply or the main unit. (Try a different power supply) . If it works normally then it is the battery - get a new battery. Hope that helps.
Sep 30, 2011 | Bose SoundDock Portable Digital Music...
I have a Latitude D630 laptop and I recently purchased a docking station to use with it. I tried my laptop's PA12 Power adapter When I initially connected everything and placed the laptop on the dock an...
Try updating to BIOS to version A16 from Ensure you are not attached to the docking station when flashing the BIOS. Once updated, connect the 90W adapter to the docking station, connect your laptop to the dock, and power on using the docking station power button.
Nov 13, 2009 | Dell Docking Station for Latitude D600
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Teac sr-l200i, the ipod dock just started malfunctioning in the last hour. When I dock the ipod there is barely any sound. This is the case for all my ipods on this unit. The ipods are working on all my...
I had the same problem but with a different TEAC docking product.
My TEAC would not recognize my ipod therefore I was unable to control my ipod via the docking station remote control.
Plug your ipod into the docking station and power down (reboot) your ipod. Once the ipod powers down (in the dock) restart the ipod (yes, while in the dock).
Mar 09, 2009 | Teac SR-L200i-W Docking Station for Apple...
Battery/docking station ac power
There is no manual way to switch from battery to AC, the machine or docking station should automatically switch between battery and AC. There is a power management chip inside the laptop that regulates the power and switches from battery to AC when plugged in. Some docking stations have a chip built into them to do this. Start by ruling out the power supply. Do this by undocking the laptop and plug it in using the power supply that is attached to the docking station and see if the machine is just running off of battery. If it is running off battery, then check the power supply with an ohm meter for the proper output. The output readings are on the supply. If you have two power supplies, and you know one works with the machine, try that supply on the docking station. If the power supply checks good, then I'm afraid the pm chip on the motherboard has gone out. You will need to take this in to have it professionally diagnosed, because it could be a replaceable component that works in conjunction with the pm chip. However, if it is the pm chip, then the motherboard will have to be replaced in order to fix it.
Jul 22, 2008 | IBM ThinkPad T23 Notebook
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
Try this, with laptop removed from docking unit:
1. Press and hold the laptop power button down, for 10 seconds.
2. Now remove the battery
3. Repeat step one above
4. Let the laptop sit for 10 minutes.
5. Reinstall the battery
6. Make sure docking station is unplugged, and insert laptop into docking station.
7. Plug in power supply (to dock)
8. Start the laptop.
9. IF IT STARTS, let it run a while to see if the battery is charging
10. Remove it from the dock and repeat steps 1-5 above and then go directly to 8 (start without connecting dock).
CONCLUSIONS: If the laptop started in the dock on step 9 but not 10 (only on battery), your battery or power regulator circuit may be damaged. However, if it starts in step 10 but not step 9, your docking station -or its AC power supply may be damaged Let me know how this comes out, please.
Jan 15, 2008 | Computers & Internet
Battery indictes low and turns off
I replaced the battery on my TomTom 910 and still no improvement so eventually sprayed the contacts with switch cleaner. Now, no problem. Probably didn't need to replace the battery.
If you unit is outside guarantee then this is worth trying. Might be as well to detach the battery and all other power supplies until the switch cleaner has dried.
Another possible problem is the rubber gromit which forces the contacts to make contact. You could replace this with a bit of rubber from a pencil.
Hope this helps you.
Oct 23, 2007 | Tomtom GO 910
Tomtom GO 910 GPS Receiver Logo
65 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
