We have a ASUS X83Vb laptop. The computer is no longer accepting the charge from the adapter. The adapter works fine with a green light, but once it is plugged into the computer, the light flickers or goes off, and the computer does not charge.
  • 1,179 Answers
If you remove the battery does the Laptop power on? If the answer is yes then the adapter is fine and the battery needs replacing. They generally last for about 2-3 years and then they die. If it is under warranty then return it to the seller and they will replace the faulty components.
Thanking you
damnor01
Posted on Nov 15, 2010
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
Laptop powers up but a blank screen shows with two green lights showing up top whats the problem
PLug the laptop into an external monitor to see if you get video to the external screen.  You should have a vga port on your laptop, connect it to the laptop and then turn it on.  If you see video the onboard video card on the laptop is fine and most likely you have a bad lcd.  On the other hand if by "powers up and then goes to a blank screen" you mean its posting you see the asus splash screen and instaed of going into windows you see a blank screen.  in that case you mos likely have a bad hard drive or corrupt operating system.  You can test the hard drive by downloading dft and booting from that cd.  here is a link to dft http://www.hitachigst.com/support/downloads/#DFT
May 15, 2011 | ASUS X83VB-X2 Notebook
Hello. Today in the morning my laptop (Asus A8Jseries) was working alright. Then after 6 hours when i tried to turn it on, it didn't. I mean, it starts to work and Asus symbol comes alone, but then it just...
If it happens only when you move the adapter plug inside the power jack, it's likely that you have a problem with the power jack inside the laptop. The power jack has to be resoldered or replaced.
If it happens even without touching the adapter plug, the problem could be related to the faulty power adapter.
You can test the power adapter with a voltmeter and find out if the ouputed voltage is correct. If the voltage is not correct, replace the adapter.
http://www.chargerbuy.com/replacement-asus-a8-ac-adapter-19v-3-42a.html
But don't trust that even if the output votage matches specifications. It's possible that the power adapter doesnt' work correctly under load. Test your laptop with another known good adapter. If the laptop works fine with another adapter, your power adapter is defective and has to be replaced.
Mar 13, 2011 | ASUS A8J Laptop AC Power Adapter (4.3A...
My ASUS Eee 1000HE netbook will no longer charge. When I plug it in, the indicator light on the front edge does not go on, and the computer will no longer turn on, as the battery is also dead. Is the...
remove the battery and check if your laptop can boot or turn on for the matter, if so then the problem is the battery if not then the problem is either the laptop power protector is busted or perhaps the port or the adapter itself is bad.. to check the adapter use a tester to see if there is any power coming out if so then the problem is either the port or the motherboard itself.
Feb 07, 2011 | ASUS Eee PC 1000HE Netbook
Power light blink orange 4 times, 1 green?
My guess is that the battery is worn-out -- no longer accepting a charge, nor holding a charge. Replace the battery, or find a specialty business that "refurbishes" batteries (by opening the case, replacing the cells, and re-sealing the case).
Mar 04, 2010 | Dell Inspiron 6400 Notebook
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Asus ac adapter will not wrk green light on adapter
First check the wall socket make sure you are getting power, plug a lamp into it for instance. If there is no green light on the adapter then it is bad and you will need to order a new one from your computer manufactor.
rate with 4 diamonds
Mar 02, 2009 | ASUS AC Adapter- Universal Notebook AC...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
