Question about HP Compaq Presario 2200 Notebook
How do i set up an external monitor to my compaq laptop if the laptop screen t work
    Genius:
  • 1,542 Answers
Hi
most laptops have a blue connection on the back of it which you plug into with a cable from exterior monitor to the blue connection on the laptop the link shows the kind of cable that you require
http://www.cables2u.co.uk/monitor-cable-premium-male-male-p-444.html
But are you having probs with the screen on the laptop it may just need a replacement driver for the vga display and have you tried all the updates as windows may have the update there for it
Posted on Nov 15, 2010
Compaq turns on cap locklight on f12 light on and power light on black screen
Have you tested this laptop using an external monitor? If your laptop works good with an external monitor, it means your laptop screen is dead and needs to be replaced. If the external monitor displays black screen , it means there is something wrong with the GPU and or motherboard.
Mar 10, 2014 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
Compaq 621 laptop not working with projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 04, 2012 | Computers & Internet
I figured that last problem out now if someone knows how to recover a compaq laptop with windows xp, when monitor is damaged and using an external monitor?
Sep 02, 2012 | Compaq Computers & Internet
How do i get monitor output
You can switch to anexternal monitor by two methods.1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor.2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a lkeycombinations for the laptops :-HP and Compaq = Fn + F4
Mar 11, 2012 | HP Compaq nc6120 Notebook
My hp compaq model 510 is not working with projector.projector is not working on this laptop plz provide a proper solution.
You are not providing enough information to help you.
Have you set the display to use an external monitor or dual monitor? That is how laptops work with projectors. You normally can set the system for dual display and either mirror the displays or use the second display (projector) for power point or other presentation.
If this does not fix the problem, post more information on why it is not working for you.
Jun 23, 2011 | HP 510 Notebook
HP compaq evo 610c after booting only compaq logo appears and then screen goes black.. I have connected a external monitor, it is working fine
Restart the laptop, hit F10 to get into the BIOS. Arrow over to the Advanced menu and then down to Device options. After or before the "USB legacy support" option, there may be a external monitor setting. If it is there, change that, as it may be set to only work with an external monitor connected. After making changes hit F10 to accept.
Arrow over to the File menu and to "Save changes and exit". Reboot. Try that, if it doesn't work, re-enter the BIOS (F10). Arrow over to the File menu and to "Restore defaults". Then "Save changes and exit". Reboot.
Jun 13, 2011 | Computers & Internet
When i conect my presario cq62 to an external monitor HD i can't see anything there.help please!
You have to hold the Fn key and then press F4. There should be 3 settings. Setting 1. Computer Monitor. Setting 2. Computer Monitor and External screen and setting 3. External Screen only. The order changes sometimes but pretty much all laptops follow this sequence in some way.
Nov 26, 2010 | Compaq Presario CQ60-220US PC Laptop
My compaq preasrio r3000 black screen cant conect to an external
have you any other A/V ports out ie Svid etc if so try that via an A/V lead, if that works reset your bios settings to minimal settings, if that doesnt work search the 'net someone somewhere has had the same problem! try shining a flashlight/lamp onto the screen whilst booting up, if you see anything on the screen then your inverter is definatly gone and yes it could still be your inverter! your laptop may have software/hardware issues with an external monitor?
Mar 09, 2009 | Compaq Presario R3000 Notebook
Nx 5000 dual screen problem
What program are you using for the dual setup? Place a shortcut in startup. usually an external monitor is used in place of the laptop LCD. The Monitor may need to be #1 and the laptop LCD#2 http://www.intel.com/support/graphics/intel852gm/sb/cs-009064.htm?iid=search& This site may help too. Good Luck, Tim
Feb 08, 2007 | HP Compaq nx5000 Notebook
HP Compaq Presario 2200 Notebook Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
