Question about Canon PIXMA iP1600 Printer
Canon ip1600 error 5100 - Canon PIXMA iP1600 Printer
  • Canon Master
  • 4,338 Answers
First, reseat your ink cartridges.
if reseating your printer cartridges doesn't work, keep looking for things that would cause the printing head carriage (the thing the print cartridges sit in) to not function properly.
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Posted on Nov 15, 2010
Describe your Canon PIXMA iP1600 Printer Problem
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 16, 2010 | Canon PIXMA iP1600 Printer
Giving me service error 5100
5100 is a carriage travel error, either something is stopping the carriage or there is ink or grease on the encoder strip.
Jan 07, 2010 | Canon PIXMA iP1600 Printer
Hello, my Canon PIXMA IP1600 is suddenly not working and has a code 5100 erorr. What to do?
Error 5100 is always a carriage error.
first thing to do is check is check the timing strip(plastic strip wide around 1/4 inches and usually located behind the print head)
Make sure there is nothing around it like piece of paper or staple or pen/pencil etc.
Make sure the strip is moving freely and hasnt come out of the roller.
Check VERY thoroughly for any obstruction at all, a very small piece of paper can cause the problem.
Dec 01, 2009 | Canon MultiPASS F60 All-In-One InkJet...
I have a Canon pixma ip1600 and it won't print. It just says service error 5100.
Jan 22, 2009 | Canon PIXMA iP1600 Printer
Error 5100
Use the link below to fix the error
http://www.fixyourownprinter.com/forums/laser/25975
2nd solution :
o to the canon website (listed below) - under Tech Support - click on Technical FAQ's (this will pop up another small window)
then click on Search by Key Word
next - type in error 5100 and click on the circle next to - Include all words and hit Search
next - click on the link with your answer "how to.... "
this should show the answer
http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=238&modelid=11865
Oct 20, 2008 | Canon PIXMA iP1600 Printer
Printer troubles
when i start to print it does apper error 5100, what happen please suggest me, where is fault.
Oct 11, 2008 | Canon PIXMA iP1600 Printer
IP1600
hola tengo problemas con una impresora ip1600 no imprime las luces parpadean y aparece una ventana que dice que los cartuchos estan vacios o no son compatibles
Oct 09, 2008 | Canon PIXMA iP1600 Printer
SERVICE ERROR 5100
please suggest me service error 5100, when i start to print it appear service error 5100. what happen ?
Jul 05, 2008 | Canon PIXMA iP1600 Printer
Canon iP1600 Error 5100
Hi, I am having the same problem,
the link is posible solution
http://answers.yahoo.com/question/index?qid=20080115130158AA5y9NZ
Sep 29, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
378 people viewed this question
old marine
old marine
