Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Standby light flashes ten times,when you try to power on the unit you get sound but no picture for about fifteen seconds then it powers off
  • 95 Answers
Your Television needs repair, 10 times blinks is a failure on high voltage section. If you have basic knowledge in electronics you can fix it, just simply replace the PWM generator IC MCZ3001d (near fly-back transformer.) or look for a electronics technician to fix it.
Posted on Nov 15, 2010
  • Josias Aleixo
    Josias Aleixo Apr 12, 2011
    Hi my name is Aleixo, I have on my bench one Sony rear projection Tv model: KP-46WT520. I'm sorry my English, try if you understend my explanation. Thank you
    I plugegd the Tv in outlat nothin happend, then I pushed the power botton, the relay click to turn the Tv on and estart those frist slow 10 blink, in 4 blinks start the sound but no high voltage, the Tv still working sound with no picture until finish those frist slow 10 blink. then those frist 10 slow blinks stop for 5seconds then the relay click again shuting down Tv, and start the error code witgh 10 fast blinks with pause contynuosly.This mean the horizontal shorted, but eventhin ok because sadenly the Tv working fine. Now, if I pushed the power botton again with Tv blinking 10 with pause and 10 blincks, it repit all again, click relay folowing 10 slow blinks, in 4 blinks sound no picture, when finish those 10 slow blink, pause 5 secounds and start the error code with those fast 5 blinks pause 5 blinks continuosly. Those 5 blinks mean CRT board problem, but sadenly it wor fine with no problem. I did check and no found the problem. I need help
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
When i try to turn it on i get picture and sound for about 2 seconds and then it shuts off and the red light flashes,
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
May 07, 2011 | Sony KDS-R50XBR1 50" HDTV
Sony KV-34xbr800 standby light flahes all the
Flashing standby light is an error code that is specific, there would be pause of 3 seconds in flashing, so count pause to pause and let me know that how many times red standby light is blinking to diagnose problem.
Thanks.
Jan 11, 2010 | Sony Televison & Video
Relay clicks, but No sound, No picture.
Hello, just try this first.
Unplugged the unit the power outlet for about 60 sec.Then power it on again. If you have surge strip along the line. You should directly switch in on power outlet only. If this doesn't help.
As the relay is working you have power in standby mode. Check its supply voltages if its ok. Secondly you can check the the B+ supply it is in DC, If this is a crt type tv, check its horizontal output transistor, Check its flyback for short circuit. Capacitor near to it rated almost 800V, and deflection coil.
Just for input, hope it helps
Apr 19, 2009 | Daewoo Televison & Video
BRAVIA KDL-V32A12U PICTURE LOSS
THREE Blinks
B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
